Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Old 07-12-2007, 04:52 PM   #1
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Default Which fuse to tap in to for 12v
Hey guys,
I'm no expert in wirering, but i need to tap a 12v wire (WIDEBAND GAUGE) in to the fuse box located under the driver seat. Which fuse would you connect your 12v Ign wire to?
Can I use the Radio 15A one?
WRX4eva is offline   Reply With Quote
Old 07-12-2007, 04:59 PM   #2
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
The radio fuse should work fine... i think you are meaning the fuse block under the dash right? not under the seat???? unless your 04 is diff from my 07.
boostdog is offline   Reply With Quote
Old 07-12-2007, 08:52 PM   #3
fuzzymemory
Member#: 63477
04 WRX Wagon
San Remo Red
Question 1: What device/accessory are you looking to run? (more specific the better)
Comment 1: If you are wiring up something that doesn't draw that much current, such as a radar detector or a Sat radio unit, then I'd suggest using a Add-a-Circuit device. What this does is piggyback off a fuse in your fusebox, then you run your power into the cord on the add-a-circuit. Similar to a fuse-tap, but much safer because it lets you have a separate fuse for each item. It also makes things much easier to uninstall, and you don't risk cutting the stock wiring of the car like you would with a vampire (crimp) tap.
fuzzymemory is offline   Reply With Quote
Old 07-12-2007, 09:06 PM   #4
WRX4eva
Member#: 103343
I just tapped off from my radio wires. THanks for the help. Everything has worked out.
Old 07-12-2007, 09:07 PM   #5
v8eaterWRX
Member#: 108547
2017 Tundra 1794
Lifted, Armored, Muddy AF
^^where can you buy that?
v8eaterWRX is offline   Reply With Quote
Old 07-12-2007, 09:27 PM   #6
umscooby
Member#: 50902
05 STi
^ most auto parts stores have them
umscooby is offline   Reply With Quote
Old 07-13-2007, 01:15 AM   #7
fuzzymemory
Member#: 63477
04 WRX Wagon
San Remo Red
Yeah, I've seen them at AutoZone and Advance Auto Parts. They run about 6-12 bucks. You can also order them online from many places. My 04 Impreza uses the "mini" size fuse. It made getting power for my radar detector that much easier to install and remove.
Can i use the rear wiper fuse as a source to tap +12 Switched for my gauges? 03WRXMA Electrical & Lighting 8 01-14-2010 11:03 AM
Puttin in gauge pod- where to tap in to manifold for boost pressure? stevessti Electrical & Lighting 5 01-30-2005 01:31 PM
good locations to tap in for water temp & oil pressure ? SportyBry STi Forum Archive 4 08-23-2003 03:25 PM
Flat Tire Noob which fuse (20,15,10) to disable AWD Zartan Newbies & FAQs 1 06-24-2003 09:08 PM
Where to tap in for boost gauge??? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-18-2002 02:33 PM
