10-01-2009, 12:33 AM | #1 |
Vendor Sales Rating: (24)
Member#: 156247
Vehicle:14' Flex Fuel FXT 15' Flex Fuel WRX |
Killer Savings on BC RACING Coilovers! [PERRIN] [StopTech] [Hawk] [DBA] [Whiteline]
We will meet or beat any price. Please PM all Tein Inquiries. StopTech Brake kits & Rotors: StopTech 04-07 STi front and rear SS brake lines StopTech 04-07 STi Stage 1 Brake Upgrade Kit StopTech 04-07 STi Stage 2 Slotted Brake Upgrade Kit StopTech 05-07 STi Stage 2 Slotted Brake Upgrade Kit Stoptech 08-09 WRX & STi Stainless Steel Brake Lines (4- line front and rear set Stop Tech Power Slot 05-07 STi Rear Rotors - PAIR Stop Tech Power Slot 05-07 STi Front Rotors- PAIR Stop Tech Power Slot 04 STi Front Rotors- PAIR Stop Tech Power Slot 04 STi Rear Rotors- PAIR Stop Tech Power Slot 02+ WRX Rotors - PAIR DBA - Crazy Low pricing on DBA - PM Us for a quote DBA 02-07 WRX Front Slotted 4000 Series Rotor DBA 02-06 WRX / 98-07 Impreza 2.5L RS Rear Slotted 4000 Series Rotor Also have the street version of the rotors! DBA 05+ STi (5x114.3) Front Drilled & Slotted Street Series Rotor DBA 05+ STi (5x114.3) Front Slotted Street Series Rotor DBA 05+ STi (5x114.3) Front Slotted 4000 Series Rotor DBA 05+ STi (5x114.3) Front Drilled & Slotted 4000 Series Rotor DBA 2004 STi (5x100) Front Slotted 4000 Series Rotor DBA 2004 STi (5x100) Front Drilled & Slotted 4000 Series Rotor DBA 2004 STi (5x100) Front Slotted Street Series Rotor DBA 2004 STi (5x100) Front Drilled & Slotted Street Series Rot DBA 05-07 STi (5x114.3) Rear Drilled & Slotted Street Series Rotor DBA 05-07 STi (5x114.3) Rear Slotted Street Series Rotor DBA 2004 STi (5x100) Rear Slotted 4000 Series Rotor DBA 2004 STi (5x100) Rear Drilled & Slotted 4000 Series Rotor Hawk Brake Pads Hawk 02-03 WRX HPS Street Front Brake Pad Hawk 02-03 WRX / 05-08 LGT HPS Street Rear Brake Pads Hawk 02-03 WRX Performance Ceramic Street Front Brake Pads Hawk 03-05 WRX Performance Ceramic Street Rear Brake Pads Hawk 03-05 WRX / 08 WRX HPS Street Front Brake Pads Hawk 03-05 WRX HPS Street Rear Brake Pads Hawk 06-07 WRX HPS Street Front Brake Pads Hawk 06-07 WRX HPS Street Rear Brake Pads Hawk HPS 04-08+ STI Front & Rear Hawk HPS 08-09 WRX Front & Rear Combos We'd like to present to you the following products starting with BC's most advanced coilover system yet: The BC Racing ER Series Coilovers Features: *External reservoir Mono-Tube shock design *30 levels of damping force adjustment, adjusts both compression and rebound separately *Twin Piston Design *Pillowball mounts and adjustable camber plates included (where applicable) *Adjustable rear camber plates available *Separate full length height adjustable *One year warranty *rebuildable Fitment - WRX / STI 02-08 PM US FOR SPECIAL INTRO PRICING!! BC Racing Inverted Coilovers Features- front camber plates front and rear pillowball mounts inverted struts front + rear 46mm piston, 53mm body 8k front 6k rear spring rate. Fitment: 02-07 WRX / STI and 08+ STI $1149 SHIPPED We also sell the all popular BC Racing BR Series Coilover Kit!! Features- The best coilover for the money, hands down! * 53mm Dampers (larger then the competition * fixed cup/locking collar design (unlike