Welcome to the North American Subaru Impreza Owners Club Thursday March 23, 2017
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 06-16-2006, 06:28 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Mounts back in stock. Helix, HKS, Greddy, Built Motors!
JDM STi Mounts in Stock!!
STi Motor Mounts - $95 Shipped
STi Pitch Stop Mounts - $45 Shipped
Motor and Tranny Mount Combo - $159 Shipped!
Motor, Tranny and Pitch Stop Mount Combo - $199 Shipped!!
Helix Injectors:
Helix Power 660cc Injectors for WRX + Walbro 255L FP and setup kit - $539 Shipped!
$469 Shipped for just the Injectors!
- Ideal for VF series and PE size turbos on WRXs
- 340WHP Capable
- Will work on the 06 WRX
Helix Power 820cc Injectors for WRX + Walbro 255L FP and setup kit - $549 Shipped!
$479 Shipped for just the Injectors!
- Ideal for large turbos on WRX: Green, 20G, GT30R, etc.
- 510 WHP Capable
Helix Power 860cc Injectors for STi + Walbro 255L FP and setup kit - $565 Shipped!
$495 Shipped for just the Injectors!
- Ideal for 20G, Green, Red, GT30R, GT35R, etc.
- 550WHP Capable
Cusco Radiator Shroud - 02+ WRX / 04+ STI - $99 Shipped!
Gruppe-S Oil Cooler Kit - $479 Shipped!
This Oil Cooler kit was introduced to the public after testing several iterations on Brian Lock's USTCC race car in the deserts of Arizona. The stock WRX and STi lack an oil cooler and running any turbo charged motor hard puts an extreme load on the motor's cooling systems and fluids. Keeping your oil cool not only prolongs the life of your oil but more importantly, it prolongs the life of your motor. This is one of the most overlooked upgrades on the WRX / STi and we feel that anyone who drives their turbocharged vehicle hard should have one. Perhaps that's why the Spec. C comes with an oil cooler from the factory. This oil cooler is track tested on a race winning vehicle and data logs show that it works. In comparison to competitors' oil coolers, the Gruppe-S Oil Cooler features an extremely high quality European core manufactured by a world famous brand and a thermostat of similar quality.
Key Features:
*High quality European core (240mm x 120mm x 45mm), not some Taiwanese knock off core.
*Thermostat operated Oil Cooler to avoid cooling cold oil upon startup.
*Aerospace fittings / stainless steel lines, professionally assembled and tested to 1000psi.
*Light weight mounting brackets.
In the words of USTCC race car driver Brian Lock, “this oil cooler rocks. After installing this setup we never had a problem with oil temperature again. Even at PIR where it was 115 and it was so hot inside the car I thought my legs were on fire, it was golden. Brian Lock thinks that this oil cooler is the ****, Brian Lock thinks you should buy it.”
Gruppe-S Forged Connecting Rods for EJ20T (WRX or JDM STi) - $349 shipped!!!
These are super high quality forged steel connecting rods made by a famous JDM aftermarket manufacturer (please e-mail for this info). They will fit in any 2.0L WRX motor (including JDM STi motors). These would be an excellent rod choice for anyone building a 2.0L motor and should support well over 600 WHP. These rods feature ARP L19 rod bolts which are widely considered to be the best on the market. At this price, there is absolutely NO REASON not to use these rods if you're building a 2.0L motor.
-Very high quality forged steel connecting rods
-Manufactured by a world renowned JDM company - PM FOR MORE INFO
-Use ARP L19 con rod bolts (regarded as the best on the market)
-Super cheap blow-out price for super high quality part!
EJ205 / 207 Forged Internal Kit -$849 Shipped!!!
We've put together an awesome deal for anyone looking to upgrade to fully forged internals. We are offering a forged internal complete rebuild kit for the EJ205 or EJ207 engine. With this kit you can rebuild your 2.0 to hold safely 400whp+*. The details are as follows:
*Wiseco 0.5mm over pistons – We use Wiseco forged pistons in our staged engine packages. Wiseco pistons are good for over 700HP. The 0.5mm overbore is designed to those of you that have had ringland or piston failures – you will need to re-hone your cylinder walls. If you require stock bore or 1.0mm overbore, they are available for an additional $50.
*Helix 2.0 forged connecting rods - These rods are sourced from a very famous Japanese tuner (once you see the rods you will know, JDM wholesale is over $500 for the rods alone). Helix took these rods and upgraded them to the strongest rod bolts ARP offers – the L19. Based on engineering principles and testing, the decision was made to use the stronger L19 rod bolts because of the high revs these 2.0 motors often see. After installing the stronger rod bolts, the rods are magnafluxed and re-tested to ensure reliability. These rods are good for 9000 RPM operation** .
