Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Old 01-18-2016, 11:20 PM   #76
PhillyPhan90
Member#: 351013
2006 WRX TR
Crystal Gray Metallic
This is amazing. Been looking for something like this for weeks now. Finally found it! Though, unfortunately, I can't see the photos on the first page of this post.
PhillyPhan90 is offline   Reply With Quote
Old 01-18-2016, 11:28 PM   #77
turboimpreza07
Member#: 89703
1994 Impreza
Acadia Green
turboimpreza07 is offline   Reply With Quote
Old 01-27-2016, 01:34 AM   #78
SR 25 RS
Member#: 97983
2017 STi
FYI - gasket kids do not come with this bad boy :/ (from a GR STi)
SR 25 RS is offline   Reply With Quote
Old 03-27-2016, 10:18 PM   #79
Larouche97
Member#: 434697
2007 Wagon 2.5i/rs
Urban gray metallic
Wooow amazing
Larouche97 is offline   Reply With Quote
Old 04-03-2016, 06:06 PM   #80
Mitchrod1
Member#: 443988
2002 wrx
What is that gasket?
Mitchrod1 is offline   Reply With Quote
Old 05-18-2016, 06:44 AM   #81
tenzhushoten
Member#: 447054
Very useful info. I bought a 2005 STi recently. It's running smooth. A friend of mine has blown engine in its STI. He wants to sell it to me. I'm thinking for buying it and rebuilding the engine. Thanks bro !
tenzhushoten is offline   Reply With Quote
Old 06-09-2016, 05:16 PM   #82
Braz
Member#: 64273
2005 STi
CGM
Thread deserves a sticky. And new pics!
Braz is offline   Reply With Quote
Old 10-24-2016, 10:06 PM   #83
BuiltSubaru
Member#: 457044
Originally Posted by 2phless View Post
I just picked up my master gasket set and it had a factory seal. The last one I got had been pilfered. I'd ordered it from out of town and had a bear of a time ID-ing all the orings that I was missing. That messed up kit, however, came with a parts list (this one didn't) so I went through this one with the list and tried my best to identify all the parts using real-live english words instead of the suba-reviations from the list.
If anyone can fill in any of the blanks. I'm not 100% sure what everything is. I might have gotten rid of some of these o-rings when I swapped for aftermarket parts... or I left a part intact during the rebuild and didn't find that gasket...
Anyway. I hope this helps someone sometime. Have pictures I'll try to add too.
Gasket set part number 10105AA590 Gasket & Seal Kit - ENG
My list key
list number/part number/ part name/ quantity/ what it is or where it goes.
1 / 803928010 / GSKT-28.2x33.5x1 / 3 / silver seals for the 14mm allen block access bolts
2 / 806786040 / OIL SEAL-86x103x10 / 3 / Rear main seal. Why 3? I don't know.
3 / 10991AA000 / O RING-CYL BLOCK / 4 / 3 between block halves. 1 behind oil pump. ** Looks similar to pt # 11 **
4 / 806931020 / O RING-31x2.0 / 1 (but came with 2) / #4 wrist pin access cover gasket (hidden by flywheel)
5 / 806932030 / O RING-32.6x2.7 / 1 / ???
6 / 11034AA000 / WASH-CYL BLK SLNG 6 / for the 6 internal 12mm 12 point block connecting bolts that contact oil.
7 / 11044AA641 / GSKT-CYL HEAD / 2 / Head gasket pair.
8 / 803912040 / GSKT-12x16x1 / 14 / Copper bango bolt washers (except for the turbo oil feed)
9 / 806910170 / O RING-10x2 / 2 / 2 orange gaskets for the bottom of the dipstick tube.
10 / 806917070 / O RING-17.4x2.4 / 1 / oil fill tube to LH valve cover
11 / 11122AA000 / SEALING-OIL PAN / 1 / This goes between the oil pump pickup and block. ** Looks similar to pt # 3 **
12 / 11126AA000 / GSKT-DRAIN PLUG / 1 / A crush ring for the drain plug. Nice of them huh?
