Welcome to the North American Subaru Impreza Owners Club Monday November 23, 2020
Old 12-13-2002, 06:35 PM   #1
kotaro
Member#: 8256
Question STi air-water intercooler??
Is this really an sti part or is it just a standard one painted in silver and with some different stickers?
A standard air-water IC:
An STi one?:
(all the pics are here )
Besides the different color, and the different stickers, the silver one has 2 caps or two openings in the top, while the black one has only one...so maybe it is an STi part?
Anyone knows anything about this?
kotaro is offline   Reply With Quote
Old 12-13-2002, 07:14 PM   #2
EJ22T
Member#: 26603
1994 EJ22T powered-
majic carpet, Boo yaaa...
I think its only a standard subaru air-water. knowing that its a legacy chassis with the EJ20T engine. Sti made only a handful of the ultra rare legacy turbo STi RA, and I think they still used the stock air-water IC. But yes, to me it looks like a standard legacy turbo with the stock air-water
Mark,
EJ22T is offline   Reply With Quote
Old 12-13-2002, 08:27 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Those are right hand drive right? The location of the brake fluid resovoir and wind sheild wiper motor is freaking me out.
On the right side of the picture on the rear most intake runner is a tan colored item, is that the Idle controller? Where would the ABS controller go on these cars?
Old 12-13-2002, 08:50 PM   #4
kotaro
Member#: 8256
Yes they are right hand drive cars, and if I recall correctly, ABS was optional not standard on RS turbos.
And I still think this MIGHT be something different from the standard IC...I mean I see 2 caps in the top of the silver one v/s 1 cap in the top of the black one...
Old 12-13-2002, 08:54 PM   #5
biggreen96
Member#: 12535
Low 06 5MT OBXT
92 EG33 Legacy Rally Car
If you look real close you can see a hole where the cap should be on the black one.
biggreen96 is offline   Reply With Quote
Old 12-13-2002, 09:00 PM   #6
kotaro
Member#: 8256
Unhappy
I can't see anything...so I went to fullboost to search for another pic and found this one
and I can't see anything either
Old 12-13-2002, 09:05 PM   #7
kelley
Visiting NASIOC Timeout
Member#: 5681
94 legacy turbo
04 sti
what about the airbox in that first pic. does any body know anything about it. that is exactally what I've been looking for.
kelley is offline   Reply With Quote
Old 12-13-2002, 09:20 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
Looks like it was home made to me. I did something similar on my supra.
The easiest way is to make the box the way you want from cardboard. Get it exactly the right size then use the cardboard as stencils to cut the material. I bought a big peice of broken plexiglass for cheap and made a decent looking air box.
biggreen96: I think the silver one is different, I used photoshop to brighten up the areas of the two other pics and no hole exists on the passenger side of the intercooler for the black ones.
Old 12-13-2002, 09:40 PM   #9
biggreen96
Member#: 12535
Low 06 5MT OBXT
maybe I just saw a smudge of dirt...
Old 12-13-2002, 09:54 PM   #10
kelley
Member#: 5681
94 legacy turbo
04 sti
hey ciper, I get some low quality primered pics of the aerotech body kit could use photoshop to make it body color and freshen it up. thanks, kelley.
Old 12-13-2002, 11:04 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
kelley: I could try, Im not a graphics artist or anything show results may not be so good.
Old 12-17-2002, 08:38 PM   #12
SubbyRS
Member#: 17193
1991 Legacy RS
I have a '91 Legacy RS with the black water/air intercooler....AFAIK the only difference between the black & silver units is the silver one has a water level indicator/sensor which is the connector on the RH side of the intercooler...my black one doesn't....in terms of capacity etc, they're the same.
SubbyRS is offline   Reply With Quote
Old 12-18-2002, 10:16 AM   #13
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
ciper.......that tan cap thing.....is the IAC valve....if you were still wondering....
Legacy777 is offline   Reply With Quote
Old 12-18-2002, 03:16 PM   #14
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
i have a black on in my garage ..i can take a bunch o picts if people would like .. it will probblay go up for sale soon
in background .. bad pict
Old 12-18-2002, 05:07 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
Jaxx: ej22? From a RHD?
Old 12-18-2002, 05:45 PM   #16
HomeSlice
Member#: 6081
MY93 Legacy
Sonora Sand ej22t
those pics made me mess up my pants-----"Thats not chowder!"
HomeSlice is offline   Reply With Quote
Old 12-18-2002, 11:00 PM   #17
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
EJ20G from a 89-93 RHD Legacy RS
exactly what is pictured above
220 PS
closed deck
tdo4
425cc injectors
coil on plug
relitivily cheep $650 no harnees no ecu
i have a tec 2 that i am going to use ..
current prob is making it idle
it has a 3 wire stepper motor .. ?
Old 12-18-2002, 11:05 PM   #18
ciper
Member#: 15543
90BJ Legacy LS ABS
Yeah, combo stepper and metal "heat" spring. What about just setting it at a decent point, and let the metal spring take care of cold to warm transition? Your idle would be different based on the weather but still in a good range. I was playing with mine once, turning the valve by hand.
Old 12-18-2002, 11:40 PM   #19
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
Old 12-18-2002, 11:42 PM   #20
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
intersting idea....
i havn't taken it apart yet
not sure if that will be goo enough
might have to find a GM stepper motor to fit
Old 12-19-2002, 12:19 AM   #21
ciper
Member#: 15543
90BJ Legacy LS ABS
Man, the inlet on that looks very small and some weird bends. Forced induction may overcome this but still!
Here, old but might give you an idea.
http://www.chez.com/ciper/iac/iac.html
Old 12-19-2002, 01:51 AM   #22
warlord225
Member#: 24729
1993 Legacy gtb- sti
black wagon
yes, that tan coloured thing is the idle controll unit (the one with the 3 wires).
i see alot of these motors.
also the cars are suprisingly fast, but not as fast as our gtb
warlord225 is offline   Reply With Quote
Old 12-19-2002, 02:51 PM   #23
kotaro
Member#: 8256
Thumbs up
thanks a lot for all the answers and info
air/water intercooler thuynh2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-08-2003 11:30 PM
What the heck is this on his intake manifold? air/water intercooler?? STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-25-2003 01:27 PM
Air/Water intercooler install, any suggestions? BlueDemon South East Region Forum 3 08-25-2002 10:39 PM
Air/Water intercooler? FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-30-2002 12:45 AM
Interesting Air/Water intercooler thought Legacy GTR Normally Aspirated with bolt-on Forced Induction Powertrain 9 02-14-2002 12:53 AM
