10-29-2001, 02:06 PM | #1 |
Member#: 8721
Vehicle:1999 2.5 RS Rally Blue |
Suggestions ?
I am looking for some more power in my 99 RS. Crrently I have Borla Exhaust, S-AFC, Underdrive pulley, and a K&N Cone filter. I do not neccesarily want a huge increase in power(Though I wouldnt mind) I am curious what relativly easy N/A mods (No headwork) could I do to get a noticable power increase? Would headers or a new, more complete intake be worthwhile? Or would I be better off just saving my money and going for a small turbo later on. Thanks for your help.
-Brandon
10-29-2001, 02:17 PM | #2 |
Subaru Bounty Hunter
Moderator Member#: 7131
TXIC
Vehicle:2015 Outback - Croc Dundee Edition Ice Silver |
If you are disciplined enough, save up for the turbo, but done correctly, you are looking at $6-8000. Gotta buy the turbo, new engine management, lower compression ratio, new exhaust (at least 2.5", 3 is better). That will be a big power gainer. If not, get an intake. I can get you instructions to convert cobb intake for the MAF, or you can talk to Larry Ganz about his weapon R conversion, which has the PRM filter like the Cobb. This filter is awesome, and will give you around 7-10hp and pull all the way from idle to redline smoothly!
Headers are nice if you don't want to turbo down the line... Rob |
10-29-2001, 02:18 PM | #3 |
Celebrity Guest Star
Member#: 10648
NESIC
Vehicle:2008 Acura TL Wicked Black |
Headers seem like the next step for you. Don't know if it would really be worth the $$$ unless you're real serious. I'm saving up for a turbo myself. EJ25 + turbo = . about 5-6K for a complete Vishnu system. yee haw. still, if you've got a couple hundred bucks to blow, go with the headers. Also, engine and tranny mounts help out, I've heard. less drivetrain flex should make it feel more solid and a little more responsive.
-IggDawg |
suggested COTS cam suggestions | atech_rallyrs | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 02-06-2008 04:06 PM |
Need suggestions on making good mashed potatos. Suggestions? | ChosenWon | Off-Topic | 36 | 11-27-2003 12:29 AM |
('93-'01) Exhaust shakes alot... any Suggestions? | kaos200 | Impreza Forum | 10 | 05-03-2001 04:05 PM |
('93-'01) Need suggestions... | Tats | Impreza Forum | 0 | 04-23-2001 09:35 AM |
('93-'01) suggestion | bryanw | Impreza Forum | 0 | 04-06-2001 11:01 AM |
