#1 |
Member#: 17346
South East
Vehicle:08 Cayman S White |
![]() For those who are swapping in 6-speeds into the a WRX
Since the 07 Spec B has the r180 diff with the six speed and the bolt patern for the wheels is the same as the WRX (5x100) I think the 07 SpecB axels would work on a WRX and r180 without having to swap hubs. But I'm not sure if Legacy axels are longer then Impreza axels. any thoughs?
#2 |
Member#: 7022
Vehicle:2001 Forester Arcadia green |
![]() the 07 uses a 5x100 setup?! What rear brakes are on the spec B?
I am gonna have to make a trek to the local dealership and investigate this. Its this or DSS r160 hubs to r180 dif axles. |
#3 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
![]() The brakes are the same as the LGT. Ill peak at the 07 spec-b, its like 10 feet from me
#4 |
Member#: 2272
BAIC
![]() I cant tell on the axles. The rear does look like an R180 though.
#5 |
Member#: 2272
BAIC
![]() Alright, the FRONT Spec-B 6-speed axles are the same as the LGT axles. REARS are different.
#6 |
Member#: 17346
South East
![]() The 07 uses the same wheels as 06, which are 5x100. Can you check the rear axels of the SpecB vs STI?
Keep in mind, factory SpecB axels probably cost as much as the Driveshaft Shop (I have no nubmers I am just speculating) |
#7 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
![]() are you sure the spec b has the r180 ...
its not the bolt pattern thats differnt/the proublem is the diamater/spline count of the axel/hub |
#8 |
Member#: 2272
BAIC
![]() Spec-B rear diff: 1.1qt capacity, helical LSD.
STI rear diff: 1.1qt capacity, mechanical LSD. Every other rear diff has a .8qt capacity... Its a R180. I cant tell about the rear axles yet though, still ressearching. (Im not using part numbers btw, im using the tech documents) |
#9 |
Member#: 2272
BAIC
![]() Rear axles...
Spec-B: EBD+DOJ, .87in Diameter, 375.1mm length STI: EBD+EDJ, .98in diameter, 316mm length So no, they are not the same. |
#10 |
Member#: 7022
![]() whats the length of RS axles?
#11 |
Member#: 2272
BAIC
![]() What year?
#12 |
Member#: 2272
BAIC
![]() Odd, im looking at 03 axles, and the rear axles on the 03's are not the same length on each side
#13 | |
Member#: 37190
RMIC
Vehicle:01 Ford SCrew |
![]() Quote:
#14 |
Member#: 7022
![]() Well I gotta pull my axles out and see what they are. I think they are 00 rs axles. (lsd).
I have a v4-6 RA 4.44 r180. I would love to just grab some spec B axles and have them fit. But for somereason, I am doubting this. Anyone work for a dealership and wanna loan me some axles. I can test them out. If they work, i'll buy them ![]() |
#15 |
Member#: 2272
BAIC
![]() Most axles like that arent stocked, they would have to be special ordered (there are far to many kinds of axles to keep in stock).
The spec-b axles wont fit, I can tell you that for sure. They are 7cm longer than STI axles... |
#16 |
Member#: 17346
South East
![]() that's what I was afraid of, thanks for looking into this though
#17 |
Member#: 2272
BAIC
![]() Oh, and dont forget that since 2000, Legacys have had the multi-link rear suspension and COMPLETELY different rear hubs than Imprezas...
#18 |
Member#: 19396
Vehicle:02/6 FrankensteinWRX black |
![]() what is the gear ratio on the spec B r180 diff?
#19 |
Member#: 2272
BAIC
![]() 3.545 with 39/11 gear teeth.
#20 |
Member#: 19396
![]() so i will assume this can be techincally a upgrade for a wrx rear end, that is planning to still use stock tranny. (but remembering to use a sti rear axles and brembos and hubs)
#21 |
Member#: 2272
BAIC
![]() Might work, im not sure if the spec-b helical LSD has different splines than the STI LSD though... Ill have to check that next week.
#22 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
![]() are you saying these spec B's will fit my BE? hmmm.... I need an R180, then again they likely won't hold 600whp either.
Ben |
#23 |
Member#: 2272
BAIC
![]() I dont know if the BE hubs are the same as the current gen hubs, but ill check that too...
#24 |
Member#: 2272
BAIC
![]() I can't tell if the spines are the same or not between the spec-b and sti.
Looks like the rear hubs are the same, or at least the rear suspension components are on the 2000-04 legacys and 05+ legacys. |
#25 |
Member#: 72234
South East
Vehicle:2004 WRX SRR EJ257-35R-6MT |
![]() how thick are wrx rear axles? Early 04 model... If they are the same thickness as the spec b axles couldnt you swap the center axle portion with just the cv inner/diff side components?
WTT. jdm 6-speed for 07 6-speed | WrXtaCy2003 | Drivetrain | 15 | 09-08-2009 12:51 AM |
07 6 speed swap | BoostN420 | Private 'Wanted' Classifieds | 1 | 09-06-2009 04:44 PM |
Brand New Complete 07 STI 6 Speed Swaps for WRX, all necessary parts included! $4450 | P&L Motorsports Inc. | Drivetrain | 14 | 12-03-2008 12:44 AM |
6 speed swap into 06-07 wrx | rendog24 | Transmission (AT/MT) & Driveline | 29 | 04-22-2008 02:36 AM |
use old 5 speed slave cylinder in 6 speed swap? | DoctorNick | Subaru Conversions | 6 | 01-16-2005 10:34 PM |
