Welcome to the North American Subaru Impreza Owners Club Friday May 7, 2021
Old 09-19-2020, 06:23 PM   #1
BoostMasterZero
Member#: 337634
2013 WRX Sedan
308/339 -Tuned by Agile
Default Does anyone know how to turn off the Auto Start Stop feature?
I'm trying to help my mother out. She bought a brand new 2020 Subaru Outback and the center section by the radio is like one gigantic iPad. Everything is electronic with no knobs at all which isn't my style, but hey, it's not my car.
Anyways, I know how to switch over to one of the 3 bottom settings from the car, home, and personal settings. In the car settings, one of them I can turn off the Auto Start Stop feature which my mother hates, and i've driven the car before and I find it annoying as well, but then again my WRX was a stick, so that would never work on a car like that. Whenever I turn off the feature it stays off, but when I go to the local grocery store for example and lock it up and get back in and start it up and then come to a stop it automatically turns itself back on. I thought if I linked my mother's iPhone to the car and then re-applied my settings it would stick since the key fob is linked to the driver profile, but the Auto Start Stop feature still turns on automatically regardless of which key fob I use.
I figure this applies to anyone with an Outback, Forester, Ascent, or Legacy. I know WRX/STis don't have all this fancy touchscreen only stuff, at least they have some manual knobs lol
BoostMasterZero is offline   Reply With Quote
Old 09-20-2020, 12:43 AM   #2
GalaxyWide
Member#: 383291
2004 Forester XT
Cayenne Red
It is impossible to permanently disabled, due to fleet fuel economy numbers. Take it up with the EPA or California if you want it changed, we'll all sign the petition.
GalaxyWide is offline   Reply With Quote
Old 09-20-2020, 07:46 AM   #3
BoostMasterZero
Member#: 337634
2013 WRX Sedan
What is the point of the digital button to turn it on and off for? You mean no matter what I do in the settings, it will automatically just turn itself back on?
Old 09-26-2020, 03:59 PM   #4
engineertdog
Member#: 518914
If it's like Ford, then every time you turn the car on, you'd have to press the button to disable it. Not familiar with these newer Subarus, but didn't realize they had it as well.
engineertdog is offline   Reply With Quote
Old 09-27-2020, 02:01 PM   #5
Max Capacity
Member#: 149347
05 LGT ,09 SpecB
Black/silver
That is what I've read on the other Forums where people have asked the same question.
You need to turn it off every time.
Max Capacity is offline   Reply With Quote
Old 09-27-2020, 02:53 PM   #6
Samurai Jack
Member#: 21145
2002 Enemy of Aku
There is no way you are going to be able to permanently shut off that feature. The whole idea is to promote fuel savings by not having the engine running when you are stopped in traffic.
I've read where people have attempted to permanently shut it off by dicking around with the ECU / sensors.
The end result was they shut it off, but created a number of other issues with other systems in the car which are difficult to correct, if at all.
Old 09-27-2020, 04:14 PM   #7
JustyWRC
Member#: 153088
2005 Baja Turbo
95 Sambar 06 Forester
To be a little bit more accurate, it's the fact that an engine not running is not putting emissions into the air. Fuel savings is a nice byproduct of that.
And, no, as stated already, it cannot be permanently turned off. Gotta turn it off with every cycle of the ignition.
Old 09-27-2020, 07:52 PM   #8
curiousfish
Member#: 89283
2017 WRX Premium
ISM
This also goes for Ascent, Forester, Crosstrek, Legacy.....
curiousfish is offline   Reply With Quote
Old 09-28-2020, 09:15 AM   #9
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Pretend it's an electric car. You stop. Car shuts off. You want to go, you step on the gas and it starts and goes.
Now, I can see where if this were a Jeep Wrangler and you were trying to crawl over boulders and suddenly lose power, that's a problem. But for a street vehicle, just deal with it.
Old 09-28-2020, 09:46 AM   #10
GalaxyWide
Member#: 383291
2004 Forester XT
Cayenne Red
You can modulate the brake pedal to prevent it from activating, if you apply more or less pressure than the system is looking for it will leave the engine on. You can also cancel it at a stop by applying more pedal pressure.
Old 09-29-2020, 08:37 AM   #11
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You don't have to wait until you are at a stop. If you forget to cancel it at time of start up, you can cancel Auto Stop / Start at any time while driving.
Just don't look down and crash the car while doing so.
Old 09-29-2020, 01:19 PM   #12
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
If she has the latest software update (ending with 504) then at least it does make it a two step process instead of a three step process. That update also adds vertical CarPlay as well as fixes some connectivity issues.
No personal experience, but this company has an Autostop Eliminator that will remember the last setting. https://www.autostopeliminator.com/c...top-eliminator
The Forester version has been out for a while and the Outback version is new.
Modulating the brake pedal is for those that don't want to monkey around with the screen. My wife uses the brake method when she drives my car, although I agree that it's very easy to turn it off, especially now that it only takes two presses of the screen.