13 / 805323040 / CIRCLIP-INR 23 / 8 / Wrist pin circlips
14 / 806742160 / OILSEAL-42x55x8 / 2 / Intake cam seals
15 / 806732160 / OILSEAL-32x55x8 / 2 / exhaust cam seals
16 / 13091AA050 / SEALING-TENSIONER / 2 / *** These are the rubber or foam stickies on the tensioner *
17 / 13091AA060 / SEALING-TENSIONER / 2 / * mount plate that keep dust out of the timing belt area *****
18 / 806939040 / O RING-39.4x3.1 / 2 / AVCR intake cam oil covers (the triangular covers held to the front of each intake cam sprocket by 3 philips/8mm bolts)
The next several part numbers are fairly unidentifiable. They are the foam stickies or rubber edges that seal the
timing chain covers.They have no dimentions or valid descriptions. They either have obvious spots or don't. I've
used RTV for the wishy washy areas before.
19 / 13581AA050 / SEALING-BELT CVR FR / 1 /
20 / 13594AA000 / SLNG-BELT COVER, 2FR / 1 /
21 / 13583AA260 / SEALING-BELT CVR RH / 1 /
22 / 13583AA270 / SEALING-BELT CVR / 1 /
23 / 13583AA280 / SEALING-BELT CVR / 1 /
24 / 13583AA290 / SEALING-BELT CVR RH / 2 /
25 / 13584AA050 / SLNG-BELT COVER, 2RH / 1 /
26 / 13597AA020 / SEALING-BELT CVR / 1 /
27 / 13597AA031 / SEALING-BELT CVR / 1 /
See?
28 / 13592AA011 / MOUNT-BELT COVER / 7 / Snap in rubber coated metal spacers for the t-cover-to-block bolts.
29 / 13207AA050 / SEAL-INT VALVE / 8 / intake valve seals (green???)
30 / 13211AA050 / SEAL-EXH VALVE / 8 / exhaust valve seals (black???) I haven't checked the difference yet.
31 / 13210AA020 / COLLET-VALVE / 32 / Small metal wedges. Dip concave side in thick grease to stick to valves during install.
32 / 13270AA190 / GSKT-ROCKER COVERRH / 1 / Right valve cover gasket.
33 / 13272AA140 / GSKT-ROCKER COVERLH / 1 / Left valve cover gasket.
34 / 13293AA050 / GSKT-ROCKER CVR,2 / 4 / Spark plug hole gaskets
35 / 806733030 / OIL SEAL-33x49x8 / 1 / oil pump to crank seal (front main)
36 / 15048AA001 / SEALING-OIL PUMP / 2 / More rubber pads for timing chain dust control.
37 / 806922040 / O RING-22.1x3.5 / 1 / This may be the recirc valve kneck o-ring
38 / 803942010 / GSKT-42x51x8.5 / 1 / Oil fill-tube cap gasket. (This was a puzzler the first time I saw one)
39 / 21114AA051 / GSKT-WATER PUMP / 1 / Water pump gasket. (Coated Metal)
40 / 21116AA010 / SEALING-WATER PUMP / 1 / And another rubber dust gasket for timing chain area.
41 / 21236AA010 / GSKT-THERMO / 1 / Thermostat gasket. Inner rib snaps around radius of the thermostat.
42 / 21370KA001 / GSKT-OIL COOLER / 2 / Orange and 1 goes between oil cooler and block. #2 included for backup?
43 / 806959030 / O RING-59.6x2.4 / 1 / Blue??? Not sure where it goes.
44 / 806932040 / O RING-32.0x1.9 / 1 / Orange and goes between the two block halves.
45 / 14035AA421 / GSKT-INT MANIF / 2 / *** One of these is the intake to tumblers *
46 / 14075AA160 / GSKT-INT COOL / 2 / * and the other is Tumblers to heads ******
47 / 16608AA040 / SEAL-FUEL INJ / 4 / Lumpy fuel injector seats
48 / 16698AA050 / O RING-INJECTOR / 4 / Lower small diameter injector o-rings ???
