Welcome to the North American Subaru Impreza Owners Club Monday September 28, 2020
Old 05-18-2006, 08:40 PM   #1
AaronWRX
Member#: 7194
2011 997.2 Turbo
Default New turbo: APS SR56 thread...
IdiotsWithStis.com thread:
http://www.iwsti.com/forums/showthread.php?t=51770
Originally Posted by MZM Performance
Hello everyone,
We glad to announce we have just received the brand new bolt-on dual ball bearing turbo charger specifically designed for the USDM 2.5 liter motor from APS :tup: The SR56
You wanted the big exhaust housing for top end power and power curve that does not drop off on high rpms, APS engineered, designed and manufactured it and we got it
You also wanted the ultimate in boost control and ability to run high boost at lower RPMs and lower gears while less on top end and higher gears. Well the SR56 comes with the hardware, Forge wastegate actuator!!! (Forge nuff said ) Combine the Forge actuator with one of the better top of the line electronic boost controller solutions in the market and see how its like to have the exact boost pressure you like when you want it
Technical information and specs to follow. We just had another SR55 equiped 2.5 liter STi trap 120 we can't wait to see what this bad boy can do
Enjoy the pics
Cheers
AaronWRX is offline   Reply With Quote
Old 05-19-2006, 05:33 AM   #2
V5-STi
Member#: 18058
Strange....the turbo shown actually has SR56 stamped on the side, but the APS website only lists an 'SR57' !!
Looks like an SR55 with an uprated Forge actuator to better control boost.
Wonder if there are any other differences?
V5-STi is offline   Reply With Quote
Old 05-19-2006, 05:35 AM   #3
Bolster
Member#: 22290
2002 STI Ver 9
Spec C Wagon
Just checked APS' website. Apparently, the SR56 is already "obsolete" because they now list an SR57 and make no mention of the SR56.
Bolster is offline   Reply With Quote
Old 05-19-2006, 08:18 AM   #4
quickscooby
Member#: 39415
STI 444/[email protected]
479/492 @ 30psi GT30R .82
Edited
quickscooby is offline   Reply With Quote
Old 05-19-2006, 10:36 AM   #5
keaniegenie
Member#: 94494
2005 Element 92x
larger exhaust housing too.
keaniegenie is offline   Reply With Quote
Old 05-19-2006, 10:46 AM   #6
13brewtt
Member#: 39694
05 Evo 8 MR 2.2L
SR56= upgraded SR55. The most significant elements are the larger A/R turbine housing and proprietary Forge billet actuator.
However, you have a choice. Current stock released is with a 60 mm compressor inlet hose connection, (which is what APS SR series turbochargers have always had, stock is 55mm) as a SR56; or the optional upgrade 76.2 mm. (3) as a SR57.
No difference in price to each other, or the SR55.
Whichever compressor housing is NOT chosen, will be offered as a loose part for an MSRP of $$??, not released as of yet.
More concrete & definitive information will come shortly through APS web site.
13brewtt is offline   Reply With Quote
Old 05-19-2006, 11:13 AM   #7
bboy
Member#: 56468
04 Improved STI
Dirty White
Exhaust housing looks like the one from the VF39--not very big.
Old 05-19-2006, 12:09 PM   #8
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
For $2100 you can get any garrett turbo you want, rotated with an external wastegate, AND a new uppipe and downpipe.
Capt Crunch is offline   Reply With Quote
Old 05-19-2006, 01:33 PM   #9
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Link?
DoctorNick is offline   Reply With Quote
Old 05-19-2006, 06:20 PM   #10
Capt Crunch
Member#: 10852
Originally Posted by DoctorNick
Link?
www.perrinperformance.com
www.wbrperformance.com
the perrin kit requires a T31 exhaust housing, which can be had in GT flavors, and the WBR kit uses a conical discharge GT turbo. Both are $2500 but include an intake and MAF housing.
Old 08-02-2006, 01:53 PM   #11
greysave
Member#: 62395
2005 STI
anyone get this yet?
greysave is offline   Reply With Quote
Old 02-08-2007, 10:22 PM   #12
shay-sti
Member#: 130054
Me
I will put this sr56 turbo on my 02 sti 20L next week.
I hope this turbo will be faster then my stock VF30.
I will tell you guys how it is after the tuning.
