Welcome to the North American Subaru Impreza Owners Club Wednesday December 19, 2018
Old 08-21-2018, 08:49 PM   #1
hegasports
Member#: 88988
05 9-2x
Default Jdm ej205 avcs usdm ecu
If i swap the crank and cam gear in my 2005 92x to run usdm ecu so i can pass nj emissions, will i be able to plug in the jdm ecu without putting back the jdm crank and cam gear? I feel like i already know the answer to this but I just realy need the conformation.
Thanks in advance.
hegasports is offline   Reply With Quote
Old 08-26-2018, 09:36 PM   #2
snow_bound26
Member#: 395793
2005 92x Aero
You'll need the JDM sensors and cam gear to run it on the JDM ecu and run avcs. You can run the engine on the US ecu without changing anything on the engine and just have it tuned for emissions purposes. It's what I did with my JDM 205 swap and I haven't had any problems. I use the JDM ecu primarily and the IS ecu one day of the year to get to and from the inspection.
snow_bound26 is offline   Reply With Quote
