Welcome to the North American Subaru Impreza Owners Club Friday February 26, 2021
Old 02-15-2017, 12:57 AM   #1
Frank 17 STI
Member#: 452989
Default Methanol Power Gains, Worth The Money?
To start I have read the sticky's. I have searched this forum. I have researched on google. I tried to do all of my homework before making this post and wasting anyone's time. I have researched several different kits: Aquamist, AEM, Devils Own, Snow Performance. I have read the differences between installing a 1 gallon tank vs a 5 gallon tank. I have researched which methanol blend to run.
I have also gotten a few prices. Seems like AEM kit + install + re-tune + taxes and puts the total cost at roughly $1,600.
My main question is how much power can one expect. Granted every car is different, every dyno reads different, every tuner tunes different, climate and elevation will affect numbers, I am well aware of all of that. My car is a 2017 STI with full bolt on's and a Cobb 20G turbo. Currently makes 360whp and 350wtq on a dyno jet at 20psi.
I have read that methanol adds roughly 10-15whp. I know it will reduce my IAT temperatures as well. I am just trying to debate it $1,600 is worth 10-15whp. Or if my research is off and methanol can yield slightly greater results.
So people with methanol injection. What did you pick up power wise after installing the kit.
Thank You for reading.
Frank 17 STI is offline   Reply With Quote
Old 02-15-2017, 07:32 AM   #2
can250
Member#: 452601
I picked up 14kw here in australia on a 50/50 blend
can250 is offline   Reply With Quote
Old 02-15-2017, 08:17 AM   #3
undyjr
Member#: 459692
2019 WRX STI
silica black
I find it hard to believe you would only net 10-15whp. Those numbers would make sense on a normally aspirated 2.0 liter. Your tuner would be able to advance the timing and boost yet retain knock resistance. The is not unlike running E85 but without the reduced energy content. I'm going with water meth port injection, the only way I can comfortably get 500whp out of my built FA20. Maybe some of the more experienced members can give you a number on power increase?
undyjr is offline   Reply With Quote
Old 02-15-2017, 09:21 AM   #4
JMlegacy
Member#: 341649
Don't use hp, use % gain as dynos and setups vary.
Before
236whp
After 50/50 meth with homebrewed kit with aquamist fast acting valve:
271whp
Picked up 14% power on 90 octane and a 2 liter. The further back you are with intercooler and octane the further forward water/meth will push you.
with your current 360 assuming you are on 93 octane, I wouldn't be surprise if u hit 390-400 whp.
tip: use two small nozzes not 1 big one
JMlegacy is offline   Reply With Quote
Old 02-15-2017, 11:02 AM   #5
Frank 17 STI
Member#: 452989
Before
236whp
271whp
I like how you said use % power increase. Thank you for the information it is greatly appreciated.
Old 02-15-2017, 05:11 PM   #6
JMlegacy
Member#: 341649
you are welcome
Old 02-16-2017, 03:15 PM   #7
jw4902
Member#: 436758
2016 WRX Limited 6MT
Wouldn't small nozzles clog faster? If so why small?
jw4902 is offline   Reply With Quote
Old 02-17-2017, 10:25 AM   #8
point78
Member#: 344329
2008 Wrx, 6mt
Smaller jets should have a finer spray pattern-smaller drops.
"Technically" smaller would clog easier, but that's why you have a failsafe & filter.
point78 is offline   Reply With Quote
Old 02-17-2017, 03:44 PM   #9
Nurp
Member#: 383782
2014 WRX STi ST
I picked up a kit to help with the crappy gas we have locally. On 91 I was making 265whp and 300lbs.ft torque. With methanol I was about to get 300whp and 350lbs.ft torque. 13% increase.
If you are picking one up, I would advise getting something better than the AEM kit. While the kit and controller itself is okay, the flow meter failsafe is garbage. Mine stops working as soon as temps drop past -10 degrees Celsius.
Nurp is offline   Reply With Quote
Old 02-18-2017, 09:25 PM   #10
JMlegacy
Member#: 341649
Agreed. Check out torqbyte and aquamist
Old 02-19-2017, 12:27 PM   #11
PL-Prez
Member#: 376664
2014 WRX Wagon
My gains on a aquamist kit with 50/50 mix on a 2014 wrx with full bolt ons. Stock turbo.