cheap coilovers will not change ride heights, change camber, and wear out your tires. * Full pillowball mounts front + rear * 30 way adjustable * optional rear extenders so you do not have to take out the rear seat every time to change the range on the dampers * Clicks when you turn the damper handle so you can keep track of position * 1 year warranty * $95 after the 1 year and you get a replacement Fits: 05-07 STI, 02-07 WRX - 08+ WRX/STI Megan Racing - Megan Racing Coilover Damper Kit Fits: 02-05 WRX - Megan Racing Coilover Damper Kit 05+ STI Fits: 05+ STI PM For pricing Swaybars Perrin 02-07 WRX/STi 25mm Adjustable Front Sway Bar Perrin LGT/08 WRX 22mm Adjustable Front Sway Bar Perrin LGT/08 WRX 25mm Adjustable Front Sway Bar Perrin 08-09 STi 25mm Adjustable Front Sway Bar Perrin 02-07 WRX/STi Front Strut Brac Perrin 02-07 WRX Rear End Links Perrin 08+ WRX / 08+ STi Rear Endlinks Perrin STi/04-08 Forester XT 25mm Adjustable Rear Swaybar Kit Perrin LGT 22mm Adjustable Rear Swaybar Kit Perrin LGT 25mm Adjustable Rear Swaybar Kit Perrin 08+ WRX / 08+ STi 19mm Rear Swaybar Perrin 08+ WRX / 08+ STi 22mm Rear Swaybar Perrin 02-07 WRX 22mm Adjustable Rear Sway Bar Kit Hotchkis 02-07 WRX Wagon Sport Swaybar Set - PM US Hotchkis 02-07 WRX Wagon Competition Swaybar and Endlink Set - PM US Hotchkis 02-07 WRX Sedan Sport Swaybars - PM US Hotchkis 02-07 WRX Sedan Competition Swaybar and Endlink Kit - PM US Hotchkis 02-07 WRX 25.4mm Competition Rear Swaybar and Endlinks - PM US Hotchkis 04-07 STi Sport Swaybar Set - PM US Hotchkis 04-07 STi Competition Swaybar and Endlink Set - PM US Hotchkis 04-07 STi Competition Rear Sway Bar & Rear Endlinks - PM US Hotchkis 02-07 WRX Sedan Front & Rear Endlink Set - PM US Hotchkis 04-07 STi Front & Rear Endlink Set - PM US Whiteline 02-07 Subaru WRX Sedan and Wagon / 03-07 Subaru Impreza Non-Turbo / 04-07 Subaru STi / 93-00 Subaru Impreza Non-Turbo 20mm Rear Swaybar mount-h/duty kit Whiteline 02-07 Subaru WRX 0Sedan and Wagon / 03-07 Subaru Impreza Non-Turbo / 04-07 Subaru STi / 93-00 Subaru Impreza Non-Turbo 22mm Rear Swaybar mount-h/duty kit Whiteline 04-07 Subaru STi Rear 24mm Swaybar-X heavy duty Blade adjustable Whiteline 04-07 Subaru STi Rear 22mm Heavy Duty Adjustable Swaybar Whiteline 08+ Subaru WRX Hatch / 08-09 Subaru STi Rear 20mm Swaybar-heavy duty Whiteline 08+ Subaru WRX Hatch / 08-09 Subaru STi Rear 22mm Swaybar-X heavy duty Blade adjustable (includes KBR15) Whiteline 08+ Subaru WRX Hatch / 08-09 Subaru STi Rear 20mm Heavy Duty Adjustable Swaybar (includes KBR15) Whiteline 08+ Subaru WRX Hatch / 08-09 Subaru STi Rear Brace-swaybar mount Introducing COBB SWAY BARS! Cobb 02-07 WRX/STi/FXT Tubular Front Swaybar - PM Cobb 02-07 WRX Rear Swaybar Kit Adjustable Mounts - PM Cobb 02-07 WRX Rear Swaybar Kit Standard Mounts - PM Cobb 04-07 STi Rear Swaybar Kit Standard Mounts - PM Cobb 08 WRX/STi Tubular Rear Swaybar - PM Cobb 05-08 LGT/08 WRX Tubular Front Swaybar - PM We specialize in Customer Service Excellence! Visit our NEW Website: www.theshopct.com Gerry Shoot me an email! [email protected] Paypal = [email protected] Call us at Phone#: 203-847-5791 We accept Visa And Mastercard via phone.
