04-23-2016, 03:17 PM | #7951 |
Member#: 440947
NWIC
Vehicle:2006 impreza wrx cgm |
mishimoto radiator
04-23-2016, 07:25 PM | #7952 |
Member#: 273896
BAIC
Vehicle:2015 Impreza Sport Black |
Swapped out the steelies for some wrx rims
I've had sitting around from another project. Before: After: ...only to find out two tires were flat |
04-23-2016, 08:54 PM | #7953 |
Member#: 182577
NWIC
Vehicle:2013 sti ISM |
Million times better, i hate steelies.
Just did an oil change. |
04-27-2016, 12:32 PM | #7954 |
Member#: 57586
NWIC
CNT catted DP, Grimmspeed EBCS, & a re-tune!
04-27-2016, 05:53 PM | #7955 |
Member#: 345550
NWIC
Vehicle:2016 WRX World Rally Blue |
Washed off a giant cup full of dip spit that some d bag decided to dump onto my car while at the gym. Thanks to whomever that was!
04-27-2016, 06:54 PM | #7956 |
Member#: 191476
NWIC
Vehicle:2005 2.5RSTi 2003/4 2.5TS |
04-27-2016, 07:19 PM | #7957 |
Member#: 345550
NWIC
04-27-2016, 07:27 PM | #7958 |
Member#: 441204
Clutch
I just got done putting my ej257b in my 02 wrx. Got everything all hooked up. But come to find in the end that my clutch will not engage.. I just replaced the stock TOB with a OEM Exedy replacement. I slipped the Exedy onto the input shaft, attatched my fork to it along with the rod and hex nut. Once I mated the trans to engine and bolted it together, I shifted the fork towards the firewall and heard it click into the flywheel. Everything was done right but yet my clutch pedal will only move 1/2"-1" assuming it's not engaging whatsoever. What could be the problem.?
04-28-2016, 01:05 AM | #7959 | |
Member#: 273896
BAIC
Dude... Sounds like the most frustrating part is having to take out the engine again...I'm afraid that once I finish my head repair, the same things going to happen to me... |
04-29-2016, 12:23 AM | #7960 |
Member#: 328399
NWIC
Vehicle:2012 WRX Limited OBP |
Got a new killer b oil pan after botching an oil change by forgetting to pull the old crush washer off the drain plug
04-30-2016, 11:17 PM | #7961 | |
Member#: 3409
NWIC
Vehicle:98 My FMIC Is bigger than yours. |
05-01-2016, 08:18 PM | #7962 |
Member#: 331131
NWIC
Vehicle:2001 2.5RS-T Silver..thorn Metallic |
05-03-2016, 03:11 AM | #7963 |
Member#: 211299
NWIC
Vehicle:2005 STi going into 2001 gc |
Off topic, but anyone know anything about this car?
http://seattle.craigslist.org/see/cto/5551815723.html |
05-03-2016, 04:55 PM | #7964 |
Member#: 328399
NWIC
Don't know the car but there are some red flags. Definitely not enough pump or injectors for the claimed numbers
05-03-2016, 05:04 PM | #7965 |
Member#: 182577
NWIC
Those numbers might be poosible with e85... definatly not pump with 850 injectors
05-05-2016, 03:07 PM | #7966 |
Member#: 441204
Thanks man I appreciate the reply! I vacuum bled it while unbolted with the bleeder at it's highest point and boom I got it. But now I got electrical issues... No power whatsoever including Accessories. My battery reads 12.2v .. A little oxidation on the grounds but I don't think it would be enough to cause any problems. All my fuses/Relays are good for the exception of SBF5 but that shouldn't effect my accessories from what I've been reading. My next step is to check if my Ignition is getting voltage. After that idk where else to look.
05-05-2016, 03:12 PM | #7967 |
Member#: 441204
05-05-2016, 06:02 PM | #7968 | |
Member#: 307270
NWIC
Vehicle:2002 WRX WRB |
12.2v isn't the worst you could be at, but it's definitely not the best. 12.6 or more is where a good battery should be at. How old is it? If it's a flooded battery, a hydrometer might be a good investment. I agree though, 12.2v is absolutely enough to be powering accessories. |
05-05-2016, 10:34 PM | #7969 |
Member#: 158695
NWIC
Vehicle:2013 GVF STi World Rally Blue |
Sneak peek.
05-05-2016, 11:53 PM | #7970 |
Member#: 430918
NWIC
Vehicle:2003 WRX WRB |
05-07-2016, 01:28 AM | #7971 |
Member#: 431617
W. Canada
Vehicle:2005 Impreza RS Silver |
Swapped '05 RS front seats and 16" rims into my '93 LS.
05-08-2016, 05:31 PM | #7972 |
Member#: 328769
NESIC
Vehicle:2005 WRB WRX 2007 UGM 2.5i |
Finished up painting the headlight insides on the hawkeye, love how it came out
05-08-2016, 10:05 PM | #7973 | |
Member#: 3409
NWIC
I'd go fishing for voltage, looking for drop... Wait. SBF5 is kinda important. Did it pop? MB-9 (circuit that SBF-5 powers) feeds the main relay, fuel pump relay, ECM, and power at the DLC. You're right, it shouldn't kill power to your accessories though. Last edited by CosmoTheCat; 05-08-2016 at 10:35 PM. |
05-14-2016, 08:28 PM | #7974 |
Member#: 410227
NWIC
Vehicle:2002 Wrx WRB |
05-17-2016, 10:34 PM | #7975 |
Member#: 308167
NWIC
Vehicle:1998 Impreza L Black |
well that was fun |
What did you do to your Subie Today? Version 3 | TrickNipple | North West Impreza Club Forum -- NWIC | 3796 | 09-07-2011 02:52 AM |
What did you do to your Subie Today? Version 2 | Smoke | North West Impreza Club Forum -- NWIC | 1978 | 05-21-2010 12:43 AM |
What did you do to your Suby today? | BREWPUBEAVER | North West Impreza Club Forum -- NWIC | 1197 | 11-01-2009 12:06 PM |
What did you do to your subie today?! | 07imprezadrifter | General Community | 277 | 06-14-2009 11:42 PM |
