Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Alaskan Impreza Club
Go Back   NASIOC > NASIOC Chapters > Alaskan Impreza Club Forum -- AKIC
Old 10-16-2011, 07:06 PM   #1
AK_GT
Member#: 275567
2010 WRX
Default Transmission stuck to the block??
Doing my clutch in the wagon, got all 8 bellhousing nuts/bolts off, axles out, driveshaft off, crossmembers disconnected, and STILL can't get the trans to separate... What am I missing?
AK_GT is offline   Reply With Quote
Old 10-16-2011, 07:11 PM   #2
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
My Other Ride's your MOM
You have to pull the clutch fork pivot pin/guide/arm thing. Look right in front of the slave cylinder. Look for a hex key hole ( looks just like a oil galley plug) .
Dirty_WRX is offline   Reply With Quote
Old 10-16-2011, 07:30 PM   #3
retrac
Member#: 217208
NO! That's a pull style clutch thing. LGT and 06+ WRX are push style.
You're probably missing force if it's never been separated. Don't forget the pitch stop (under the intercooler), shifter linkage and neutral & reverse switch wiring as well, since you didn't list that.
The locating pins are most likely stuck. I usually recommend pulling the motor for this reason, it's easier to apply force from above with everything out of the way.
Last edited by retrac; 10-16-2011 at 07:43 PM. Reason: Put location of pitch stop.
retrac is offline   Reply With Quote
Old 10-16-2011, 07:49 PM   #4
AK_GT
Member#: 275567
2010 WRX
Yep got the pitch stop, wiring, starter. Everything is loose, just not breaking free
Old 10-16-2011, 08:28 PM   #5
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Retrac is right... If you aren't pulling the engine you need two jacks, one under engine the other under the tranny so you can assust with seperation. Undo your mounts before you do
Racer Dubya is offline   Reply With Quote
Old 10-16-2011, 08:55 PM   #6
edo2000
Member#: 68709
2012 WRX
red
What Retrac and Dubya said. The aluminum bell housing sticks to the aluminum block pretty tight after a few years. There are alignment pins that tend to really want to stay engaged. I had to *gently* use a sharp chisel to initially start the two sides apart (02 WRX). Once I saw a small separation, I used PB Blaster at the alignment pins to help free it up. Use a little anti-seize on the pins when you reassemble. Good luck.
edo2000 is offline   Reply With Quote
Old 10-17-2011, 02:44 AM   #7
AK_GT
Member#: 275567
2010 WRX
Well 10 hours and the engine is still seized onto the trans. Pulled the motor up to see if that would do it but it's still stuck. I got aggressive enough to have the jack stands start shaking so im at a loss. I was thinking about using a gear puller where the starter goes and see if I can get the cases spread enough to get a chisel or pry bar between them. If not, motor and trans are coming out together and I'll beat the piss out of the trans on the garage floor. Talk about frustrating!
Old 10-17-2011, 01:03 PM   #8
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
and just how do you know this?
Nomadgene is offline   Reply With Quote
Old 10-17-2011, 02:13 PM   #9
AK SloPok
Member#: 56464
12 Ram
Mine was pretty stuck as well.... huge pry bar. I used a three footer and well placed jacks. Seamed like it would never come out, but it did.
AK SloPok is offline   Reply With Quote
Old 10-18-2011, 03:36 AM   #10
AK_GT
Member#: 275567
2010 WRX
Great Success! Got the trans down tonight. What a pain in the @$$!
and my secret tool to start separating the cases:
simply a 2/3 jaw puller, put a socket and extension on the end, insert into the starter opening and the jaws grab the outer ring of the opening. gently tighten, wiggle the motor, tighten some more until you can get a pry bar in the between the two. Worked pretty slick, only took us an hour after I rigged up the tool.
Old 10-18-2011, 11:02 PM   #11
edo2000
Member#: 68709
2012 WRX
red
^^ Good thinking! Way to move on with the job.
Old 04-08-2018, 09:09 PM   #12
Tygerfalcon
Member#: 484363
2008 Impreza WRX
Obsidian Black
I realize I'm revitalizing an old/dead thread but I'm having a similar problem on my 08 WRX. I'm hoping the OP could repost/pm the pictures of how they had the jaw puller set up. Thanks.
Tygerfalcon is offline   Reply With Quote
clutch stuck to the floor, not sure what to try. b0nd18t Transmission (AT/MT) & Driveline 5 07-01-2011 08:05 AM
What's funnier than a guy in a wheelchair stuck to the grill of semi? Sharkbait Off-Topic 52 06-08-2007 09:24 PM
clutch get's stuck to the floor kettsupp Transmission (AT/MT) & Driveline 2 07-25-2005 02:05 PM
Clutch pedal keeps getting stuck to the floor. powerlabs Transmission (AT/MT) & Driveline 9 07-06-2005 11:12 PM
Clutch stuck to the floor? grue Transmission (AT/MT) & Driveline 6 04-27-2004 05:56 PM