*Gruppe-S Sport Bearings – Higher performance than the Subaru OEM bearings, we are offering the Gruppe-S sport bearings. They are equivalent to the JDM STI Spec C bearings, and can withstand high RPM operation. Sorry we are not offering our coated race bearings at this time.
This kit normally retails for over $1100 at our everyday low prices. Buying the stock cast parts from the dealer will cost you more than $1100. We have two kits at this price.
*Balanced / treated crankshaft is recommended for 400+whp service. Reinforced cylinder walls are recommended for all EJ205 cars for 400+whp service.
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 06-16-2006, 06:28 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
JDM V8 STi Twinscroll Downpipe - $249 Shipped!!
Perrin:
Perrin Downpipe for WRX / STI / FXT - $349 shipped
-304 Stainless, 75mm piping
-Divorced wastegate design
Perrin Front Mount IC for WRX / STI - $1099 shipped
-Rated for 500-800 HP
-Low pressure drop across core, efficient core.
-Comes w/ new bumper beam
Perrin Signiture Series FMIC for WRX / STI - $1175 shipped
-Comes w/ wrinkle red piping
Perrin Big MAF for WRX / STI / FXT - $209 shipped
-Allows more air to travel through the MAF without maxing it
-Highly recommeded for 20G / Green and larger sized turbos
-Requires tuning
Perrin Turbo Inlet Hose for WRX / STI / FXT - $209 shipped
-Smooths airflow into turbo
MORE PERRIN HERE: http://www.gruppe-s.com/subaru.htm
HKS:
HKS Hiper for WRX / STI - $529 shipped
-75mm piping
-Full stainless steel, comes with all gaskets and hardware
HKS Carbon Ti for WRX / STI - $719 shipped
-75mm piping
-Full stainless steel with carbon canister and titanium tip, comes with all gaskets and hardware
Greddy:
Greddy SP2 for WRX / STI - $539 shipped
-CARB certified, under 95 db
-80mm piping
Greddy Evo2 for WRX / STI - $579 shipped
-80mm piping
Greddy Front Mount Intercooler - 02-05 WRX / 04 STi - $885 Shipped!!!
Because of it's smaller core size and piping size, this is an excellent FMIC for people who have smaller turbos on their WRXs and STis (VF34, 16G, etc.)
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 06-16-2006, 06:49 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Built Shortblocks and Motors:
Gruppe-S Stage 1 USDM STi Longblock - $3999 + Shipping (built to order)
We have one blown STi motor that we will be rebuilding into one of our stage 1 longblocks (balanced, forged Wiseco pistons, coated race bearings, etc.). This longblock will be capable of holding 535 crank HP consistantly and will drop into any WRX or STi easily. Build time will be ~3 weeks and a 50% deposit will be required. You will not see this price on a longblock like this again!
*Longblock does not include ancillaries located on top of motor or accessories: no water pump, AC condenser, power steering pump, intake manifold, wiring harness, turbo, intercooler, etc.
-Gruppe-S / Wiseco Forged Pistons (custom spec)
-Gruppe-S Coated High Performance Rod & Crankshaft bearings
-Forged STi connecting Rods
-Forged STi crank shaft
-ARP Headstuds
-Cometic Head Gaskets (on long-block option)
-Professionally balanced rotating assembly (recommended 7500 RPM redline)
-Rehoned cylinder walls
-Capable of up to 535HP Operation
-~3 week build time, 50% deposit required
*Picture represents product and is not actual product. Actual product is longblock, not motor.
Gruppe-S 2.2L Stroker Kit for EJ20T - $1399 + Shipped
These are all the parts needed to build a 2.0L turbocharged motor (WRX or JDM STi) into a serious power making 2.2L stroker motor. This motor should be capable of holding 550 crank HP while revving to 7500 RPM if properly balanced. It includes the following:
-Custom spec Wiseco forged stroker pistons
-STi forged connecting rods and bolts
-STi forged crank shaft
-Gruppe-S coated racing bearings
Gruppe-S 2.5L Stage 1 Shortblock - $2599 + shipping
Our Stage 1 shortblock replaces the components we feel are most likely to fail in the USDM STi shortblock. This is essentially a bulletproof USDM STi shortblock and will compliment a GT30R, SZ55, FP Red , FP Green, or TD06-20G sized turbo nicely on 100 octane. WRX owners can benefit from this shortblock also since their heads will bolt right onto it; however, combining their heads with something like the Helix cams and valvetrain and this shortblock would yield something with peak power output similar to the USDM STi. In comparison to other companies' Stage 1 shortblocks, our adds coated race bearings and balancing to within 1 gram (JDM STi motors are balanced to within 7 grams).
