Welcome to the North American Subaru Impreza Owners Club Saturday October 20, 2018
Old 10-27-2001, 01:24 AM   #1
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
Default wrx not getting into gear, why??
recently when i punch my car and shift, its been getting stuck and not going into gear. before when i punched it i never missed a gear but starting two days ago i missed three times during a race. and three more times today, is it me or is it the car? it seems like im doing everything the way i use to so it should go into gear. please help
dennis
datdudedennis is offline   Reply With Quote
Old 10-27-2001, 03:44 AM   #2
Xsara
Member#: 9212
when ever i go really high rpms i like to double clutch ... you would shift a second later but you won't happen to miss it ...
it probably has to do with the engine speed and the layshaft speed... you gotta match them for it to go in gear
Xsara is offline   Reply With Quote
Old 10-27-2001, 04:38 AM   #3
Bottle
Member#: 739
02 WRX
Midnight Black Pearl
Today i had the same problem at the track i ran twice and it would not let me into 3rd once and 2nd once.
What i figured out is that since the tranny fluid was cold and not warm and flowing, it caused this problem, so on my 3rd run i kep the car running and drove through the lines, and the tranny was easy to shift.
Maybe this is the problem, I might change out my tranny fluid with something like redline d4atf or something like that.
Bottle is offline   Reply With Quote
Old 10-27-2001, 03:01 PM   #4
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Talking Teehee.
Take it to your local friendly dealer and tell them that, ever since you started racing, you've been having problems getting the car into gear. I'm sure they'll look at it under warranty!
Fear the Trunkmonkey. There is no cone.
http://www.trunkmonkey.com/ | [email protected]
Automotive Reviews by Sean | What is a Trunkmonkey?
Somebody set up us the WRX. All your rice are belong to us!
Sean is offline   Reply With Quote
Old 10-27-2001, 08:10 PM   #5
loanshark
Member#: 7875
2005 Impreza WRX STi
Exclamation
Hey Dennis, let me guess, you go to Westfield right? I drive the other black one (with the SSRs). How many miles do you have in your car so far? If it's broken in, I'd like to run with your a couple of times.
loanshark is offline   Reply With Quote
Old 10-27-2001, 10:01 PM   #6
Sean
Member#: 518
762 PGT Impreza L,
Talking Guh.
OK, since no one has answered yet, I'll toss in a serious answer. When you shift, the stick moves a little bit, the synchros kick in and, once the synchros sync up the drive shaft to the rest of the tranny, the stick moves the rest of the way into gear. At high RPM shifts, that's that notchy feel before the stick "clicks" into place.
If you rev too high and don't give the synchros enough time to do their job, it's difficult to force the stick into place. Since you can't move the stick any farther and it's only half engaged, it feels like it won't let you go into gear. Try giving the engine a little longer to rev down so the synchros have a little more time to work. Also, make sure that the clutch is fully depressed.
Old 10-28-2001, 06:45 PM   #7
loanshark
Member#: 7875
bump
2010 wrx would not go into gear whatsoever awdpower91 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-02-2010 09:32 PM
Why would WRX not get a spark? AWDsub Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-17-2009 06:57 PM
the 24 hours not getting OT: was i the only one that could not get into here? NJSwamplands Off-Topic 1 03-14-2008 03:20 PM
05 wrx 5mt somewhat difficult to get into gear scooby_x Transmission (AT/MT) & Driveline 4 12-22-2005 10:17 PM
Anyone have problems w/ not being able to get into gear when the car is cold? GTBGUY Normally Aspirated Powertrain 27 12-21-2000 10:43 AM
