Welcome to the North American Subaru Impreza Owners Club Sunday April 23, 2017
Vancouver Impreza Club
Old 09-24-2006, 05:22 AM   #1
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
Default fuel gauge screwy?
this is not the first time i've noticed this, it has happened a few time already... what happens is, when ever i fill up a full tank of gas, and start to drive off, the fuel needle is never at the max point!? it takes a few start ups and turn offs for it to read max out... i'm sure the fuel tank is at full cause evey time i when i fill up i try to top off my tank and make an even number... this kind of makes me concer when i'm low on fuel... what if i near empty and the needle s still 1 bar from empty!? scary...
RX Renesis is offline   Reply With Quote
Old 09-24-2006, 05:53 AM   #2
rs_two_five
Member#: 99206
2007 WRX STi wagon
Ducati Hyperstrada, WR450
generally if your having a fuel level issue, its not the indicator (gauge) its 98.9% of the time the master fuel level sender in the tank. The one thats attached to the same arm as the fuel pump. Unfortunately that part is generally very expensive to buy, so you may want to try and clean with a light emery cloth (gently) the pickups on the unit itself. If that doesn't work.. then.. replace it.
One way to test it, is to measure the resistance of the unit, and see if the readings move smoothly from 0-35ish ohms.. unfortunately it involves removing it from the tank, and I'd much rather replace if i'm going to that much effort to test.
hope this helps, Sean-
rs_two_five is offline   Reply With Quote
Old 09-24-2006, 10:44 AM   #3
Picard
Member#: 100204
2006 STI (retired)
Try some fuel system cleaner in your tank before you start replacing things. It's always worked for me in my other cars.
Picard is offline   Reply With Quote
Old 09-24-2006, 12:38 PM   #4
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
It's usually a better idea to ensure that your tank is topped off and then pay attention to the number of kilometres on the tank. Way more accurate than estimating from the fuel guage. Maybe that is just the pilot in me talking (fuel guages never seem to work well in airplanes, go figure)
shawmacs is offline   Reply With Quote
Old 09-24-2006, 01:48 PM   #5
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
rs_two_five & Picard...he's got an '06 STi! Should he really be taking the fuel sender unit out and sanding it, or using fuel system cleaners??? How about the dealership for the warranty you paid for?
Might have to take off that TBE first though
semaj is offline   Reply With Quote
Old 09-24-2006, 02:03 PM   #6
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
^^ I concur; a TBE will definitely impact the proper operation of the fuel level sender. Subaru research indicates they are sensitive to loud noise. No warranty for you!
Old 09-24-2006, 02:56 PM   #7
semaj
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
haha, I didn't mean the TBE will ruin the fuel gauge...just the dealer might give you a hard time about mods, that's all. Fine, leave the TBE on...and go to the dealer to get your fuel gauge looked at.
Old 09-24-2006, 03:52 PM   #8
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
well so far i went to the dealer twice for service and they seem fine with it... and i've see other STis there with mods on and they seem fine with it...
Old 09-24-2006, 03:58 PM   #9
semaj
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Ok then, get them to take a look at your fuel gauge then!
Old 09-24-2006, 08:46 PM   #10
rageguy
Member#: 119278
service and warranty are different. you can drive a heavily modded subaru to the dealership for a basic service/maintenance and they wont bug you about it, because you are paying for it.
but with warranty, some dealership will try to blame the problem on your modifications, to avoid doing the warranty work for free.
good luck rice renesis!
rageguy is offline   Reply With Quote
Old 09-24-2006, 11:11 PM   #11
ghostfoot7
Member#: 61040
dead sexy blue!
wow.. that is a very disconcerting piece of knowledge!!!
How much fuel we got left? Well it says quarter tank so we could be empty.....
ghostfoot7 is offline   Reply With Quote
Old 09-24-2006, 11:12 PM   #12
semaj
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
oooh, I hope you are a friend of his
Old 09-24-2006, 11:42 PM   #13
rs_two_five
Member#: 99206
2007 WRX STi wagon
oh shiznach.. yeah posted that when i was a little tired.. but i agree.. take it to the dealer being as though its soo new.
Old 09-25-2006, 12:16 AM   #14
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
i have no idea who he is... i think he wants a beatting...
Old 09-25-2006, 01:04 AM   #15
semaj
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Hehe, now you're sounding like Dalton!
Old 09-25-2006, 01:09 AM   #16
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
Dalton with his poor speelang?
Old 09-25-2006, 01:12 AM   #17
semaj
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
He can't help it...he's ESL
Old 09-25-2006, 02:02 AM   #18
veightkiller
Member#: 78967
2011 335i
im not having that kind of problem on mineyour best bet is take it to the dealer and get it check.
veightkiller is offline   Reply With Quote
Old 09-25-2006, 02:35 AM   #19
banman
Member#: 12408
2006 Legacy GT
The way I'm interpreting his "problem", it sounds totally normal. It usually takes a while for the fuel gauge to fully max out (i.e. go above "F"). I'm not sure this is something he should be worried about, unless his gauge is reading 1/2 or 3/4 when he has a full tank.
banman is offline   Reply With Quote
Old 09-25-2006, 03:29 AM   #20
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
well ever since day 1, everytime i fill up my tank to the max the gauge reads max right after i start it up, but lately(the past 3 times i've filled up) it doesn't max out anymore right when i start it up... it takes a few start ups to get it maxed out... so i dono if it's normal or something is acting up...
Old 09-25-2006, 03:34 AM   #21
rageguy
Member#: 119278
honestly, just take your car to the dealership and ask, they shouldnt blame it on the exhaust you have. its your best option. you've had the problem since a while ago...2 weeks i think? time to get it checked out =p
no i dont know rx =p
Old 09-25-2006, 02:06 PM   #22
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
dealer ftw! my TS used to take about 30 seconds to reach full. but it got there.
FunkMasta is offline   Reply With Quote
AEM Boost Gauge and AEM Air/Fuel Gauge FknQikly Engine/Power/Exhaust 24 02-12-2010 04:39 PM
AEM Tru Boost Gauge,AEM UEGO Air/Fuel Gauge,Duel Gauge Dash Bezel jester696 Interior/Dressup/Audio & Security 11 06-21-2009 08:04 AM
AEM Tru Boost Gauge,AEM UEGO Air/Fuel Gauge,Duel Gauge Dash Bezel jester696 Interior/Dressup/Audio & Security 0 05-01-2009 06:02 PM
FS: DFW - Boost gauge, air/fuel gauge, tachometer w/ shift light integralus TXIC Private Classifieds 2 03-05-2009 07:01 PM
air/fuel gauge vs. EGT gauge kaidoy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-02-2001 10:00 PM
