Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2022
Old 05-17-2017, 12:41 PM   #1
cpenner
Member#: 20635
11 STI
Default Accessport V3 and Air Pump Delete kit - how to silence CEL
**edit the Cobb is a V3 **
Hi,
I have a 2011 STI (Canadian Edition). I've just had my local shop install the LIC Motorsports Air Pump Delete kit due to the usual air pump valve failure. The rest of the car is stock - except for a Cobb Accessport off the shelf "tune" for stage 1 91 octane.
I now have a CEL and am in limp mode.
I have a Cobb Accessport (v2 - I believe) (actually V3) and can reset the codes, but they keep coming back.
Do I need to take the car in to a Cobb tuner to get the codes deleted from my ECU programming, or is this something that can be done via emailing files. I'm not looking for a custom tune at this point - I just want my S# back. If so - who do you recommend?
Thanks in advance.
cpenner is offline   Reply With Quote
Old 05-17-2017, 12:46 PM   #2
TheOtherAdrianG
Member#: 466686
You can pay a Cobb tuner to disable them for you, or pay the $150USD to get EFI trained so Cobb will provide you with accesstuner race, which you can use to disable the codes yourself. The second option makes more sense in my opinion.
TheOtherAdrianG is offline   Reply With Quote
Old 05-17-2017, 12:52 PM   #3
cpenner
Member#: 20635
11 STI
Which course is it? I see the $600USD 2 day course, but no $150. I'd need to see if there are locations near me.
For what it's worth - I'm not a mechanic by any stretch. I'm a software developer. Mind you, ECU is just software...
Thanks for the quick response.
Old 05-17-2017, 12:55 PM   #4
TheOtherAdrianG
Member#: 466686
This should explain it:
https://www.cobbtuning.com/products/...-accesstuner/#
The course is pretty basic from what i've heard but will get you access to the software. Disabling CEL's is child's play, but you get access to a lot more this way.
Old 07-21-2017, 08:56 PM   #5
Wilky867
Member#: 427177
https://www.freektune.com/can do it for you via email. When he did mine he charged something like $50.
https://www.freektune.com/collection...just-lc-or-ffs Looks like it's $20.
Wilky867 is offline   Reply With Quote
Old 07-22-2017, 01:22 AM   #6
cpenner
Member#: 20635
11 STI
Thanks. I probably should have posted a follow up. I took the $150 course and got the software from Cobb. Easy to do. The theory of the course was interesting - but really just scratched the surface. What I picked up from it was "lots of cool ways to tune and adjust for things - but you know so little about any of them - keep your hands off"
Good times.
Old 07-22-2017, 11:14 AM   #7
Wilky867
Member#: 427177
Right on. I ended up doing the same thing. At least I can turn off the monitors when I do a mod that requires a different map now.
Old 02-26-2019, 05:15 PM   #8
lowbee
Member#: 254317
2011 STi
So OK I unchecked all the code encapsulated in the red boxes and I am seeing no CELs any more BUT when I use the Cobb AP to scan for code, the code p2443 is still there but no CELs. Is that normal ?
Checking IM readiness on Cobb AP and it says everything is OK, no DTC and all system ready including secondary air pump operation. I am confused
lowbee is offline   Reply With Quote
Old 08-02-2019, 02:44 PM   #9
VaderGT
Member#: 504845
I am also looking to get rid of my cel for my air pump and was wondering if someone could send me the file to download access tuner
VaderGT is offline   Reply With Quote
Old 08-05-2019, 04:02 PM   #10
Shake-n-Bake
Member#: 324646
2007 WRX Wagon
Same here. Someone help us please
Shake-n-Bake is offline   Reply With Quote
Old 08-05-2019, 07:59 PM   #11
JSR84
Member#: 469585
2009 STi
Doesn't work like that. The AccessTuner Race files are locked to the Access Port serial number.
