Welcome to the North American Subaru Impreza Owners Club Thursday May 13, 2021
Old 12-30-2004, 04:57 PM   #1
underground-mpyre
Member#: 30351
1999 GC8 STI V7 6spd
Silver Coupe
OMGHi2U Tein suspension questions for the GC8
I am looking at getting a set of Teins for my GC8 coupe. I have heard the Sti, WRX and the GC8 2.5rs share the same struts? Is this true? I would also like to know if the rear struts are adjustable at the lower body like AGX KYB(which I have, or do adjust at the top(which would really suck)? If so probabley have to go with the EDFC unit. I need to be able to road course with them, is the a model for street and road course, or all the same? Any help is needed(except sarcasm).
underground-mpyre is offline   Reply With Quote
Old 12-30-2004, 05:34 PM   #2
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
yes, they are the same except the rear top hats. to use wrx ones, you would have to put gc rear top hats on the wrx coilovers
petawabit is offline   Reply With Quote
Old 12-30-2004, 05:40 PM   #3
underground-mpyre
Member#: 30351
Silver Coupe
Don't they make GC STI top hats for for the front and rear?
Old 12-30-2004, 06:49 PM   #4
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
you have to be specific with which teins you're getting. tein ra's, ha's, ss, flex, hg, rs, re?what exactly are you asking? no stock struts have adjustments on them. also, which sti are you talking about? why do adjustments at the top suck? the only reason they have adjustments where they do is mostly because of the shock design(inverted vs non inverted. if you're going to take them on a road course, you might as well just get pillowball top hats
Old 12-30-2004, 07:11 PM   #5
underground-mpyre
Member#: 30351
Silver Coupe
Well I really don't know the model design at all. Everybody I have talked to said to use the Teins. I need something from street to road course, which do you guys recommend. The rear adjustable tops, you have to remove your seat to adjust, whereas the AGX KYB can be adjusted underneath on the rear.
Old 01-01-2005, 04:28 PM   #6
underground-mpyre
Member#: 30351
Silver Coupe
Do have model info? Do they come with front adustable camber plates?
Old 04-17-2005, 12:57 PM   #7
revel
Member#: 62628
MY99 Ver6 Type R
aspen white
i am running WRX Tein Flexs with EDFC on my GC coupe. the WRX Flexs have both caster and camber adjustments so they offer the GC owner a little more adjustability at a cost-you have to trim the rear strut bar to fit the rear hats. kind of a pain, but well worth the added adjustment.
personally i wouldnt have anything else..........except Tein RAs or HAs.
revel is offline   Reply With Quote
Suspension question for the 18 millionth time MitchGT Legacy Forum 15 03-21-2005 02:56 PM
Suspension Questions for the 2000 Legacy Acejam2k Legacy Forum 6 10-15-2003 06:48 PM
The ultimate suspension setup for the GC8 Teh Legacy Brakes, Steering & Suspension 3 02-01-2003 02:01 AM
suspension question for the master techs: bushing differences between FWD/AWD? RaceCarRiot Brakes, Steering & Suspension 2 05-14-2002 09:08 AM
Another suspension question for the class gtguy Legacy Forum 3 11-06-2000 12:26 AM
