08-02-2012, 07:53 PM | #5951 | |
Member#: 280582
Vehicle:2009 2.5i premium ssm |
08-02-2012, 08:43 PM | #5952 |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
Looks good Jourdan. Did you notice any differences vs stock when you made that? I probably wont attempt that but I may try and use the same location for some brake ducts lol.
Also Christmas came early |
08-02-2012, 08:49 PM | #5953 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
Not mine... I decided I don't need it since half my fender liner is missing.
And screw you for getting Koni inserts. I'm super jelly. One of these days I'll get a set. |
08-02-2012, 09:21 PM | #5954 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
I'm definitely going to try that Funnel routing.
But to me it seems like the air has to travel a longer path and would alternatively disrupt air flow as 2 sources come in at the same time. And all the bends and creases would slow down air travel compared to having it tied down to the fog light like some sti owners do. Kartracer, the piece isn't 90degrees but I see what your saying. Another route I was thinking of doing is cutting my OEM grille to match that of a jdm c-west grille where one side dips down for direct air travel kinda like the nose navy sesal was mentioning earlier. Last edited by theoutbackdream; 08-02-2012 at 09:27 PM. |
08-02-2012, 10:26 PM | #5955 | |
Member#: 280582
08-02-2012, 10:34 PM | #5956 |
Member#: 248840
NWIC
Vehicle:2011 Impreza Satin White Pearl |
Anyone have any tips for installing the OEM front underspoiler?
08-02-2012, 10:43 PM | #5957 |
Member#: 268328
BAIC
I got a replica of the oem one and I riveted the sides where it overlaps on the inside of the fender. If you decide to paint it, take your time and spend extra time prepping.
Jourdan- thanks, I spent a lot of time just getting the right price . I thought you were going to get a ground control kit this summer? |
08-03-2012, 12:58 AM | #5958 |
Member#: 280582
Well I did it. Think this is all I'm gonna do except get rid if the blue vac host and coupler gonna do those black prob. Oh and if anyone else has done the hybrid intake...for the liove of Pete..how did you do the stupid vac lines. Every where I've looked I can't see a decent pic or no one really explains it and the two threads about hybrids are dead now
Edit....ready for the flogging...what you guys think.. Last edited by krzywhtboi82; 08-03-2012 at 01:04 AM. |
08-03-2012, 01:29 AM | #5959 | |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
I did mine by myself, so I lined everything up and started by putting in one of the driver side screws while the rest of the lip was supported with a cardboard box. That would've been easier with a helper, but it was ok. Remember to start the corner pieces of red tape cover plastic strips, so you can pull them out when you are done, so the double sided tape doesn't stick to early. Don't take the protective cover off the double sided tape untill you're sure everything is lined up perfectly. It's really pretty easy, and doesn't take long at all. Oh, and don't let the lip twist or bend before you install it or you'll crack the paint (if you got the Subaru pre-painted one) And I think you re-use some of the screws from your car, and you get some new ones to use in existing holes under there. Just make sure you read directions and figure out where they all go before you start screwing them in.. or you might not get them all in the right place- or you might have to take them all out to re-adjust the lip where it goes on top or on the bottom of existing plastic pieces. You'll see what I mean once you start fitting it. If you do it right it's amazing how perfectly it fits. Not even 0.10 mm gap anywhere. ------- ---------------- ---------------- -------------------- |
08-03-2012, 01:48 AM | #5960 |
Member#: 301179
BAIC
okay, so my Intake system seems to work ALOT better. The car pulls through gears smoother IMO and faster.
If to lazy to read: The Butt dyno approves. If you want to read indepth: After driving my car on local and expressways today, I've noticed a bigger gain in power. The temperature difference from yestarday and today, was that It was a bit warmer today than yestarday according to the in car dash guage. It recorded 70-73degrees today while driving. While there was not much of a difference in the low RPMs, (0-1500rpm), there was a noticable difference in the 1500rpm til shift point. The power felt more linear and felt like power was there especially at the higher end of the RPM guage. 1 Major difference I spoted was the engine bay temps. Before the Air intake system would be decently warmed up after a 10min drive. This was not the case. The intake inlet felt almost cold, id say 60-70 degrees, and didn't feel warm up untill the Torque box. BWX, about the Engine bay temps. It seemed to me like there was no additional heat buildup to this mod. Conclusion: -More noticable power at the higher end of the RPMs. -Colder Air for sure. -Power feels more linear. -Ill keep you guys posted. Edit: Ill take a drive today and use a temp gun and post pics. Last edited by theoutbackdream; 08-03-2012 at 09:53 AM. |
08-03-2012, 02:00 AM | #5961 |
Member#: 301179
BAIC
BTW just wondering, is it safe to run 65w bulbs in replacement for the 55W OEM bulbs?
08-03-2012, 03:28 AM | #5962 | |
Member#: 305008
BAIC
Vehicle:2008 outback sport Newport Blue Pearl |
08-03-2012, 05:12 AM | #5963 | |
Member#: 248840
NWIC
08-03-2012, 10:52 AM | #5964 | ||
Member#: 146287
BAIC
08-03-2012, 11:31 AM | #5965 | |
Member#: 280582
08-03-2012, 11:41 AM | #5966 |
Member#: 301179
BAIC
08-03-2012, 12:31 PM | #5967 | |
Member#: 280582
08-03-2012, 12:44 PM | #5968 |
Member#: 146287
BAIC
So the way I did it...
Stock configuration, you have the torque box. Connected to the torque box is a short hose that bends up to a 90 degree T piece that also clips to the torque box. Then you have the white connector that clips to that. I reused the small bent hose and the 90 degree T piece. That hose is wider than the others. I think it's 5/8 where the others are 1/2. I used a 5/8 to 3/8 and have 3/8 hose connecting to the intake. |
08-03-2012, 12:53 PM | #5969 | |
Member#: 280582
Your sktill using the plastic price to right That's how I did it but it doesn't look very clean.bugs me every time I see it. |
08-03-2012, 01:03 PM | #5970 |
Member#: 146287
BAIC
Still using the plastic bits yeah.
Since I have my hose going under the intake and to the catch can, it's not much of an eye sore. But I can't think of a better way to do it without cutting the OEM hose. You can kinda see it here. http://i137.photobucket.com/albums/q...g?t=1333676531 |
08-03-2012, 03:18 PM | #5971 | |
Member#: 236305
edit.. First read through I thought you said 10mm.. 0.10 mm gap? Just loosen all screws and try to adjust it maybe? Didn't you see problem before you took the tape covering plastic strips off (the final step)? Or did you stick it on with tape uncovered? Last edited by BWX; 08-03-2012 at 03:23 PM. |
08-03-2012, 04:46 PM | #5972 | |
Member#: 268328
BAIC
08-03-2012, 06:34 PM | #5973 |
Member#: 280582
Ok I see. So there's a fuse in there? What's it even for? Is it the iat. Oh should I do the catch can set up? Is it worth it what's the pros to doin one.
08-03-2012, 09:22 PM | #5974 | |
Member#: 268328
BAIC
08-03-2012, 10:09 PM | #5975 | |
Member#: 280582
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
