Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 01-01-2009, 06:58 PM   #1
blackcompany
Member#: 143158
2007 STI
UGM
Default DIY plasti-dip painted interior, blue suede headliner + spec-C roof vent
So after researching on NASIOC forums I decided to get rid of that ugly beige top interior in my 07 STI. I have been using plasti-dip for all the plastic pieces and have the 3m 90 strength fabric adhesive and dupli-color fabric and vinyl dye.
3 cans plasti-dip spray
1 can plasti-dip brush on
1 can dupli-color vinyl/fabric paint
1 can generic prep-spray
1 large can 3M adhesive spray 90 strength
3 yards Blue suede microfiber
1 roll blue painters tape
1 hardheaded yet understanding wife
1 eager two year old son
The last two items occasionally but usually do not help progress.
Here is what I have done so far, pics to come later. So far it looks GREAT!
I removed all the interior pieces necessary to remove headliner, prepped and painted all the pieces (A,B,C pillars, oh crap handles, sunvisor plastic pieces, map and dome lights, and clips that hold the headliner in place)
After the first coat everything came out a dark grey which was ok...but there was a bit of un-even coating which I expected because I SUCK at painting with anything. After second coat OMG amazing, texture is spot on factory black with a nice shine like right after a good armor-all wipe down and even though I thought some parts were sprayed a little thick it all evened itself out. This may be because I took a page from a VW restoration as a teen ager and hung all my pieces to paint and dry.
(Did I mention it is COLD and my garage is not heated. It would have been great since I spent two days cleaning it up and getting it ready to be worked in and store my STI but the garage door went terminal and because of the odd size its going to cost my $700 to fix and I am not paying that for a rental place. Of course I rent from my brother-in-law who has no extra cash so I am SOL in the garage door department)
But I digress, optimum temperatures are 70-90 degrees ferenheit and it is 35 degrees average right now. This caused one of the cans to be kind of thick and start sputtering about half-way through the can. I switched to another can and finished up. In all I have used 2 cans worth of plasti-dip out of three cans.
After I pulled the interior and I saw a thread for the Spec-c roof vents on sale for $399 shipped, I jumped on it. Now I have been working on the interior on and off for about 5 days now when it is warmest checking on pieces and doing everything I can to make sure I get as much painted as possible including those impossible to paint seat belt pieces.
I have learned that if you do a light coat and let it completely dry, like two days time for me, the second coat goes on strong and doesnt peel off as easily. Hence my oh crap handles coming out nicely.
As for the pieces on the seat belts that are 'unremovable' I also purchased a can of brush of plasti-dip and I have plans to painters tape my belts over a large area and sponge the plasti-dip on to the loops in several coats. I will report on how this works out later.
Once my spec-c vent comes in I will be following some detailed guides from NASIOC as well as other forums to do the best I can cutting the roof out of my car . Then the rest of my interior can be returned to the car and I can show it off, hopefully this will be done by the third weekend in Jan. Depends on shipping! So I can show it to my friends at drill and then at my first meet in Cincinatti area. (See MWSOC forum for details cincinatti teh thread sequel.)
Also, while I am in the interior mode I am going to modify my sub enclosure that holds two 10" JBL subs to be a little shorter and more narrow while creating a different angle for the sound to more effectively use the trunk space for cargo as well as large sounding board for the subs. After this carpentry work is done I am goine to wrap it in the same blue suede as the headliner and maybe eventually redo the trunk carpet pieces with black suede or just dye them black, probably try dye first to maintain factory function with all the tool storage.
pics, pics, we want pics! I know! I will get them up when I find time. Wife is home for vacation and has been deployed for military purposes since last Feb. so I am stealing time from her everytime I work on the car. Hard to work on car marriage and child-raising all at the same time.
Did the headliner yesterday, looks decent but not perfect, added some detailed tips in lower post. I may have it redone professionally down the road. not until I install the spec-c vent though. Still waiting for its arrival.
*Edit* look out pics!
blackcompany is offline   Reply With Quote
Old 01-02-2009, 08:45 AM   #2
anthony_delprete84
Member#: 88254
sounds good, can't wait to check it out
anthony_delprete84 is offline   Reply With Quote
Old 01-02-2009, 09:38 AM   #3
Shagon Wagon
Member#: 145005
Chic ks dig it Lloyd
It's the Shagon Wagon !
Yea im definately waiting to see this one !
Shagon Wagon is offline   Reply With Quote
Old 01-04-2009, 02:12 PM   #4
blackcompany
Member#: 143158
2007 STI
UGM
So my wife and I did the headliner yesterday in the blue suede. I gotta a say, what a PITA. I followed other threads instructions by spraying the headliner and material with 3M 90 strength fabric adhesive. Then waited for the glue to become tacky and began applying the material to the headliner in small sections and rubbing vigorously to remove all wrinkles. Here is the issue with what went down. If the material comes in to contact with the headliner it will begin to adhere without any pressure, and if you take too long the glue will dry to the point where rubbing will not make it adhere at all.
A note for application that may be more clear than other instructions that I have read is to spray adhesive in small sections on headliner and material, wait for it to become tacky and then rub it together, repeat these steps to completion. Furthermore It seems it would be better to work from front to rear. Visors to trunk, because of all the different humps and angles in the front and then to the smooth rear sections.
Old 01-04-2009, 02:28 PM   #5
Un0RiGiNaL
Member#: 189748
need pics!!!!!!!!
Un0RiGiNaL is offline   Reply With Quote
Old 01-04-2009, 02:32 PM   #6
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
That's the way I was taught to do headliners, phantom tops, etc. Because the glue is so tacky, and the workpiece so big, you need to break it down to sections that are easier to work with. Also, keep the material pulled tight. That helps cut down on the wrinkles.
