Welcome to the North American Subaru Impreza Owners Club Wednesday December 19, 2018
Old 09-05-2017, 09:24 PM   #301
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Were like tiny garage twinzies
no694terry is offline   Reply With Quote
Old 09-08-2017, 10:54 PM   #302
lodown1
Member#: 200596
98 Forester 3.0R
Yep, that looks about right!! I really didn't mind the small space most of the time.
lodown1 is offline   Reply With Quote
Old 09-10-2017, 05:42 PM   #303
lodown1
Member#: 200596
98 Forester 3.0R
Still need to get some video action for you guys, was at friends place to get weights and corner balance.
Here is my official new weight, and balance I've manages to move about 5% of the weight rearward and take out around 500lbs
And a nice shot of the undercarriage, with it up on the lift.
Old 10-21-2017, 10:31 PM   #304
lodown1
Member#: 200596
98 Forester 3.0R
Have been meaning to upload this video sooner,
Old 10-22-2017, 12:52 AM   #305
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
That lot is ginormous - where is that?
Old 10-22-2017, 12:57 AM   #306
sdunlimited
Member#: 179162
2005 Saab 92x Aero
Silver w/RallyArmor flaps
Thanks for posting the vid. That was quick and sticky!
sdunlimited is offline   Reply With Quote
Old 10-22-2017, 10:05 AM   #307
lodown1
Member#: 200596
98 Forester 3.0R
That is the parking lot at the Z-Max dragway up in Concord NC
Old 11-09-2017, 02:56 PM   #308
webberjames95
Member#: 417695
moarrrrrrrrrrrrrrrr
webberjames95 is offline   Reply With Quote
Old 01-22-2018, 07:16 PM   #309
kos
Member#: 118334
2006 Carmine Red WRX
2005 Aspen White RS
Damn this is NUTS.
kos is offline   Reply With Quote
Old 01-23-2018, 09:48 AM   #310
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Originally Posted by lodown1 View Post
Updated STI damper with some threaded sleeves and springs, front is a 250lb/in rear is the progressive from the KW V3 set, so somewhere around 220lb/in. Sleeves are from all-stars, After removing the stock spring mounts I welded some stops 7" down where the sleeves could rest. These sleeves are slightly larger than 2in so i used some rubber o-rings to remove the slop and keep them nice and tight. Also took the chance to put some new paint on them.
For these I will use the OEM STI top mounts, this set should give me idea of what spring rates i would like to run with the KW V3's that I need to get rebuilt.
you notice any ill effects of welding to the struts, like oil boiling out odf the seals or anything? I turned my foz into a tube truck and need something like what you made here
Old 01-28-2018, 07:35 PM   #311
lodown1
Member#: 200596
98 Forester 3.0R
No ill effects when you use the STI dampers, they are inverted monotone so all you are welding to is just the metal shells.
Winter has been quite and car has not gotten much use, due to what sounds like some rod knock, which means I need to move quicker my engine rebuild plans. Still deciding between a high comp. NA ~13.0:1 or a 10.7:1 turbo build.
Old 02-04-2018, 08:57 AM   #312
Master467
Member#: 459849
2002 Legacy GT
89N (titanium pearl)
Check the dipstick for metal flakes? If not it could be a tensioner or exhaust leak, i've seen a few "rodknocked" motors without any bearing failure.
Compression without good flowing heads won't make much power. Get those things ported. See if delta will regrind your cams. Even stock compression would make some good numbers N/A with cams and head work.
Master467 is offline   Reply With Quote
Old 02-05-2018, 08:44 PM   #313
lodown1
Member#: 200596
98 Forester 3.0R
Yeah, I have not confirmed its actually rod knock but there is a noise i don't like. I did an oil change recently and didn't really see any metal flakes.
Otherwise everything i have heard/read about the heads is that they flow pretty well, cams are definitely a sticking point, with the variable lift system no one want to do them at least not for anything less than 2500. Its one reason (among many) that adding boost is much easier on this motor. Like I said i am still in the debating stage, part of the high compression NA is a desire to put one in a BRZ. 350 HP NA in a brz with the sound this motor makes would be quite a nice thing.
Old 02-06-2018, 11:35 PM   #314
04trailsti
Member#: 179170
James,
Well I cant believe I actually found your build thread. I was the tall guy working grid at that last ZMax event that was drooling over the fozzy. Im going to loose sleep now because Im going to go back and read it from page one.
To anyone that thinks this is an awesome build... Its event better in person and the videos do NOT do the exhaust note justice. Keep up the awesome craftsmanship
04trailsti is offline   Reply With Quote
Old 09-06-2018, 05:59 PM   #315
Master467
Member#: 459849
2002 Legacy GT
Six month update?
Forester/STI suspension parts from SPT? JSR Brakes, Steering & Suspension 1 04-28-2006 10:08 AM
JDM Forester STi Suspension DanzBorin Forester Forum 9 08-09-2005 10:01 AM
JDM Forester STi Suspension DanzBorin Private 'For Sale' Classifieds 2 07-29-2005 12:04 PM
Forester STi suspension installed Peaty Forester Forum 6 06-06-2005 10:55 AM
03 RS to 98 Forester shifter linkage swap?? jonnysubby Transmission (AT/MT) & Driveline 2 04-17-2005 11:29 PM