10-01-2009, 10:24 AM | #2 |
Member#: 156247
Good morning! Bump!
__________________
[COLOR=#ff0000] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | 203-856-9946 | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/COLOR] |
10-01-2009, 01:20 PM | #3 |
Member#: 156247
Afternoon bump.
__________________
10-01-2009, 07:36 PM | #4 |
Member#: 156247
We also sell TEIN!! We're up LATE!
__________________
10-02-2009, 10:13 AM | #5 |
Member#: 156247
Good Morning!
__________________
10-02-2009, 12:06 PM | #6 |
Member#: 156247
Bump!
__________________
10-02-2009, 11:48 PM | #7 |
Member#: 156247
Late night bumpski!
__________________
10-03-2009, 10:18 AM | #9 |
Member#: 156247
Good morning,
All PM's have been replied to.
__________________
10-04-2009, 10:59 AM | #10 |
Member#: 156247
bump.
__________________
10-04-2009, 09:23 PM | #11 |
Member#: 156247
Bump!
__________________
10-05-2009, 11:35 AM | #12 |
Member#: 156247
Good morning.
__________________
10-05-2009, 06:08 PM | #13 |
Member#: 156247
Bump.
__________________
10-06-2009, 09:30 AM | #14 |
Member#: 156247
Good morning!
__________________
10-06-2009, 02:10 PM | #15 |
Member#: 156247
Good afternoon!
__________________
10-07-2009, 09:39 AM | #16 |
Member#: 156247
Good morning
__________________
10-07-2009, 10:12 PM | #17 |
Member#: 156247
Bump.
__________________
10-08-2009, 09:30 AM | #18 |
Member#: 156247
Good morning
__________________
10-08-2009, 06:53 PM | #19 |
Member#: 156247
Bump.
__________________
10-09-2009, 10:14 AM | #20 |
Member#: 156247
Happy Friday everyone!!
__________________
10-09-2009, 03:59 PM | #21 |
Member#: 156247
Bump.
__________________
10-10-2009, 11:12 AM | #22 |
Member#: 156247
To the top
__________________
10-10-2009, 04:22 PM | #23 |
Member#: 156247
Bump!
__________________
10-11-2009, 11:44 AM | #24 |
Member#: 156247
Bump!
__________________
10-12-2009, 10:14 AM | #25 |
Member#: 156247
Happy Monday
__________________
Similar Threads | ||||
Bc Racing, Tein, Megan, stoptech, whiteline, hawk, DBA...UNBEATABLE Pricing+Service! | IMPORTIMAGE | Suspension/Brakes/Handling | 551 | 06-26-2010 04:59 PM |
OEM/Whiteline/Perrin/Cobb/Hawk/DBA and more | subaruwrxparts.com | Suspension/Brakes/Handling | 17 | 10-06-2009 02:32 PM |
Hawk/DBA/Whiteline/BC Racing/OEM and more at SubaruWRXparts.com | subaruwrxparts.com | Suspension/Brakes/Handling | 8 | 07-08-2009 02:48 PM |
We're back! Hawk/DBA/WHITELINE/BC Racing and more! | subaruwrxparts.com | Suspension/Brakes/Handling | 0 | 06-19-2009 10:43 AM |
Hot Deals on Hawk, DBA, Whiteline, Cusco, STI! | Annapolis Subaru | Suspension/Brakes/Handling | 13 | 12-15-2008 09:01 AM |
