Welcome to the North American Subaru Impreza Owners Club Friday May 20, 2022
Old 07-19-2021, 08:43 AM   #26
Scooby-Doode
Member#: 28976
2016 Step 2 Push
Buggy GT
Old 07-19-2021, 11:05 AM   #27
JP Chestnut
Member#: 504432
Expensive, I'm sure, but a pretty unique car in 2021.
JP Chestnut is offline   Reply With Quote
Old 07-19-2021, 11:10 AM   #28
JRodrigues
Member#: 149337
2016 MX-5
Soul Red
JRodrigues is offline   Reply With Quote
Old 07-19-2021, 12:06 PM   #29
AVANTI R5
Member#: 73805
Audi's hot compact returns next spring.
Unlike some automakers as of late, Audi is revealing its returning compact car from the bottom trims up. That means that instead of the Audi RS3 coming out before the A3 and S3, like a Mercedes-AMG, we were treated to info on its less expensive brethren before we got to talk about the new high-performance, track-ready version. The only thing we could talk about last month was the RS3's new "Torque Splitter," a new piece of tech that replaces the rear axle differential and the previous multiple disc clutch package.
It now uses an electronically controlled multiple disc clutch on each of the drive shafts to distribute the right amount of torque along the rear axle. During high-performance driving, the torque splitter increases the drive torque to the outer rear wheel, which reduces understeer. It can also be used for sweet drifts in RS Torque Rear mode.
The 2022 Audi RS3, available next spring, continues with its turbocharged inline five-cylinder engine, inspired by its rally cars of the last century. The firing order is the same, 1,2,4,5,3, as those championship-winning vehicles, and output is now rated at 401 hp, seven horses up from the previous model. Torque is rated at 369 lb-ft (an increase of 7 lb-ft). Torque maxes out at just 2,250 rpm and continues until 5,600 rpm, and max power comes in earlier too.
That's good for a supercar-like 0-60 mph sprint of 3.8 seconds and a top speed of either 155 mph or 174 mph, depending on options. A seven-speed dual-clutch transmission distributes power too all four wheels and the RS3 now sports a variable exhaust control flap for a broader sound.
The standard RS suspension features new shocks and valve system that are both specific to the RS3. Audi says they respond faster and more efficiently. Adaptive dampers are optional, which continually adjust to the road and chosen drive mode. The wheels also have more camber than the previous model, which leads to a sharper steering response and increased cornering force, says Audi. The fronts have 1 degree of additional camber over the A3. The rear wheels have half a degree extra.
Audi had to modify the pivot bearings, and new bearings were equipped in the lower wishbones, subframes and stabilizers at the front. The four-link rear gets upgraded over the A3 as well. The RS3 sits about an inch lower than that car.
All of the suspension data is captured and analyzed by the new modular vehicle dynamics controller, which then synchronizes the Torque Splitter, adaptive dampers and wheel-selected torque control. It makes the car handle better, is the short version. The RS3 is offered with either steel or carbon ceramic brakes with six-piston calipers in several colors.
The new RS3 gets a more aggressive and futuristic look than its predecessor with slim daytime running lights and checkered flag lights below. Matrix LEDs are optional. The intakes are bigger as is the central opening. It gets a new air outlet behind the front tires and redesigned rocker panels on both sides. The rear sticks with two tailpipes but gets a black grille just above as opposed to the body color on the previous model. A new selection of 19-inch wheels are available and if ordered, Audi will mount semi-slick Pirelli Trofeo R tires.
Inside, the RS3 features the Audi virtual cockpit plus along with a 12.3-inch screen. In addition to your normal navigation and media function, it also has a selection of specific screens for things like power and torque percentages. You can also display the gauges in RS Runway mode, in which the values are displayed in the opposite direction resembling an airport runway with the highest speeds in the foreground and lowest in the background. It also can show your lap times, g-meter, acceleration. You can also put shift lights in the head-up display.
Elsewhere in the cabin, you get carbon fiber, sport seats and embossed stitching. Buyers can spec leather with contrasting stitching in black, red or green. RS Design packages are also available to match with seat corners, seatbelts and air vent accents.
Audi hasn't priced the RS3 in the US yet, but in Europe it will costs 62,000 euros, which converts to about $73,000, but usually there are price differences besides the conversion. The new color you see is called Kyalami Green. It will also be offered in Kemora Gray. Lastly, while Europe will get both the sedan and hot hatch, we'll only get the sedan.
Old 07-19-2021, 01:29 PM   #30
dwf137
Member#: 161333
20 Yami XSR
fast leaf
Old 07-19-2021, 01:40 PM   #31
murrdogg24
Member#: 50586
64 Impala
murrdogg24 is offline   Reply With Quote
Old 07-19-2021, 01:40 PM   #32
Scooby-Doode
Member#: 28976
2016 Step 2 Push
Buggy GT
It's loud, I like it. Too bad no hatch for the U.S. market. Too bad it will be super expensive. Back to whining about the STI.....
Old 07-19-2021, 07:02 PM   #33
heavyD
Member#: 194216
2020 X3M Competition
I just feel like the grille is too large now. I think Audi has consitently made clean and handsome cars since last decade when they brought bigger grilles mainstream but I think that look has peaked as this car is less handsome than past generations.
heavyD is offline   Reply With Quote
Old 07-19-2021, 07:32 PM   #34
JP Chestnut
Member#: 504432
The grill is huge and it's not a lovely car. However, it's pretty distinctive and aggressive which is unusual for an Audi.
Old 07-20-2021, 03:28 AM   #35
Pre
Member#: 139693
Dura ngo 95
horrorshow
So that's how you get physical climate control buttons.