49 / 16698AA060 / O RING-INJECTOR / 4 / Upper large diameter injector o-rings ??? (or reversed)
50 / 14038AA000 / GSKT-EXH MANIF / 2 / head to exhaust manifold metal gaskets.
51 / 14022AA160 / GSKT-MF / 2 / Exhaust crossover gaskets? PN may be a typo as 44022AA160 was listed but I don't believe it.
52 / 803910050 / GSKT-10x14x1 / copper turbo oil feed banjo gaskets
53 / 16175AA241 / GSKT-THROT CHMBR / 1 / Blue paper throttle body gasket.
54 / 806933010 / O RING-33.7x3.5 / Water jacket crossover pipe to right and left blocks.
55 / 21896AA072 / GSKT - INTER COOLER / 2 / *** one pair is for the Y-pipe to TMIC, the other *
56 / 21896AA010 / GSKT - INTER COOLER / 2 / * pair is TMIC to recirculating valve. (2 why?) ****
Shew!
Quite the list you have there. I was thinking about a build similar to this one!
BuiltSubaru is offline   Reply With Quote
Old 10-24-2016, 10:06 PM   #84
BuiltSubaru
Member#: 457044
Curious to know whether or not you are going through with this?
Old 10-29-2016, 07:24 PM   #85
fire911
Member#: 243207
2006 Impreza
Platinum Silver
Default Did you build the goddam thing or not?
How did it turn out?
Any stats of power?
fire911 is offline   Reply With Quote
Old 11-05-2016, 05:22 AM   #86
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
Is it just me or are the pictures mia for everyone?
sub2010ss is offline   Reply With Quote
Old 11-15-2016, 10:08 PM   #87
1fstSTi
Member#: 103773
anybody have the part # for those half moon plugs that goes on the side of the heads?
1fstSTi is offline   Reply With Quote
Old 11-15-2016, 10:21 PM   #88
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
What year? What do they go to?
Old 11-16-2016, 03:54 PM   #89
1fstSTi
Member#: 103773
2005 JDM STi. It goes on the corner of the head, below the valve cover.
Old 11-27-2016, 12:06 PM   #90
omg3hdpk
Member#: 458830
Default master gasket set and it had a factory seal
omg3hdpk is offline   Reply With Quote
Old 06-15-2018, 11:56 AM   #91
Jput97
Member#: 487250
Default Been there before
Here we have the set of two huge orange o-rings. You only need one afaik between the oil cooler and the block. The two little ones somehow keep the dipstick tube from leaking where it hits the oil pan (that's magic to me 'cuz they are wiggly... but they don't leak) They threw in a crush ring. Preesh. And the odd, pointed on one side, flat on the other, thick black o-ring is for the yellow oil fill cap.
These are the 3 (of 4) black, shaped o-rings and the larger orange o-ring that go between the two block halves. When these are missing from a set, it can really hamper your day. The 4th black shaped o-ring of the same size goes behind the oil pump. There is a very similarly shaped black o-ring ( the different one in the middle here) that goes between the block and the oil pickup tube so squint a bit when you decide what is what:
Rear main seals. They give us 3. I think because they have no idea how to write instructions. The rear main seal DOES NOT GET DRIVEN ALL THE WAY IN. I got even better at pulling my motor because I did not know that the first time. Fortunately my DP was kind enough to send a smoke signal. "...you.... are... a... retard..." it seemed to say. The rear main should sit basicly flush with the block. Subaru "mechanics" use a tool. ( <--- that should be a t-shirt)
Been there before brother not a fun time 😂
Jput97 is offline   Reply With Quote
Pros/Cons of 2.0 JDM STI vs. 2.5 USDM STI engines TooSlow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 63 07-14-2017 08:23 PM
2.5 USDM STi short block KZ_Scoob Private 'Wanted' Classifieds 7 10-03-2015 04:32 PM
Axis Stage 2 vs. USDM STi 2.5 Chad W Built Motor Discussion 14 04-29-2007 11:40 PM
V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? saab-on-the-cobb Subaru Conversions 6 09-18-2006 07:03 PM
2.5 USDM STI Motor is strong! Race Tested! WorldOne Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 102 06-23-2004 12:42 PM
