Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 06-26-2006, 09:10 PM   #1
ToxinRS
Member#: 111266
2001 2.5RS
SRP
Default FS: Highly Modded TD05-14b 91 Dodge Stealth R/T TT in NH
I am selling my Firestorm Red 91 R/T TT with 107k on it. This car has been a project of mine for some time, and is almost finished. The tranny was replaced at about 90k, transfercase replaced at about 103k under a recall, new timing belt and tensioner with 3 miles on it, tires have about 3k on them. I need to buy a new car and a house soon, so it needs to go.
Mods:
Td05 14b turbos, one rebuilt, one with ~40k on it
JPDC adapter plate kit w/ Titan o2 housings and open dumps
Stainless Oil lines, deleted coolant lines
Stillen DP, needs to be cut to fit the new o2 housings
Custom 2.5" Catless Catback with Magnaflow Mufflers
A pair of Apexi N1 knockoff mufflers, 3" inlet ( wanted to change exhaust )
Aeromotive FPR w/ IPO install kit
Supra pump (not yet installed)
ACT 6 puck clutch and Fidanza flywheel
DNP Hardpipe kit customized to fit the TD05s
Option (MOMO Jet Styled) Steering wheel ( horn disconnected )
Greddy E-01
Emanage ( not yet installed )
Autometer A/F, Boost, EGT Gauges in triple A pillar pod ( EGT probe installed, gauge is not yet installed )
Vaccuum reduction w/ red silicone hoses
EGR/EVAP/Boost solenoid removal
Magnecor KV85 race wires
Rear Battery relocation with Optima Redtop
Greddy Counterweight shiftknob
Eclipse stereo
Ignited Single DIN switchpanel ( not yet installed )
Custom Red groundwire kit ( not yet installed )
Brass shifter and shiftplate bushings
K&N FIPK
Apexi BOV and Turbo Timer
Alpine Alarm, needs new horn
Shiver Datalogger on a Palm PDA w/ custom mount
Adjustable rear control arms ( not yet installed )
OhioSpyderman Short Shifter
Fuel Pump relay bypass
PIAA driving lights ( not yet installed )
680cc PTE injectors
Maximal Solid Motormounts and Tranny mount
ek2mfg fuel loop
Red Valve Cover w/ CF sparkplug cover
Polished Coolant Catchcan ( not yet installed )
Smokin Brushed Aluminum Dash Vents ( not yet installed )
1 DSM sidemount intercooler as an extra
Lots of extra and stock parts
I might be forgetting a few things too...
The body:
It has a dented DS fender, I have a new one to replace it with. It also has a few more dents and scrapes, and could use a paintjob. The rims are a bit choppy, but you will probably want to fit some 18x9s to this thing anyhow.
The interior:
Normal wear for 107k, drivers seat could use recovering, doors are bubbling.
Here is what needs to be finished:
-Downpipe needs to be cut to fit and installed
-Custom lower radiator hose needs to be cut
-Fuel pump installed
-Coolant catch can installed
-AFPR adjusted, along with...
-Emanage installed and tuned ( already have a good base map for you )
-New fusable link to rear mounted battery, current one is corroded (wasn't
sealed)
-Interior/Exterior cosmetic work
-Horn hooked up in aftermarket steering wheel
-PIAA Fog lights installed
-Clutch broken in
-Ignited Switch Plate installed in 2nd DIN slot
-Undercarriage enginebay plastic installed, have most of the pins and all plastic
-EGT gauge installed, sensor already tapped/installed in front manifold
-Groundwire kit installed
-A/C recharged
-The radiator cooling fans *just* touch the front turbo every once in a while, so the top retainer braket for the radiator needs to be cut about 1/8th of an inch to shim it back.
-the fittings might need to be checked/tightened for the new stainless oil lines once the engine is run for awhile with them to ensure a clean fit, simply
because they are new custom fittings. (just trying to be thorough here)
This car would be running reliably with about 15 hours of work or so, maybe less if you know the car well. I thought I'd put it here since it's AWD and Turbo, maybe someone would dig it. I have it for sale in a couple of other places, thought I'd try here also. I'm looking for 5.5k, which was a very firm price, but if I get it sold in the next few days I'll take 5k. I can be contacted at 603-930-9569 (cell) 7pm-11:30am EST ( work overnights ). Or I can be reached at [email protected]. Have some pics, email me for them.
ToxinRS is offline   Reply With Quote
Old 06-27-2006, 12:27 PM   #2
ToxinRS
Member#: 111266
2001 2.5RS
SRP
Mid day bump.....
Old 06-27-2006, 11:00 PM   #3
ToxinRS
Member#: 111266
2001 2.5RS
SRP
Buuuuuuuuuuuuuuump.....
Old 06-28-2006, 12:58 PM   #4
ToxinRS
Member#: 111266
2001 2.5RS
SRP
mid day bump
Old 06-29-2006, 12:48 AM   #5
ToxinRS
Member#: 111266
2001 2.5RS
SRP
bttt....
Old 06-29-2006, 02:34 PM   #6
ToxinRS
Member#: 111266
2001 2.5RS
SRP
Bumpity bump
Old 07-03-2006, 06:07 AM   #7
ToxinRS
Member#: 111266
2001 2.5RS
SRP
bump?
Old 07-06-2006, 06:02 PM   #8
ToxinRS
Member#: 111266
2001 2.5RS
SRP
Bump......
Old 07-07-2006, 12:15 PM   #9
ToxinRS
Member#: 111266
2001 2.5RS
SRP
Bump...
FS: Highly modded 91 Legacy Turbo Sti_044 NWIC Private Classifieds 4 11-05-2009 08:30 PM
FS: Highly Modded TD05-14b 91 Dodge Stealth R/T TT in NH ToxinRS NESIC Private Classifieds 3 07-09-2006 07:01 PM
FL FS: HIGHLY modded HPI RS4-2 Scoobiblue Jr. Private 'For Sale' Classifieds 3 03-29-2004 10:26 PM
FL FS: HIGHLY modded HPI RS4-2 Scoobiblue Jr. Private Vehicle 'For Sale' Classifieds 0 03-27-2004 03:37 PM
FS: Highly modded 2002 WRX paulw Private Vehicle 'For Sale' Classifieds 0 12-12-2003 05:09 PM