Old 09-30-2020, 01:13 PM   #13
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
Understand that touch screens do not work equally well for everybody, so the brake method may be the only way that works reliably for her.
The 'extreme weather' warning screen on our WRX almost never responds to me when I try to cancel it, so I've stopped bothering to try. And I've had touch screens lock up on me mid-word when signing in at a local medical facility, though the admin person could pick up and continue from where I got locked out with no difficulty whatsoever. Those are the recent ones.
It probably involves some body electrical thing, capacitance or resistivity, where the screen's electronics can't handle individual body values that are outside of the expected range(s).
Norm
Old 01-22-2021, 06:49 AM   #14
Tonga 1947
Member#: 466134
I just saw a video review on the 2021 Outback and the Stop/Start button on the screen was front and centre in between the home button and car icon. It must be a software update, anyone have info on this?? I want it as it will make life so much easier!!!
Tonga 1947 is offline   Reply With Quote
Old 01-22-2021, 08:14 AM   #15
rtv900
Member#: 428511
2016 STI
It's obviously not an EPA or regulatory thing because
a) some cars that have the feature can simply permanently disable it (jeep grand cherokee for instance)
b) most cars don't even have the feature at all
If it was regulatory every car would have it
Old 01-22-2021, 08:22 AM   #16
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Well it might be because the EPA test cycle was run with the system on, therefore it needs to be on by default or the fuel economy numbers are invalid.
Just a guess.
My CR-Z has auto-stop with a manual, at first it was disconcerting but I've gotten used to it. The implementation is actually quite good and restarting is seamless as soon as you put it in gear.
As for the '21 I highly doubt that an earlier model can be updated for that, you'd need to buy a new one.
Old 01-22-2021, 10:07 AM   #17
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
Engine Start-Stop a feature solely for MFR fuel consumption improvement then marketed to the consumer as a customer friendly feature.
It is not what I would say called for in regulation at the moment. As noted above, if the feature is active during emissions certification then it most certainly is involved and thus MFR can't allow permanent deactivation (only inconvenient temporary deactivation).
Eventually most if not all cars will have this feature someday. Features like this are not typically spread across all product platforms at the same time. Usually spreads to new product at re-design points and targeting areas that offer the most fuel efficiency credit (for the MFR). MFRs implement engine Start-Stop differently of course. So they can vary between seemless-ish to outright intrusive in operation. Sitting at a stoplight and some cars next to you are startling/distracting when the systems activates and deactivates.
So much disappoint...if only that effort spend on bandages like this were put to use in areas that could have larger impact.
Last edited by JarHarms; 01-22-2021 at 10:13 AM. Reason: People can blah, blah, blah all day long about it being an environment saving feature.
Old 01-22-2021, 11:32 AM   #18
rtv900
Member#: 428511
2016 STI
it's not for fuel savings, it's emissions.
Emissions at idle are some of the worst of all because of how much timing is needed for a good idle.
I'm not saying it's a big deal or necessary but it is emissions, not fuel economy.
Old 01-22-2021, 12:56 PM   #19
JarHarms
Member#: 138994
Emissions at idle are some of the worst of all because of how much timing is needed for a good idle. I'm not saying it's a big deal or necessary but it is emissions, not fuel economy.
Oh shoot when I say fuel consumption I was not indicating fuel savings. I should have adjusted my perspective better. Start-Stop is for fuel burn.
I was not being critical of your post, just being cynical of Start-Stop in general.
Old 01-22-2021, 01:24 PM   #20
rtv900
Member#: 428511
2016 STI
yeah I think the feature is idiotic. It makes me nuts when I'm in traffic and I hear a car shut off for 5 seconds and start back up again.
maybe in horrible city traffic or something where you are stopped for 80% of the total time it could serve a purpose, but in rural areas like where I am you are driving 98% of the time and maybe hit a light or two for 10 seconds, 20 at most
Old 01-22-2021, 06:05 PM   #21
BoostMasterZero
Member#: 337634
2013 WRX Sedan
I totally agree.
I would love to see some long term studies or even just plain use over a 20-30 year period to see cars with the auto start-stop feature vs. cars w/o them and the life span of the OEM starter of the same two vehicles with one equipped with AS and one w/o it.
Old 01-28-2021, 04:14 AM   #22
casper_04
Member#: 521841
2018 STI Limited
Dark Grey Metallic
If you take it in to your local dealer now, Iíve been seeing posts about a software update that puts the auto start/stop button right next to the home button, which makes it a lot easier to turn off as itís always there and takes one press. Unfortunately it still canít be disabled permanently, so either press it every startup or learn to live with it.
casper_04 is offline   Reply With Quote
Old 01-28-2021, 07:00 AM   #23
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
Pressing a button every startup stops being much of a nuisance after a while.
Norm
Old 01-28-2021, 11:55 AM   #24
rtv900
Member#: 428511
2016 STI
Hell I have to flip my center console switch to S# every single start up.
It's just a reflex at this point although I certainly wish I didn't have to do it