Features:
-STi Forged Connecting Rods
-STi Forged Crankshaft
-ARP Headstuds (on long-block option)
-Capable of up to 535+ CHP Operation
-Final Displacement 2.48L
-Compression ~8.5 : 1
*Assembly time is generally 3-4 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order.
Gruppe-S Stage 2+ 2.5L Shortblock - $3999 + shipping
Our Stage 2+ shortblock is built for big numbers. This block is capable of over 625 CHP and 7800 RPM. It will max out a GT35R .82 and anything smaller than that. In comparison to the Stage 1, it adds a nitrated, lightened, and magnafluxed forged STi crankshaft and forged steel Pauter connecting rods.
Features:
-Coated High Performance Rod & Crankshaft bearings
-Reworked high RPM Forged STi Crankshaft
-Forged Pauter Connecting Rods
-Gruppe-S Stage Two camshafts (AVCS available) (on long-block option)
-Gruppe-S Stage Two Valve Train (on long-block option)
-Professionally balanced and assembled (recommended 7800 RPM redline)
-Capable of up to 625+ CHP Operation
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Gruppe-S is offline
Old 06-17-2006, 05:09 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
weekend bump!
Gruppe-S is offline
Old 06-18-2006, 02:26 PM   #5
albie1kanobi
Member Sales Rating: (3)
Member#: 101607
06 Subaru STi
are the jdm mounts any stiffer or harder than the group-n STi mounts?
albie1kanobi is offline
Old 06-18-2006, 07:34 PM   #6
Rick539
Member Sales Rating: (4)
Member#: 35997
How about a forged kit for ej25 for us doing hybrids?
Rick539 is offline
Old 06-19-2006, 07:58 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
I'm not quite sure what mounts you're talking about. As far as I know, there's just the Group-N STi mounts, the mounts that come on your car, and the Cusco mounts. In order of stiffness, it goes Cusco, Group-N, stock.
We can offer that same kit for the 2.5 with the same price. Please PM us if you're interested.
Thanks,
Geoff
Gruppe-S is offline
Old 06-19-2006, 09:48 PM   #8
albie1kanobi
Member#: 101607
06 Subaru STi
I have an 06 STi so my motor mounts from what i've read are really soft and are not like the 04-05 STi. I'm looking for Group-n mounts to replace my stock ones and was wondering if the JDM mounts are any better than Group-n or are you saying that the JDM and Group-n mounts are the same mounts?
Thanks, Albert
Old 06-20-2006, 01:50 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks, Albert
The Group-N Mounts we carry are from Japan, so I guess you can say that they are considered to be JDM. With that said, they are still stronger and better than your stock mounts on your car now.
Regards,
Mark
Gruppe-S is offline
Old 06-20-2006, 03:54 PM   #10
chirp the 1-2
Member#: 113095
06 wrx tr
Sent u 2 pms, and paypal for the mounts. Just wondering if they went out yet.
chirp the 1-2 is offline
Old 06-20-2006, 08:08 PM   #11
albie1kanobi
Member#: 101607
06 Subaru STi
i sent you payment for mounts too. wondering as well when it will be shipped out.
Old 06-21-2006, 04:31 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
I've replied to your PMs.
[QUOTE-albie1kanobi]i sent you payment for mounts too. wondering as well when it will be shipped out.[/quote]
Currently sold out of the rear upper mounts, only the front upper mounts left in stock.
Regards,
Mark
Gruppe-S is offline
Old 06-21-2006, 07:26 PM   #13
albie1kanobi
Member#: 101607
06 Subaru STi
sent you pm
Closed Thread
STi Mounts back in stock! *BEST PRICING* on Exedy and ACT. Kartboy, etc. Gruppe-S Drivetrain 0 07-18-2006 09:23 PM
*BEST PRICES ON EXEDY AND ACT* Tranny and Engine Mounts Back In Stock!! Gruppe-S Drivetrain 2 06-22-2006 08:31 PM
All Helix Injectors in Stock - Perrin, HKS, Greddy, Motor Building Components! Gruppe-S Engine/Power/Exhaust 13 06-16-2006 02:07 AM
STi Helix Injectors back in stock! Helix Cams for EJ20, built motors, much more! Gruppe-S Engine/Power/Exhaust 32 02-09-2006 04:00 PM
ESPELIR CATBACKS BACK IN STOCK!!! USDM STi 2.5L MOTOR AND TRANSMISSION!!! WorldOne Engine/Power/Exhaust 4 12-27-2005 07:40 AM