We need the hatch and a 6MT.
Old 07-20-2021, 12:14 PM   #36
4S-TURBO
Member#: 67807
It's an RS. Not aggressive?
Old 07-20-2021, 12:21 PM   #37
Scooby-Doode
Member#: 28976
2016 Step 2 Push
Buggy GT
RS6 Avant is ridiculous. Maybe one day when I have lots of cash to burn I'll buy another VAG product, and the RS6 will be near the top of that list.
Old 07-20-2021, 05:36 PM   #38
Straight6
Member#: 419593
2019 EA888 Gen3 crew
Probably the last of its kind. I still think the facelift ruined it but they are going to keep their value. It is one of those cars that won't depreciate much.
Straight6 is offline   Reply With Quote
Old 07-20-2021, 11:07 PM   #39
Kostamojen
Member#: 2272
2019 Macan 4cyl
1993 Impreza FWD WRX swap
Does the S3 get the fancy Golf-R/RS3 diffs?
Old 07-21-2021, 02:29 PM   #40
heavyD
Member#: 194216
This looks better because the black grill is separated from the headlights by colored body. The large expanse of black on the front totally dominates the front end making it look weird. Maybe black will be the best color for this car.
Old 07-22-2021, 04:25 AM   #41
JRodrigues
Member#: 149337
2016 MX-5
Soul Red
This:
Originally Posted by JRodrigues View Post
strange, the forum doesn't accept imgur links anymore.
Old 07-22-2021, 08:45 AM   #42
Brahmzy
Member#: 3293
'20 Ascent
'15 XTerra P4X
Holy grille. That front headlight setup screams Jetta.
$70K
M2C - easy choice with gas money left over, and most importantly, a clutch.
Old 07-22-2021, 08:48 AM   #43
Snow Drift
Member#: 75071
AR Giulia,Tesla MY
05 08 11 WRX 18 STI 18TM3
No. RS 3 and Golf R only.
Old 07-22-2021, 11:29 AM   #44
JP Chestnut
Member#: 504432
"Unusual" doesn't connotate never happening.
RS3
versus base A3
Are you seeming some aggression that I'm not, or do you just feel like arguing?
Old 07-22-2021, 12:16 PM   #45
4S-TURBO
Member#: 67807
No. I'm pointing out the current design language has changed for RS vehicles to be more extreme and in your face. The RS6 and all the other RS cars are using this language. Which started with the 2019 R8 refresh, the flagship RS car.
Here are the A3s...
So while it may be odd compared to the subdued style for the old cars, it's not for their current lineup. Perhaps both RS' shown (green and red) have a black optics package standard on the launch cars. Dunno.
Old 07-22-2021, 01:57 PM   #46
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
No hatch, no manual, no f***s given. I'll stick with my bugeye, thanks Audi...
car_freak85 is offline   Reply With Quote
Old 07-22-2021, 02:20 PM   #47
standardtranny
Member#: 450713
2017 WRX Stage 3ish
world rally blue
boy do I have a VW for you...
standardtranny is offline   Reply With Quote
Old 07-22-2021, 08:10 PM   #48
Pre
Member#: 139693
Dura ngo 95
horrorshow
With a bunch of screens, and no physical controls, and the OS doesn’t work very good. VW really f’d up with the R. Gearheads buy it, not phone addicted clowns.
Old 07-23-2021, 12:38 AM   #49
4S-TURBO
Member#: 67807
Somebody painted around the grill. Looks 1 million times more...mostly cuz hatch. I'll take the ugly gloss grill if it means I can have the hatchback.
Old 08-03-2021, 06:40 AM   #50
AVANTI R5
Member#: 73805
Default 2022 Audi RS3 Crowned King Of The Nurburgring
Your move, Mercedes-AMG.
The Audi RS3 in its latest incarnation has just been revealed with that signature five-pot engine, more power than ever before, and a drift mode. Its 2.5-liter turbocharged engine produces an impressive 400 metric horsepower - 394 hp in American terms - and 369 lb-ft of torque, enough for a blisteringly quick 0-62 time of just 3.8 seconds. With the right options, it'll even top out at 180.2 mph, although the stock model is limited to 155 mph. On paper then, the new RS3 looks like a winner, and as it turns out, it looks like a winner on track too. Audi took the all-new RS3 sedan to the Nurburgring and achieved a time of 7:40.748, earning the four-door the title of the fastest compact model at the Nordschleife.
Back in June, before the car had been fully unveiled, Audi Sport racing and development driver Frank Stippler was behind the wheel and beat the previous lap record for the class by a laudable 4.64 seconds. However, there's usually an issue with lap records as manufacturers tend to fiddle with the cars in ways that the average customer will never get to experience. Not so here. Before the record-setting lap, Audi says that it only adjusted the tire pressures in the Pirelli P Zero Trofeo R semi-slick tires so that they'd be more suitable for track conditions. Sure, semi-slicks aren't the default choice for the average consumer, but they're a small change that remains street-legal. Furthermore, these tires are an optional extra for the first time, so this really is a factory-stock car.
Audi pins part of the success of the lap on the torque splitter, a first for an Audi model. This technology helps the car turn in better. "In general, the new RS3 is much more agile when driving from the middle of the curve to its end and when accelerating out of the curve," said Stippler. "For me, the torque splitter is a quantum leap in terms of agile driving." The tires are also awarded some praise for the time achieved, as are the 19-inch ceramic front brakes, the adaptive RS sport suspension plus system, and the RS Performance mode.
In setting the new record, Audi beat the previous record holder, the Renault Megane RS Trophy-R, which held the record with a lap time of 7 minutes and 45.389 seconds.
54321
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
