Welcome to the North American Subaru Impreza Owners Club Thursday February 27, 2020
Old 09-07-2006, 11:30 AM   #1
USAFA08
Member#: 79585
2004 Impreza WRX
Default Cutout vs. Regular Exhaust
So right now i'm running a HKS 3'' downpipe with a qtp cutout. Here's the problem, i've had alot of problems with the wires rubbing against the driveshaft and the switch shorting out. So i'm wondering if anyone thinks i would be better off with a regular TBE, if so, any suggestions as to which one?
USAFA08 is offline   Reply With Quote
Old 09-07-2006, 11:50 AM   #2
intence
Member#: 58477
. Member #1 of
the witty MS Crew
i like my cutout but i also have a tbe. why dont you just tape the wires to underneath or something.
intence is offline   Reply With Quote
Old 09-07-2006, 11:54 AM   #3
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
I too love my cutout. I have my wires ziptied in about 20 different spots to keep them away from the driveshaft and hot downpipe. Don't give up the cutout. If anything, switch to a unit from www.badlanzhpe.com .
D-Speed 2.5 is offline   Reply With Quote
Old 09-07-2006, 05:45 PM   #4
intence
Member#: 58477
. Member #1 of
the witty MS Crew
or DMH.
Old 09-17-2006, 07:10 PM   #5
blubaru2002
Member#: 104883
2002 wrx sedan
wrc blue
is there any performance gain from running a cutout on a wrx or is this strictly for the sound????
i tried running with an open downpipe and i felt a tremendous loss of low end torque. Maybe you have to be tuned with a cutout for it to make power or am i just missing something?
blubaru2002 is offline   Reply With Quote
Old 09-17-2006, 07:16 PM   #6
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
Sedona Red Pearl, Carbon
I had this same problem, no low end power. I dunno, I prefer the catback anyway minus the exhaust tickets.
Mustang Raper is offline   Reply With Quote
Old 09-17-2006, 09:31 PM   #7
SINthetic
Member#: 53775
03 WRX
There is no low end tq loss with a cutout. Its a myth. Turbo cars do not want anything to do with a cat back. All the fastest turbo cars just run a striahgt pipe. My qtp cutout gives me 1.5 more boost across the board and now low end. www.quicktimeperformance.com
SINthetic is offline   Reply With Quote
Old 09-17-2006, 09:55 PM   #8
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
i dont claim to be the smartest person on these boards, but i dont get this.
he says it gives him 1.5 more boost? how is that possible just from a cutout? shouldnt the boost stay at a controlled point, unless its spiking?
David Medina is offline   Reply With Quote
Old 09-18-2006, 02:23 AM   #9
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
Put it this way you get the exhaust gasses out quicker the quicker the turbo can spool the quicker you can build boost
trxdam is offline   Reply With Quote
Old 09-18-2006, 03:19 AM   #10
swatornot04
Member#: 118745
2003 WrX
Sonic Yellow
now im not a genius when it comes to this stuff either but...getting the exhaust out faster that would just allow him to get to boost quicker. He should be controlled and reach his maximum faster but it would be the same max with or without the cutout.
just my two cents
swatornot04 is offline   Reply With Quote
Old 09-18-2006, 12:41 PM   #11
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
+17whp and +25wtq on an EJ205 with a Super 16G. Closed was 284whp and 290wtq. Opened was 301whp and 315wtq. Plus the entire curve shifted to the left, meaning more power and torque at earlier RPMs.
Old 09-18-2006, 01:15 PM   #12
t3hWIT
Member#: 58779
95 STi RA (rhd)
09 Tacoma
Not a bad price neither. Have any of you guys had problems with it leaking at the valve?
t3hWIT is offline   Reply With Quote
Old 09-18-2006, 01:28 PM   #13
sexualtyranasaur
Member#: 114998
i have the mooneyes cut out. i have had it since 2002 with absolutly no problems. i run a fmic on a tdo4, with the cutout closed i hit full boost before 3000 rpm and max at about 17 psi in 4th and 5th. with it open i hit 19 psi at 2700 rpm. it spools quicker and holds a higher boost. there are NO downsides performance wise to a cutout. i have raced cars with idencical mods only they run a muffler. i walked them, i pulled constantly, i had better low end and better top end.
sexualtyranasaur is offline   Reply With Quote
Old 09-18-2006, 01:44 PM   #14
InfamousDX
Member#: 25413
You ever post a dyno sheet for that?
