Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 08-24-2015, 10:39 PM   #251
soobz
Member#: 394869
2015 WRX
WR Blue
I took a bit of a different approach to this, but same awesome result!
Parts and tools used:
Thule aeroblades 7603b and 7602b
Thule fit kit 3068
Body Panel Tool
Silver Sharpie
4.9mm brand new drill bit
Rivets(8)
Rivet Air Hydraulic Riviter
Air hose blower
E6000 Silicone
Brackets provided by Krazy
-This will just be a simple run through of my installation.
-This install required no removal of interior liner.
-Air compressor and hose required.
-Approximately 1.5hr install time
Step one:
Removed gutters from vehicle using instructions provided by Advan-Emotion.
Step two:
Aligned Krazy brackets to where i would want them placed and marked the holes with a silver sharpie. I had to place the brackets just a little offset in the gutter towards the outside of the car in order to have the thule feet sit properly. I went with a 31 inch bar spread.
Step three:
DRILL! Drilled with a 4.9mm brand new drill bit. right through the middle of my sharpie mark. The bracing underneath is quite thick! Be patient with it and let the drill do its work. Be very careful not to let the drill fall through when you are all the way through the metal. After all the holes are drilled, using an air hose connected to an air compressor and an air blower attached to the hose, blow the metal shavings off the car. This creates a layer of air under the shavings and prevents it from scratching your paint!
Step four:
The hard part is over. Now with the holes drilled, grab some e6000 silicone and put a nice sized blob on the back of the krazy brackets and also on the rivets. align the brackets with your drilled holes and put the rivets in. Now with your hydraulic air riviter impact the rivets through the brackets and boom! thats it! If you want, you can add another blob of silicone on top of the brackets to be safe from moisture.
Step 5:
(Sorry no pics of this process) Align the gutters back on and with a sharpie mark the center right above the brackets middle hole. Now with the same drill bit used in the steps before drill through your sharpie hole in the gutter. Use a larger drill bit and little by little drill larger until your hole lines up perfectly with the brackets. once your holes are all lined up insert the gutters back in with the factory clips (Note: I had to use 2 less clips on each side because brackets were in the way). insert long bolt through gutter and tighten with tool provided in the Thule 3068 kit.
Step 6:
Attach bars to thule feet (Instructions provided in kit). Tighten everything down, put the covers on, lock it down and you're done!
Super happy with the results!! Looks much cleaner than clip on racks and much sturdier too. The Thule Aeroblades are awesome and basically no wind noise at all! I plan to use these for a cargo box and snowboard racks for the winter. Thanks for reading! PM me any questions you may have.
PS: Will take more(and better) photos in the next few days
soobz is offline   Reply With Quote
Old 08-25-2015, 12:00 AM   #252
krazy
Member#: 56400
2004 Subaru STi-SOLD
custom roofrack brackets!
^that is a great way of doing it. Never imagined it with rivets. Awesome man! Glad my brackets are working out for the 2015 owners!
krazy is offline   Reply With Quote
Old 08-25-2015, 12:21 AM   #253
earthwormjim
Member#: 393824
1.5 hours for install?!?!? You win the internet today
earthwormjim is offline   Reply With Quote
Old 08-25-2015, 02:11 AM   #254
soobz
Member#: 394869
2015 WRX
WR Blue
Thanks! The brackets are awesome and I highly recommend anyone looking to get a rack to get some from Krazy.
Install time was quite short. There's not much to it. No removal of interior or anything too time consuming.
Old 08-25-2015, 02:37 AM   #255
Smokeitd2
Member#: 391773
2015 Subaru WRX
Ice Silver Metallic
Worried about rain or is it pretty sealed ?
Smokeitd2 is offline   Reply With Quote
Old 08-25-2015, 11:56 AM   #256
bunz559
Member#: 388585
2015 wrx base
ISM
That is awesome! Great addition to this thread to help future installers. I wanted these for the clean look but was not sure of the size so I went with the regular aeroblade bars and 3068 Podium fit kit. Great job with the rivet idea too!
And that was a fast install for you! You must have experience or studied the install and had much confidence going in. It took me an entire day! LOL!
bunz559 is offline   Reply With Quote
Old 08-25-2015, 02:37 PM   #257
earthwormjim
Member#: 393824
Ditto even just the drilling was a saga !
Old 08-30-2015, 06:30 PM   #258
quarderpounder
Member#: 429158
2015 WRX
Dark Grey Metallic
Hey guys. I'm trying to install my rack now. Does anyone know a trick to remove the C-pillars? Having a tough time with it.
quarderpounder is offline   Reply With Quote
Old 08-31-2015, 01:09 AM   #259
quarderpounder
Member#: 429158
2015 WRX
Dark Grey Metallic
Hey guys, scratch that. I got the C pillars off fine.
Also.... Just completed my install!!! Will post pics tomorrow. So psyched.
Thanks guys for posting so much good info about this. You're saints!
