Welcome to the North American Subaru Impreza Owners Club Monday April 19, 2021
Old 03-04-2021, 02:35 PM   #26
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by Bariga View Post
I tried the exhausts solution it wasnt good, pulled no vacuum and at some point actually pushed air back
Fairly normal for low load/idle on the exhaust side. I see it used more when VTA is not allowed and the AOS or catch can being used is garbage. 10+ years ago it was more common, but not nearly as much anymore. We know more now than we did then
Old 03-05-2021, 01:13 PM   #27
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Probably best solution here would be to have mechanical pump, and mount it in tranny bay area, and drive it from crank shaft rotation.
Bariga is offline   Reply With Quote
Old 03-06-2021, 01:01 AM   #28
albersondh
Member#: 196882
08 WRX
Exhaust scavenging works. How well is debatable, but proper plumbing and execution make all the difference. The one-way valves the cheapo kits come with are trash and easily replaced with much higher flowing valves with very low vacuum required for opening. I have no reversion issues with 272 cams. Certainly better than VTA, and when used as a part of a system that employs a vacuum pump, and condenser/oil separator it works great. I did it simply because I was sick of smelling my crank case after a hard pull (beats a draft tube/VTA). I had no expectation of pulling any measurable vacuum, just wanted to keep vapor moving while the pump was not engaged.
albersondh is offline   Reply With Quote
Old 03-06-2021, 05:49 PM   #29
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There's more parasitic loss than upside. Why opposed to using the turbo inlet as a vacuum source?
