Welcome to the North American Subaru Impreza Owners Club Friday February 22, 2019
Old 02-11-2019, 07:33 AM   #1
Carl1up
Member#: 496829
Default New to me Subaru
Bought a 2010 outback 2.5 blown head gaskets pulled motor sent heads out when putting the heads back on stripped out a head bolt. Bought a used motor installed in car runs great I have changed many sensors along the way it now keeps sending the p0198 code. I have replaced the oil temp sensor three times now same code instantly. Any ideas new to Subaruís. Thanks. Carl
Carl1up is offline   Reply With Quote
Old 02-11-2019, 09:15 AM   #2
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Wiring issue? Corrosion? Broken? Etc?
viper_crazy is offline   Reply With Quote
Old 02-11-2019, 09:19 AM   #3
Blktrax
Member#: 220971
2002 WRX 223K Mi.
If you've replaced the sensor, its likely the harness or connector.
Check the plug and make sure one of the pins hasn't pushed back into the connector.
Also check the main engine harness connector, sometimes pins get bent when re-locking it together.
If both those check OK; you may need to do a wire continuity test. Sometimes when the intake is bolted back on, the harness can get pinched and goes unseen.
Blktrax is offline   Reply With Quote
Old 02-11-2019, 10:36 PM   #4
Carl1up
Member#: 496829
I bought the motor with 23000 miles didnít tear it down just inspected it thoroughly. I will check the wire connector and the main plug. Thanks