Old 09-04-2015, 10:35 AM   #260
Agri-yob
Member#: 423764
Hey Soobz,
Nice Post. You have solved the headliner problem. that was the only thing that was stopping me from this install. Im close to ready to do the damn thing now! just a couple of questions...
What size rivets did you use?
how confident are you in the strength of the bracket using rivets instead of bolts?
Agri-yob is offline   Reply With Quote
Old 09-04-2015, 11:14 AM   #261
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
Instead of rivets, I would use RivNuts.
Old 09-08-2015, 11:10 PM   #262
soobz
Member#: 394869
2015 WRX
WR Blue
I've had better experience using rivets over rivnuts. they have a stronger seal, especially when using a hydraulic riviter. But either way rivnut or rivet will do just fine !
Old 09-11-2015, 02:04 PM   #263
JimmyJames333
Member#: 429426
An air fairing might look good too.
JimmyJames333 is offline   Reply With Quote
Old 09-11-2015, 05:02 PM   #264
bunz559
Member#: 388585
2015 wrx base
ISM
Damn! I need to find someone with an air rivet tool. I really want to redo it with rivets now.
Old 09-25-2015, 03:06 PM   #265
tiphie
Member#: 422144
2015 WRX
World Rally Blue
Well worded and put!
tiphie is offline   Reply With Quote
Old 09-26-2015, 09:09 AM   #266
Skeeterone2
Member#: 239849
Thule fit kit 3068
Body Panel Tool
Silver Sharpie
Rivets(8)
Air hose blower
E6000 Silicone
Step one:
Step two:
Step three:
Step four:
Step 5:
Step 6:
What size rivets did you use and what are they made of? Thank you.
Tim
Skeeterone2 is offline   Reply With Quote
Old 10-02-2015, 04:48 PM   #267
just slothing
Member#: 391935
2015 wrx
Tim
Has anyone noticed small dents in their roof after installing a roof rack? I am 100% that there is no contact from what I'm carrying (cargo box). I transported about 100 lbs of stuff from storage in a cargo box and today I noticed there are three small dents, well away from where the foot pads contact my roof. I noticed this in my 2011 WRX while carrying my kayak with Yakima control towers although it was much worse. Just wondering if this is a result of me overloading the roof or over tightening the rack attachment points. Any insight appreciated.
just slothing is offline   Reply With Quote
Old 10-12-2015, 11:42 AM   #268
chipsterguy
Member#: 431577
Originally Posted by phunki View Post
I'd like to thank everyone that put this post together. I was going to write up my own account of the process, but after going through the original instructions I realized there wasn't much to add. I went with the Thule rack and love it.
Phunki, I noticed that you have the limited with the moon roof. Any additional complications or tips on removing the headliner when the moon roof is there? Thanks, I hope to do this soon on my 2016 STi~
chipsterguy is offline   Reply With Quote
Old 10-14-2015, 03:52 AM   #269
Ftheref187
Member#: 429596
2016 WRX
Crystal Black Silica
Just ordered the brackets from krazy and I'm going to try this my next day off. Do you think a regular rivet gun would work or should it be the air rivet gun? I like the rivet idea since it sounds like the longest part so far is removing the headliner
Ftheref187 is offline   Reply With Quote
Old 10-14-2015, 02:25 PM   #270
chipsterguy
Member#: 431577
Ordered the brackets. Will consider riveting to avoid removing the headliner on my limited with moonroof.
Old 10-14-2015, 02:26 PM   #271
chipsterguy
Member#: 431577
The install shops I've checked use rivets.
Old 10-14-2015, 02:28 PM   #272
chipsterguy
Member#: 431577
However, any concerns about metal shavings remaining in the headliner? Possible negative effects on side curtain airbags?
Old 10-14-2015, 06:05 PM   #273
earthwormjim
Member#: 393824
Put tape on underside of holes. Non issue if you aren't a hack
Old 10-15-2015, 02:21 AM   #274
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
Default 15 WRX factory roof rack mount installed, yea I drilled it !
Originally Posted by nodrog321 View Post
Props to you guys for drilling into your roofs.. I have a clip style roof rack I want to put on. Wondering if anyone put some clear vinyl between any contact points of the car and the clips/rack to prevent damage? or is this way the best way to prevent damage?
I have 3M paint protection film underneath where the feet of my Inno roof rack feet would meet the paint. I also used a sharpie to mark the placement of the feet for faster installation instead of having to measure everything out each time.
Not close-up enough to see it...
skeeter281 is offline   Reply With Quote
Old 10-21-2015, 11:06 AM   #275
chipsterguy
Member#: 431577
Rivets are cool because you don't remove the headliner. Anyone concerned about doing this install with rivets... Drilling the roof first, of course, but leaving behind more metal shavings in the roof liner? Possible ill effects with the integrity of the side curtain airbags? Just wondering everyone's thoughts on this...
