Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 07-12-2002, 11:07 PM   #1
Night Kid
Member#: 13100
2002 Impreza WRX
Default What hp gains can i expect from a uppipe?
Wassup everyone!!
What kinda hp gains can i expect from a uppipe alone? I just installed a godspeed uppipe a day ago and i could feel some improvement in power but not too much. Anyways, just curious to see how much hp it raised. Thanks
Night Kid is offline   Reply With Quote
Old 07-12-2002, 11:21 PM   #2
Division By Zero
Member#: 7555
I would think negligible. On the top end - yes (a little) and on the bottom it'll assist in spool-up by 500 rpm's or so.
Division By Zero is offline   Reply With Quote
Old 07-13-2002, 01:40 AM   #3
slin02
Member#: 11588
the main purpose for the uppipe is not really the HP gain, faster spooling, lower EGT and knowing nothing will flow into your turbo is way better than HP gain.
slin02 is offline   Reply With Quote
Old 07-13-2002, 03:02 AM   #4
Yellow Rex
Member#: 6725
2002 IMPREZA WRX
BLAZE YELLOW
OK, it will spool up quicker, but just what is it that is going to go into your blower if you use the stock pipe?
Yellow Rex is offline   Reply With Quote
Old 07-13-2002, 03:35 AM   #5
KillerRex
Member#: 15675
'92 R32 Skyline GTR
The catalytic converter that's in the stock uppipe could go into the turbo. A catless uppipe will obviously make that a non-issue. Uppipe is more of an "insurance mod" rather than an HP mod. If you want more power, get a turbo back exhaust or boost controller.
KillerRex is offline   Reply With Quote
Old 07-13-2002, 11:52 AM   #6
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
what killerREX said and they say about 5-10 hp gain with up pipe.
gets rid of one cat, increases flow, turbo spools up a little faster.
i think along with the up pipe get a mbc too
stickman is offline   Reply With Quote
Old 07-13-2002, 12:41 PM   #7
Z1 Performance
Member#: 9327
its defiantely a wrothwhile mod, but its the type of thing that you are SO much better off when swapping the turbo..you'll get more out of it (bigger turbos have bigger opening where up-pipe bolts to), not to mention that for another 15 minutes of work, the turbo can be swappd too, so you are not paying 2 labor bills!
Again, a very worthwhile mod, but there are other things that should come first...turbo back exhaust and boost controller
adam
www.z1auto.com
Z1 Performance is offline   Reply With Quote
What power differential can I expect from a protune? nos AccessPort 14 04-27-2006 06:35 PM
What kinda gains can I expect? m4r10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-13-2005 01:20 AM
What kind of HP and torque can I expect from this setup? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2002 04:40 PM
How Much HP Can I Expect From.......??? xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-25-2002 10:31 PM
What HP gains could i get from these mods? Shrubba Normally Aspirated Powertrain 6 04-07-2001 12:00 PM
