Welcome to the North American Subaru Impreza Owners Club Wednesday May 18, 2022
Old 10-21-2021, 07:16 PM   #1
basyager
Member#: 518233
2019 WRX
Default the CarPlay thread.
Trying to see why the carplay doesnt work.
I want to get confirmation that someone's iPhone 11 is able to connect to the HU thru Carplay on the 2019 non nav HU so I know im not just shooting at the sky here
HU firmware has been updated by dealer, supposedly most current. iPhone has the latest update.
my phone and cable fired up carplay on a 2021 wrx right away.
Guy said he found a fix by plugging a USB Male to USB type C female into the car's usb, and for the phone cable using a type c lightning cable
Another guy said the 11 will only connect to carplay when its at 100%
basyager is offline   Reply With Quote
Old 10-21-2021, 10:26 PM   #2
K3rm1tth3fr0g
Member#: 508105
Link tuned 02 WRX
EJ205 20G-XTR JDM 6MT E85
Not powertrain related.
Post in the correct forum.
K3rm1tth3fr0g is offline   Reply With Quote
Old 10-22-2021, 08:53 PM   #3
basyager
Member#: 518233
2019 WRX
CarPlay connected today, I gave up trying already then I started up the engine and there was a carplay pop up on the phone I was like NOOOO WAY, and yeah it did connect and work until it disconnected and never was able to connect again. but it actually worked, for about 10 minutes..then i did the delete phone, and it couldn't connect again.
Old 12-03-2021, 06:52 PM   #4
basyager
Member#: 518233
2019 WRX
i have an update.
been driving around with my phone hooked up to usb and it connected to carplay again, but this time I did not go and "forget" starlink IV in the phone. and it actually worked for 20-30 minutes, before disconnecting.
turning off the car letting it sit then coming back sometimes makes it connect back but now its been MIA for a few days again..
for 2 days it worked so good, I turned the key just half way and carplay would fire right up..
usb ports or software issue? what do you think..it is not my iphone 11 pro gaiz.. apple doesnt make trash..its the car
it saw that it can work flawlessely, but it just stops doing so... for no apparent reason
I feel like it loses connection for a moment due to a bad usb connection and then the headunit just becomes braindead not wanting to see the connected usb phone.. usb stick? no problem. It does similar thing when I listen to mp3 from a usb stick. for 30 minutes it works and then starts disconnecting every minute, but it is able to continue because I enable the "auto play usb device option". with the car play it goes away for good
it worked better with AA and my old motorola. it still lost usb connection but would hook back up. and worked stable.
Old 12-03-2021, 07:56 PM   #5
LouCioccio
Member#: 496163
2018 Forester
Pearl White
Default The CarPlay thread
You may want do a few things with the iPhone which iOS version, version of iPhone ie 11,12 etc. swap the cable to see if the problem continues. Reboot the iPhone. Does iPhone have the latest iOS upgrade.
Now that being said I got rid (it stored) my OEM radio 2018 Forester as it did not have CarPlay and replaced it with a Kenwood. CarPlay only fails very seldom where I have to logon the number code. I also have a 6th gen iPod plugged in the secondary port. As long as I remember to shut it down; when the car is started the next day it will turn itself on and begin playing the songs I have loaded. As long as I have the iPhone XR already logged on and plugged in the USB port the Kenwood sees it but does not play any music on the phone but rather to the iPod.
Not sure if this helps but from my point of view I think the automakers think of the sound system as an after thought. Look at the trouble they have with the chip shortage it old technology they never updated it. Just my 2cents.
LouCioccio is offline   Reply With Quote
Old 12-03-2021, 11:29 PM   #6
basyager
Member#: 518233
2019 WRX
no its not the cable. i tried a short one from dollarama, a long one from apple, a long one with a usb type c adapter, it works the same with all. this headunit is just f'd is the problem. or maybe the usb ports are. im gonna make a last attempt and replace usb ports before i replace it with a HU from a real electronics company
Old 01-08-2022, 09:37 PM   #7
Ghostem
Member#: 528229
2021 Subaru Wrx
It sounds like the USB ports. Make sure the cable is otg but if your using a certified apple cable it’s in the port.
Ghostem is offline   Reply With Quote