Old 09-18-2006, 02:28 PM   #15
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
+12345
jdgrimm is offline   Reply With Quote
Old 09-18-2006, 02:34 PM   #16
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
The dif is quite simple... if you are building boost you are going to make more power w/o a muffler then if you had a muffler. Off boost, esp from a stand still you will not since your torque is drained untill you hit boost. My butt dyno proves this
TheShad0w is offline   Reply With Quote
Old 09-18-2006, 03:56 PM   #17
SubNiSmO
Member#: 104417
2007 STi
White Satin Pearl
i have qtp cutouts as well running through my oem exhaust, when open i feel a great deal of difference especially after my tune, imo open downpipe is the best route to go for top end powar!!!! "
SubNiSmO is offline   Reply With Quote
Old 09-18-2006, 04:52 PM   #18
blubaru2002
Member#: 104883
2002 wrx sedan
wrc blue
it seems to me that there is no consensus on what exactly these do. one guy says more torque and more horsepower down low but he doesnt have a dyno graph. Are the gains from these cutouts only happening to pple with larger than stock turbos?
other pple i hear from say better top end power.
And now other pple say that they hit higher boost psi when its open also
Old 09-18-2006, 05:56 PM   #19
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
I would imagine that larger/aftermarket turbos would magnify the power gained from an open/cut out exhaust. I personally have a stock turbo, the most gains are felt under moderate-full throttle.
Old 09-18-2006, 07:19 PM   #20
scubyslacker
Member#: 44124
2008 STI
Darren, are these numbers your talking about from my setup? If it is, you got the numbers a little wrong. The whp numbers are correct, but the wtq is 264 w/ the cutout closed and 299 w/ the cutout open. Also, these numbers were on a 100F+ degree day with most likely heat soak.
This is with a badlanzhpe cutout (same as D-Speed 2.5 who convinced me to get it) welded into an ebay replica turboxs race pipe with the rest of the txs tbe system, Super16G, ssautochrome tmic and other supporting mods.
I've got the dyno charts, which i can post later. Stupid question though, how do I post the dyno charts?
scubyslacker is offline   Reply With Quote
Old 09-18-2006, 07:25 PM   #21
wrxzboost
Member#: 86322
was the car tuned with the cutout open and closed? because if you tune with car with the cutout open and then just dyno it by closing it; no **** your gonna get totally different numbers. just to make sure...
wrxzboost is offline   Reply With Quote
Old 09-18-2006, 07:30 PM   #22
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
does the cutout cause too much turbulance when closed?
distorto is offline   Reply With Quote
Old 09-18-2006, 07:55 PM   #23
scubyslacker
Member#: 44124
2008 STI
Well, my car was originally tuned with the cutout closed and then when I got my cutout working properly my tuner said he adjusted the timing a little so that I could run with the cutout open or closed on the same map on my UTEC. This way I wouldn't have to change maps when I want to open the cutout.
Do you mean the little pocket that is created when the cutout is closed? I asked about this on this forum a few months back when I was researching the cutout and was told it was so small it wouldn't affect anything. This is just wait I was told though.
Old 09-19-2006, 12:06 AM   #24
InfamousDX
Member#: 25413
Scan them, host them on a free pic hosting service, and post them here using those [img] tags.
Those are quite the gains... I'm guessing the hot hot day actually hindered the closed system much more than average.
EWG dumped VS. electric exhaust cutout DNFWM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-11-2010 04:28 PM
Official official vs unofficial vs regular threads debate BBkidLy Texas Impreza Club Forum -- TXIC 18 03-05-2009 06:15 PM
Cutout vs. EWG? illini_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-13-2007 09:14 PM
cutout vs. conventional exhuast USAFA08 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-29-2006 12:42 PM
Whiteline vs regular no roll bar Gambit Technical Forum Archive 2 07-27-2000 10:59 AM
