Welcome to the North American Subaru Impreza Owners Club Friday July 28, 2017
Old 08-02-2006, 07:54 PM   #1
zzzzzxx
Member#: 18503
Have a Nice Day? Not real happy with my P Zero Neros
I have about 20k miles on them with my WRX and they are cupped badly on the inside. When installed I had them mounted and balanced and an alignment done. PSI should have been fine..never under inflated. I started hearing a noise and had a free rotation and alignment done. I have since then rotated them once more. The car drives straight and the steering wheel is perfect
So now I have 4 very loud tires Do these tires require this much attention? In the past I have had tires that require some air here and there and they wear just fine.
Looking to buy something else. Maybe something a little harder with a longer tread life. ( Even though these should have given me 40k+ miles) The noise is driving me nuts!
Any ideas/suggestions??
zzzzzxx is offline   Reply With Quote
Old 08-02-2006, 09:20 PM   #2
SCOOBY2.5RS
Member#: 66234
3G WRX-WRB
Scooby-X Monster
I have the same tires! with about the same milage or more. I do not have any loud noise when driving. Tire wear is not the best, but that is because I use them for autoxing everyweekend! Other than that wear seems to be normal! So far Im happy with the tires!
Have the tires rebalanced and aligned. Try taking it to another store to do the work. Could just be their settings.
Call up tirerack or the manufacture and tell them your delma! maby, just maby they will replace them!
Good luck!
SCOOBY2.5RS is offline   Reply With Quote
Old 08-02-2006, 09:56 PM   #3
wadejg
Member#: 41649
2004 Forester XTi
Sorry, but this is almost certainly an alignment issue. All alignments are NOT equal. Find out where your local autocrossers get their cars aligned and go to that shop to have them check out your current alignment and correct the problem.
Regards,
Justin Wade
2004 FXTi
wadejg is offline   Reply With Quote
Old 08-02-2006, 10:42 PM   #4
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
i had brought my car to 3 different places before i trusted the alignment...
I have the p-zero's and there is no loud noise from them. I do a lot of driving and the wear has been little since january. I keep the pressures at 40f/36r.
moogoob is offline   Reply With Quote
Old 08-02-2006, 11:35 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.....post some details so folks can help out. ......what size? .....what pressures are you running? ....what are your alignment specs? If you're "cupping", do you mean you're getting excessive wear on the outer edges of each tire? ......a sign of under-inflation btw.
I'm on my 3rd set (225/45/17's) and couldn't be happier. I killed my last set but that was due to an improper alignment.
Kean is offline   Reply With Quote
Old 08-02-2006, 11:43 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
love mine as well
rotate every oil change
and check pressures every gas fill up
i run mine at 40f/40r
cheers
Jamie
Old 08-03-2006, 12:06 AM   #7
Tgui
Member#: 44771
My last set of tires were neros. Perfect tires. Great for autox and track days. Worked well in rain and actually did well in the snow (I had the m&s version). They wore perfectly also.
Tgui is offline   Reply With Quote
Old 08-03-2006, 12:21 AM   #8
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
p zeros m+s own! ive got em on my 18" prodirve p1s for the winter and ive got no complaints.
AlxSti is offline   Reply With Quote
Old 08-03-2006, 08:21 AM   #9
SLKWrx
Member#: 8247
2016 Outback
2005 Lotus Elise
Yeah, I think you got a bad set or a bad alignment. I'm on my 3rd set and I've gotten no less than a very quiet and happy 50k out of each set.
SLKWrx is offline   Reply With Quote
Old 08-03-2006, 08:40 AM   #10
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
agreed !
Old 08-03-2006, 08:40 AM   #11
bull3964
Member#: 48928
'02 WRB WRX Sedan
'11 DGM WRX 5dr Premium
I will add that my Pzero Neros have gotten very loud in the past few months of their life, but I attribute that to the fact that for a long time I was running a significant amount of toe out before I had an alignment done which wore away the inside edges of the tires.
So, I will agree with most and say that even though you had an alignment done, it's still not right. Either that or the damage has already been done.
bull3964 is offline   Reply With Quote
Old 08-03-2006, 10:15 AM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
.....toe killed my last set and the resulting uneven wear was most certainly the cause for the "dartiness"/increased noise in my case.
Not too happy with my ATP 35R Simes Built Motor Discussion 8 04-23-2010 05:20 PM
FS:NY 16" OEM Rims with Pirelli P Zero Nero M+S Craigster05 Wheels/Tires 4 07-31-2009 02:05 PM
FS/FT: 17" Advan RG with Pirelli P-Zero Nero All Season lik VIC Private Classifieds 10 03-21-2009 02:11 PM
Not real happy with the brakes GPuglisi Newbies & FAQs 15 07-17-2003 12:37 PM
('93-'01) i'm not to happy with my car right now juggalo Impreza Forum 16 03-14-2002 10:24 PM
