Welcome to the North American Subaru Impreza Owners Club Thursday June 4, 2020
Old 04-08-2020, 09:03 PM   #1
st1_ftw
Member#: 513104
2017 STI
Default STI brake pads swap
I was planning to replace current OEM brake pads (sti 2017), at 5mm front and rear now, with Akebono performance ceramic pads.
My question is, can I simply swap the pads, without changing rotors? Currently on OEM rotors (41K).
And also, can I replace when they start making noise, around 2-3mm, or should I replace them now at 5mm preventively to reduce the risk of rotors damage?
Thanks!
st1_ftw is offline   Reply With Quote
Old 04-09-2020, 07:51 AM   #2
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
For street duty, replacing pads at 5mm would throw at least a quarter of their service life/miles in the trash bin. So unless you have some other over-riding reason to swap pads, hold off a while. Worst case, the pads' wear indicators will start to lightly scrape on the rotors (to make the noise), but this won't damage the rotors.
When you do replace the pads, you'll still need to determine whether your rotors have sufficient thickness whether or not there is any light grooving or scoring that could be machined back to 'flat'.
Norm
