Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 08-16-2006, 10:01 AM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default playing around with tire sizes: 215/40-17 and 215/65-16
it's getting time to order new shoes for my ride, for both seasons. here's some of my latest reasoning:
proposed summer tire is 215/40-17. compared to oem 205/55-16, i'll lose about 1" of overall diameter, so ride height will be reduced by ~0.5". that's also about a 4.4% decrease in circumference ratio.
my current summers are 225/45-17. these proposed tires will be 1.2" smaller diameter, so a drop of 0.6", and a 4.8% difference in circumference.
proposed winter tires are 215/65-16. compared to oem 205/55-16, i'll gain about 2.1" of diameter, so ride height will be increased by ~1", and 8.5% increase in circumference.
compared to proposed summer tires there's a 3.2" difference in diameter, so ride height will be different by ~1.6" and yeild a 13.6% difference in circumference.
why all of this?
summer:
low profile for quick response
low ride height for improved stability
smaller circumference for lower effective gear ratios
less rubber weight for quicker acceleration
winter:
taller profile for better contact patch
increased ride height provides ground clearance for obstructions/snow/etc.
larger circumference for higher effective gear ratios
in the winter i don't care about "high performance" tires nearly as much as i do in the summer. i care about traction and ground clearance. i actually take more long highway trips in the winter as i am a skier, so a taller gear ratio would come in handy for economy. i don't toss the car into corners, in fact i go so far as to reduce negative camber to improve overall traction at low speeds. i've even disconnected front and rear sway bars when it's really nasty out.
in the summer it's time to tear it up. dial back in the camber, and every entrance/exit ramp is a skidpad.
as far as load ratings, i'm pushing things a bit with the 215/40-17, but it's not unsafe.
has anyone tried such drastic tire sizes for their winter/summer choices? if so, were you happy with your decision(s)?
ken
Old 08-16-2006, 10:16 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
how about 1 notch narrower on the winter tire? might save some money and get a better tire at the same time. (for most conditions a narrower winter tire is better)
Old 08-16-2006, 11:08 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i was looking at that, but there aren't a lot of options for winters with a 65 profile and a 205 section width. narrower is better in the winter.
Old 08-16-2006, 01:19 PM   #4
rkkwan
Member#: 5596
2010 Honda Fit Sport
Watch the load ratings on those 215/40R17s.
rkkwan is offline   Reply With Quote
Old 08-16-2006, 06:34 PM   #5
Boxologist
Member#: 21118
u will probably rub with the winter tyres when lowered. probably even if u are not lowered.
Boxologist is offline   Reply With Quote
Old 08-16-2006, 08:10 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
boxy, what is it in particular that i should be concerned with wrt rubbing? tire to strut/spring perch?
ken
Old 08-16-2006, 08:58 PM   #7
waktasz
Member#: 86356
2016 Aprilia
Tuono v4 1100 Factory
Are you concerned about highway cruising gas mileage or resale value? You are going to rack up a lot of miles quickly with a tire size that small. Regardless, I'd go 245/35
waktasz is offline   Reply With Quote
Old 06-07-2007, 12:03 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
fwiw, eventually went with 215/40-17 falken fk452s for summer tires. http://forums.nasioc.com/forums/show...&postcount=109
indicated speedometer is 5% low according to GPS. 1mph low for every 20.
having lighter, smaller diameter tires has proven to be pretty sweet so far. i keep the pressure around 40psi for a bit of extra bump
the winter shoes are 205/60-16 hankook icebear w300. http://forums.nasioc.com/forums/show....php?t=1205596 there's an 8% circumferential difference between the two.
Old 06-07-2007, 02:32 PM   #9
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Nice use of your brain Ken....exactly the kind of thing I'd expect from you. I'm using 205/45-16s year round. 4.16 final drive FTW!!!
Old 06-08-2007, 11:08 AM   #10
waktasz
Member#: 86356
2016 Aprilia
What's with all you skinny minies?!?!
205s ewwww...I'll never go back!
Old 02-20-2009, 06:50 AM   #11
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
I'm also considering going with a 215/40-17 in the FK452.
Currently running 235/40-17 FK452 on 7.5" wide wheels and I'd really like the gearing advantage for my hybrid setup <--- crazy TQ down low = shockload.
Spenk is offline   Reply With Quote
Old 05-17-2011, 05:14 PM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
FINALLY pinched one of the 215/40-17 fk452s yesterday in a monster winter pothole.
thankfully enough tread wear not to make me cry at replacing all 4.
unfortunately that seems to be a tough size to find widely available. i might end up going back to 225/45s (huge ****ing balloons! lol)
Old 05-17-2011, 08:44 PM   #13
Spenk
Member#: 7164
2000 Miata LS
In another 2 years you can post up and let us know with what tires you replaced the Falkens!
FS: NEW PRICE!!! new Toyo R1R tires, 2x 235/40/17, 2x 215/45/17 RandomFocus SCIC Private Classifieds 39 09-03-2009 02:05 PM
WTB/and used tire in 245/40/17 and/or 255/40/17 RandomFocus SCIC Private Classifieds 8 08-20-2009 04:18 PM
F/S: 2 proxies T1-S 215/40/17 and ... Fleek04 Vancouver Impreza Club Forum -- VIC 2 05-21-2006 09:48 PM
215/40/17 Vs 215/45/17 ommmjido Tire & Wheel 2 07-08-2003 09:19 AM
215/40/17 or 215/45/17? moss Brakes, Steering & Suspension 14 10-19-2002 02:22 AM