Went from 315/335
To 335/397
PL-Prez is offline   Reply With Quote
Old 03-07-2017, 07:58 PM   #12
bholton93
Member#: 421184
2015 WRX
Dark Gray Metallic
2015 wrx with full bolt on. TMIC, charge pipe, intake, j-pipe, erg, tgv, BPV...however running STI (spt) catback (not 3inch)...you guys think this would bottleneck me if I went meth (if it isn't already) ?
bholton93 is offline   Reply With Quote
Old 03-12-2017, 06:35 PM   #13
Nurp
Member#: 383782
2014 WRX STi ST
I'd probably say your stock turbo might be what will be limiting you if you were to use meth.
Old 03-25-2017, 11:24 AM   #14
russian777
Member#: 300971
Rally blue
Well done
russian777 is offline   Reply With Quote
Old 04-05-2017, 02:44 PM   #15
vmphil
Member#: 463931
2017 WRX
Red
now, what if one were to use a Water/Meth set up purely as a carbon build up deterrent? Not trying to make big power. I'm pretty sure I would still need a tune of some sort with the Water/Meth. Is there just a base tune or stage 1 with Meth of do I have to go stage 2+ etc etc.?
vmphil is offline   Reply With Quote
Old 04-05-2017, 03:44 PM   #16
Nurp
Member#: 383782
2014 WRX STi ST
You can run meth without a tune if you wanted to but you won't be getting much power gains without one. I've read of people using WMI strictly for the safety and the cooling benefits without changing their tune. You will run rich but you'll get better knock protection and cylinder cooling.
Old 04-05-2017, 05:24 PM   #17
vmphil
Member#: 463931
2017 WRX
Red
Thats what I needed.
Thanks!
Old 04-09-2017, 07:42 PM   #18
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
I've been running 26+ PSI on 91+ 50/50 Hydramist on a 35R for over 6 years and on a 30r for 5 years before that. It isn't just for power is also a great for lowering intake temps and making the air more dense but if you don't tune your car for it it will actually make you slower.
stu is offline   Reply With Quote
Old 04-10-2017, 11:48 PM   #19
Johnhalgat
Member#: 465855
2016 WRX STI
Hyper Blue
Not really
Johnhalgat is offline   Reply With Quote
Old 04-12-2017, 07:27 PM   #20
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Picked up 40whp and similar torque. That's running straight methanol without water though, other setups will vary. Nowadays with Cobb flex fuel its not worth the investment if E85 and competent tuner are near you.
Methanol gains are comparable to E85 on the top end, not as much torque gain because it doesn't kick on until you're already in boost. E85 can take big timing gains to get into boost faster which translates to more torque and broader torque curve.
imma_stocker is offline   Reply With Quote
Old 04-27-2017, 05:54 AM   #21
sheesh
Member#: 410078
2015 WRX
Default 2015 wrx
deleted
sheesh is offline   Reply With Quote
Old 05-16-2017, 10:09 AM   #22
Angelo_Wrx
Member#: 467747
My buddy picked up 30 HP
Angelo_Wrx is offline   Reply With Quote
Old 05-27-2017, 06:44 AM   #23
worksti
Member#: 117847
2005 Rotated DOM3XTR
460whp, 400wtq Pump Tune
My car made 487whp / 470wtq on methanol / water injection via Devil's Own and 460whp / 400wtq on 92 pump all other factors being equal. Gains really depend on your engine and turbo setup
worksti is offline   Reply With Quote
Old 06-19-2017, 10:46 AM   #24
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Gains depend on a lot of things. My build is a 9.1:1 CR 2.34L long rod motor. On 91 pump I comfortable tuned the engine to a safe 400 whp. The 9.1:1 CR doesn't like CA 91 octane at all. Pump and 50/50 meth put me @ 500 whp. The Aquamist allowed me to run much more boost and timing safely.
I'm going E85 now and may remove the meth kit though since I more than likely will no longer be knock limited.
Old 11-17-2018, 08:55 AM   #25
lockheed
Member#: 398030
2004 forester sti
Where are you guys fitting the nozzles ? I have a front mount ic ,standard position inlet and no blow off valve.
Any pics of the installation ?
lockheed is offline   Reply With Quote
