Welcome to the North American Subaru Impreza Owners Club Sunday December 5, 2021
Old 09-05-2021, 10:24 AM   #1
SuperPete
Member#: 517987
Default Faulty Throttle pedal?
2012 WRX with STI swap in it.
Been noticing this behavior that I am trying to narrow down.
Tuner checked logs many times and he is positive its not in the map, he says something in the car itself.
Here is the issue.
between 2500 and 3000RPM in 3, 4 or 5th gears as I am lightly accelerating or just cruising I get few jerks, 1-3, feels like I fully let go and press pedal again, I can even hear blow off going off, usually under light load on the pedal, not smashing it.
I checked my log and I see that both acceleration and throttle graphs matching up and drawing the W line when I know for fact I did not let go or moved the foot and in fact I was pressing to accelerate.
Its not happening every time I say 2-3 times out of 10.
Is it possible that my pedal is going bad? because if it was throttle position then my pedal graph would not match my pedal.
Any ideal anyone? car body has 185K miles.
Thanks you!
SuperPete is offline   Reply With Quote
Old 09-16-2021, 07:14 AM   #2
Jpearo
Member#: 526587
I have a very similar problem with my 2004 fxt. 6 months ago i had a cel for a tps but haven't since.
Jpearo is offline   Reply With Quote
Old 09-16-2021, 11:43 AM   #3
Jedi03
Member#: 491095
2009 STi Blue
if they are matching, then likely the problem is elsewhere...
Jedi03 is offline   Reply With Quote
