Welcome to the North American Subaru Impreza Owners Club Thursday February 21, 2019
Old 01-21-2019, 11:15 PM   #1
Etai9
Member#: 341084
Default 02 Wrx 05 Sti center console swap HELP!
Hello,
I want to swap my 02 Wrx center console to the better
Looking 05+ Console.
Is there anywhere I can order a complete kit of what I need for this swap?
Thanks!
Etai9 is offline   Reply With Quote
Old 01-22-2019, 05:51 PM   #2
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
your best best it to find a car that is being parted out and take everything from it that you would need.
Zmanwrx23 is offline   Reply With Quote
Old 01-22-2019, 09:15 PM   #3
kchiimba08
Member#: 223668
You Need A Lot Of Random Small Pieces. You Can Go On Subaru Oem Parts.com ( Any Of Those Oem Websites) And Pullup The Center Console Diagram In Parts And Itll Show U Mostly Everything You Need. Bunch Of Plastics And Brackets.
kchiimba08 is offline   Reply With Quote
Old 01-22-2019, 11:34 PM   #4
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
dont you need the Hvac module and dash too? the older WRX kinda hangs over the shift aria. the new one sweeps smoothly up and everything is different. you basically need to completely gut the car and install the new interior.
CarmelValleyWRX is offline   Reply With Quote
Old 01-23-2019, 11:02 AM   #5
db7like
Member#: 431396
03 wrx
wrb
The hvac stuff is only different for automatic/electronically controlled,
you would have to do a whole lot more work for any of that to go in properly.
The surrounding parts for the headunit/hvac and metal mounting bracket behind it.
Center console, two sides, shifter trim, newer ebrake handle with the back half swapped with the older one.
The metal side plates for the headunit is also different between the two styles.
And if you want your ebrake mounted with 3 bolts, you would need to tack weld the driver's side mount in place.
Like someone else said before, taking it all out of an intact parts car would be easiest.
db7like is offline   Reply With Quote