Good luck, and take some pics. I'd love to see what you come up with.
steve is offline   Reply With Quote
Old 01-06-2009, 09:59 PM   #7
blackcompany
Member#: 143158
2007 STI
UGM
PICS ARE COMING! The weather is really nasty right now and freaking cold, so since my garage door wont open...its terminal...I am locked out with only my small parts that fit through a house sized door inside and no heat in there so its FRIGID.
As for the headliner...arghh. It looked like crap! Too many little wrinkles around the edges for my taste. (wife didnt notice them but I did) So I gently ripped that stuff off and ordered some more. Judging by how easily I removed the material it probably wasn't a good job anyway. I will be the first to admit my defeats. So I sourced a guy that actually does this stuff to help me get it done right.
Old 01-06-2009, 10:31 PM   #8
piecemealBHC
Member#: 106248
2015 WRX CWP
2000 RS 2.5
tittywop.
piecemealBHC is offline   Reply With Quote
Old 01-07-2009, 12:04 AM   #9
4wdrift
Member#: 1403
99 RBP GC8 Impreza
dittotottiwwop...
4wdrift is offline   Reply With Quote
Old 01-07-2009, 12:38 AM   #10
DC16A2
Member#: 174357
2002 OBS
pics!! =)
DC16A2 is offline   Reply With Quote
Old 01-07-2009, 01:10 PM   #11
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
+1 for pics
jcbluescooby is offline   Reply With Quote
Old 01-07-2009, 01:19 PM   #12
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
no pics = fail
06HAWKMAN is offline   Reply With Quote
Old 01-07-2009, 01:23 PM   #13
ryan_13
Member#: 191604
2004 STI Stage 2
Originally Posted by 4wdrift View Post
tottiwwop...
x3!!!
ryan_13 is offline   Reply With Quote
Old 01-07-2009, 02:05 PM   #14
SpitFyRe666
Member#: 191146
2005 Sti
WRB/Gold, what else...
bump for pics.
SpitFyRe666 is offline   Reply With Quote
Old 01-07-2009, 02:42 PM   #15
blackcompany
Member#: 143158
2007 STI
UGM
I am taking pics of the plast-dipped pieces right now! However, I'm hungry so I am eating lunch!!!
Old 01-07-2009, 05:03 PM   #16
blackcompany
Member#: 143158
2007 STI
UGM
larger pics available @ http://www.cardomain.com/ride/3190864/2
p.s. I still haven't figured out what all this titty wopping is about.
Old 01-07-2009, 07:19 PM   #17
FireScoob
Member#: 86642
ttiwwop = this thread is worthless with out pics
FireScoob is offline   Reply With Quote
Old 01-07-2009, 08:35 PM   #18
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
hmmm i shoulda used plasti dip maybe i'll do it again. mine looks the same but is obviously less durable
vtecTHIS is offline   Reply With Quote
Old 01-07-2009, 10:35 PM   #19
doylfish
Member#: 88099
2004 Audi S4
2003 Suzuki SV1000S
props for having the patience and time to do that..with a 2 year old and all..i know my 5 yr old nephew is a handful and he isn't even mine
doylfish is offline   Reply With Quote
Old 01-07-2009, 10:39 PM   #20
blackcompany
Member#: 143158
2007 STI
UGM
the stuff WILL scrape off with some effort but the whole piece is coated in like a rubber jacket.
Old 01-07-2009, 11:52 PM   #21
DC16A2
Member#: 174357
2002 OBS
Great work =) Not only does it look very well done, I bet they cut down on some degree of road noise.
Old 01-08-2009, 08:34 PM   #22
1SiKWaGoN
Member#: 100263
2003 WRX Wagon
Looks real good. Do the actual sun visors look black or are they more dark gray like the pics on cardomain?
Are the pillars pretty easy to take off? Do they just snap off or are there some screws?
Looking forward to seeing the suede headliner
1SiKWaGoN is offline   Reply With Quote
Old 01-08-2009, 08:47 PM   #23
1slwsti
Member#: 149879
05 STI
330/350
only thing i hate is that you cant really do the seatbelts
1slwsti is offline   Reply With Quote
Old 01-08-2009, 09:06 PM   #24
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
^^ koji did look on his thread
bigolrig is offline   Reply With Quote
Old 01-08-2009, 11:34 PM   #25
blackcompany
Member#: 143158
2007 STI
UGM
Just gave sunvisors second dye today and the are BLACK! They still come out lighter in pics though. As for KOJI!!! Darn him! Lol, seriously though I was going to/ am going to the seatbelts. I haven't seen Kojis write up on how he did his but I have my own idea and I am going to check his out right now.
SOOO totally just read Koji's thread and how he did his belts, strikingly similar to how I said I was doing mine! Of course no one likes to read they just want pics and excerpts.
I'm sure I will never get any credit for innovation because, well just because.
Where to cut my roof? Just got spec c roof vent. SeventySTi Southern California Impreza Club Forum -- SCIC 18 10-02-2008 06:10 PM
Plasti-dip painted console 02-04 owners MF-DIF Interior & Exterior Modification 3 08-07-2008 09:00 PM
STi RA Spec C roof vent assembly BIGSKYWRX Private 'For Sale' Classifieds 13 06-07-2004 10:42 PM
FS:JDM STi Spec-C roof vent and cup/business car holder shumai_boi Private 'For Sale' Classifieds 9 05-06-2004 10:16 PM
WTB: GD Spec C Roof Vent SimpleSkin Private 'Wanted' Classifieds 5 12-24-2003 03:27 PM