JSR84 is offline   Reply With Quote
Old 08-06-2019, 07:46 AM   #12
Shake-n-Bake
Member#: 324646
2007 WRX Wagon
Wondering if anyone offers this e-tune service. The link posted above from freaktune requires that you already have an e-tune from them. No bueno.
Old 08-06-2019, 10:31 AM   #13
JSR84
Member#: 469585
2009 STi
Lots of people out there. I dealt with Eric from Torqued Performance back when I outsourced my tuning. Nothing but good things to say about him.
https://torquedperformance.com/
Old 08-06-2019, 10:51 AM   #14
Shake-n-Bake
Member#: 324646
2007 WRX Wagon
Thank you, will check him out.
Old 09-27-2020, 01:52 PM   #15
snake2332
Member#: 173313
Can you still delete the codes for secondary air pump even though it's "illegal for road use"? After going through the $149 training, I'm waiting for the email with the link to the software and am having regrets after reading online that you can't delete some of the emissions-related codes now.
So my only option would be to try and recreate the tune in RomRaider, then uninstall the AP and never go back? Really wish they mentioned this before I spent $149 and 5 hours.
snake2332 is offline   Reply With Quote
Old 09-27-2020, 02:41 PM   #16
snake2332
Member#: 173313
I see Kyle @ Cobb a year ago saying:
"The codes can be prevented from turning on the CEL but they will still be present with any scan."
But 6 months ago he simply says:
"You are not able to disable codes with the software. The issues may be related to that."
and
"You are not able to disable any codes with Accesstuner. The only way to fix the would be to fix the issues causing them."
Old 09-29-2020, 10:07 AM   #17
snake2332
Member#: 173313
Now that I've got AccessTuner, I can answer my own question: Yes, the advanced parameters are still there and you can "disable" them by unchecking them.
Unfortunately, the map for my car is locked by the tuner and I can't change it, not even the advanced parameters. Super lame but I get it - tuners gotta protect their work. I guess I'll be reading some data from my tune and trying to do my own stage 2+ and see how it runs compared to the pro tune.
Old 11-15-2021, 12:26 PM   #18
nissansupragtr
Member#: 339738
2006 Saab 9-2x Aero
Is there a way to tell if your tune is locked without downloading the software? Thanks
nissansupragtr is offline   Reply With Quote
Old 12-09-2021, 05:10 PM   #19
toonpopo
Member#: 527836
I have a 2011 STI that previous owner performed the secondary air pump delete. I have Cobb AccessPort and did the Cobb EFI training, however I still cannot quite figure out how to bypass/override/delete the CEL that comes up every morning permanently through AccessTuner.
I can clear the code from the AccessPort but it shows back up the next morning. Any help/direction? I've looked all through the support/manuals etc to no avail
toonpopo is offline   Reply With Quote
Old 12-09-2021, 05:11 PM   #20
toonpopo
Member#: 527836
Old 12-09-2021, 05:43 PM   #21
snake2332
Member#: 173313
F11 for Advanced Parameters, then do like this (I think):
EDIT: Oops forgot these ones:
Old 12-09-2021, 06:22 PM   #22
snake2332
Member#: 173313
If you're using a Cobb AP, it's locked to the tuner's AccessTuner software. Or it was created before Cobb did all of that, but you can't obtain the old software and do anything with it.
You also can't open the locked tune to copy it to a new tune. You have to start from scratch, but you can read real-time parameters and logged data to figure out the MAF scaling and other important settings.
Old 01-06-2022, 11:50 AM   #23
jon7009
Member#: 394646
2003 WRX Flex Fuel
Pv=nRT
removing the air pump from any 2007 and newer vehicle also removes the barometric pressure sensor. you'll need a workaround for that.
some people cut off the top of the air pump and leave it connected to the harness and then stow it away, and others like me, wire in an oem MAP sensor from an older vehicle and then flash the car with updated barometric pressure scalar and offset.
jon7009 is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
