Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Flatirons Tuning
Old 06-18-2016, 01:15 PM   #1
FlatironsTuning.com
Vendor Sales Rating: (25)
Member#: 171650
Rally Stuff MAP DCCD Controller install on CAN-Bus Subaru - RPM and Speedo
I just wanted to throw up a quick post as I searched and had a heck of a time finding an answer to this.
Basically, we put a 6MT into our 2014 WRX and we needed the tach/rpm signal and speedo signal to get the MAP DCCD to function fully. Since the car uses a CAN-Bus, those two signals don't go directly to the ECU, but instead are routed to the Cluster instead.
But you can get these two signals. If you look at the wires that come out of the cluster, pins 31 and 32 are what we needed. The RPM was a gray wire with a red stripe in pin 32, and the speedo was a pink wire with a green stripe.
These can also be accessed behind the radio as the bundle of wires heads down that way. Though you will have to find the correct wire group, and dig through until you find those two wires.
Hope this helps!
__________________
[CENTER][SIZE=3][COLOR=navy][B]303.402.5142
[/B][/COLOR][/SIZE][/CENTER]
[CENTER][B][FONT=Arial]Contact us at:[/FONT][/B][/CENTER]
[CENTER][SIZE=3][B]
[/B][/SIZE][/CENTER][U]
[/U][CENTER][B][SIZE=3]
[/B][/size]
[/CENTER]
FlatironsTuning.com is offline   Reply With Quote
Old 09-22-2017, 01:49 AM   #2
immortal
Member Sales Rating: (1)
Member#: 408776
15 WRX EFR 7064
Misread year
immortal is offline   Reply With Quote
Old 12-08-2017, 03:52 PM   #3
555ACKNASTY
Member#: 476835
2010 WRX Sedan
Grey
Hope this helps!
Awesome write up. Do you know if this is true for a 2010 Wrx as well? setting up with DCCD Pro soon.
Thank You
555ACKNASTY is offline   Reply With Quote
Old 04-07-2018, 01:11 PM   #4
13jerm
Member Sales Rating: (2)
Member#: 104764
2002 WRX Wagon
WR Blue Pearl
Cool
You guys are the best! Thanks FlatironsTuning.com
13jerm is offline   Reply With Quote