Watch me luck
shay-sti is offline   Reply With Quote
Old 02-09-2007, 12:37 AM   #13
Andrew
Member#: 1170
2005 STi
To anyone who can read compressor maps, how does the SR56 fair? I'm looking for a stock mount turbo and this is the largest with a 2.4 inlet.
Andrew is offline   Reply With Quote
Old 02-09-2007, 05:14 PM   #14
Andrew
Member#: 1170
2005 STi
I found this dyno graph of an SR56.
APS SR56 Turbo
with Oil Lines
-TGV Delete
-850cc Inj
-Inj. Harness Conv.
-255lph Fuel Pump
-3.5" APS Exhaust
-APS Up Pipe
-APS DR725 FMIC
-APS BOV (FMIC)
-APS Cold Air
-Fuel Rails
-ECUTeK Flash
Old 02-10-2007, 10:59 AM   #15
shaz1980
Member#: 136105
i want to buy aps turbo sr56 with sr57 housing for 2.0l sti jdm 05 i am not sure wat sort of power i will put down is it good choice for it not to flat out at the top end rev limiter is at 8k
shaz1980 is offline   Reply With Quote
Old 02-10-2007, 07:24 PM   #16
samanosuke
Member#: 131106
2004 STi
World Rally Blue
Not too bad.
samanosuke is offline   Reply With Quote
Old 02-21-2007, 05:27 PM   #17
shay-sti
Member#: 130054
Ok, I finished the tuning on my sti 02 2.0L
On 1.5 bar
aps sr56 Turbo with a 60 mm compressor inlet hose connection and Oil Lines
740cc Inj
255lph Fuel Pump
Fuel Rails
ECUTeK
Scoop hood sti 2004
Tmic xs power
3.0" Exhaust
Aem cold air intake
The red line is my
And the yellow is 2006 sti 2.5L power enterprise twinscrool.
Old 02-21-2007, 06:44 PM   #18
opavon33
Member#: 109839
I have an APS Sr-55 on sale for $1000 shipped USA ONLY, in mint conditions 800 miles on it .
For pictures E-mail me at [email protected]
Thanks
Osvaldo
opavon33 is offline   Reply With Quote
Old 04-10-2007, 01:21 AM   #19
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
Thanks
Osvaldo
why are you selling it?
rhinotech is offline   Reply With Quote
Old 04-16-2007, 04:17 PM   #20
greysave
Member#: 62395
2005 STI
I have an sr-55 for sale also fyi. Mine has 4000 miles on it no shaft play. Im selling it for 850 plus shipping, I have an 35r now.
Old 04-16-2007, 05:17 PM   #21
Jhovany
Member#: 137317
2006 STI
Rally Blue
How do you like your 35r compared to the SR55? How does it spool compared to the sr55? and also your power?
Jhovany is offline   Reply With Quote
Old 04-16-2007, 06:11 PM   #22
greysave
Member#: 62395
2005 STI
Haven't driven it yet. I am doing a pretty crazy build, so I'm waiting to finish that first. Shoot me a pm so i can tell you.
Old 04-11-2008, 05:51 PM   #23
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
bump this old thread..
Where can I purchase the SR57 housing to replace the SR56 housing?
I have the 3" inlet hose and want to use it...
Old 04-23-2009, 06:42 AM   #24
danyol3
Member#: 200562
2011 STi
could i put this in my 04 wrx?
danyol3 is offline   Reply With Quote
Old 09-05-2009, 03:14 PM   #25
3k1n
Member#: 83043
05 sti
how big is the sr56? does it come with a 2.4 inch inlet? anyone know? is it around a gt52?
3k1n is offline   Reply With Quote
Fs: Aps Sr56/ Aps Dr525 Fmic/ Hks csk8er SCIC Private Classifieds 50 08-09-2010 07:55 PM
fs: aps sr56 and aps turbo inlet evokillerchris Engine/Power/Exhaust 8 05-07-2007 04:54 PM
f/s aps sr56 & aps turbo inlet evokillerchris MWSOC Private Classifieds 21 04-12-2007 07:40 PM
TX: APS SR56, Td04 & 2 APS Equal Length Headers (Twin Scroll) w00dst0ck Engine/Power/Exhaust 18 04-08-2007 11:11 AM
APS SR56 VS Perrin GT30R .82 quickscooby Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-17-2006 10:32 PM
