Welcome to the North American Subaru Impreza Owners Club Wednesday February 19, 2020
Old 10-20-2006, 08:22 PM   #1
markreda
Member#: 89560
Question Exhaust Bypass Valve?
Would one of those "Exhaust Bypass" be a performance improvement on a 02 WRX?
I don't know the correct term for the exhaust bypass I'm reffering to.
It looks like a "Y" pipe that replaces a section of the exhaust after the cat and allows the exhaust to leave the system before the resonator & muffler.
Does anyone know the correct name for it?
Or a manufacturer?
markreda is offline   Reply With Quote
Old 10-20-2006, 08:43 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Exhaust Cut Out...atpturbo has one and QTP, and badlanzhpe has one.
wrxdrvr is offline   Reply With Quote
Old 10-20-2006, 10:15 PM   #3
SINthetic
Member#: 53775
03 WRX
SINthetic is offline   Reply With Quote
Old 10-21-2006, 11:51 AM   #4
markreda
Member#: 89560
The one you suggested is a complete downpipe.
Anyone know of an exhaust cutout that can be inserted anywhere in the exhaust? Ideally I'd like it to terminate behind the driver (now I'm just being picky).
Old 10-21-2006, 02:52 PM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
As was suggested QTP has one, you can get without the down pipe...ATP has one http://www.atpturbo.com , and badlanz has one http://www.badlanzhpe.com/ You just need to look.
Old 10-21-2006, 06:32 PM   #6
nitro
Member#: 29293
1990 BeeGTR BN32R4
Red
Default exhaust dump
I got one from summit racing and fabed it up myself, I could dig you up a picture if you want. I used a perrin DP (cattless) and right before the pipe bends up towards the back of the car I cut the exhaust pipe off, welded on a 3 bolt 3" Flange, bolted the dump on and put an angled piece below that to protect the butterfly flap, and make the pipe flush to the ground, just a little bit higher than the subframe.
Then just above the valve I welded in a 2 1/4 (same as stock) and wraped it around and welded it back inline with the stock exhaust just before the second cat.
I like summit racings because the valve is variable the amount that you can open and close it to make it a little louder or screaming.
One problem is I have a wideband o2 just above it and I think that there is too much velocity and It f*cked up my sensor. Either that Or it's my BOV making the car backfire after I shift and It burnt my sensor. I'll find out as soon as I put a new one in.
Almost forgot
I find that the bypass helps performance, because you can have it closed to give you bottom end torque, and open it up to give you 0 backpressure for up top.
As well I go from 13PSI to 15.5PSI when I open it up (I also have perrin's boost solinoid)
nitro is offline   Reply With Quote
Old 10-21-2006, 06:40 PM   #7
nitro
Member#: 29293
1990 BeeGTR BN32R4
Red
oppss
Old 10-22-2006, 12:38 AM   #8
onesixnin
Member#: 50992
09 Tribeca
Worst subaru blue
I have mentioned the cutout here on this site. Take a look at the mccord powerplate. It is not nearly as pricey as some of the other ones. The quality it there. Different switch and lighting options. Sometimes it does *feel* as if it has more power from it, but I have not tuned my car at all. So really, I probably lose low end grunt, maybe gain some quicker spool and everything in between is probably thrown off from lack of tune (I get hesitations sputters etc). However, the sound is unbeatable, you can make it quiet, and is a lot cheaper than a full turboback.
onesixnin is offline   Reply With Quote
Need to buy stock recirc valve, bypass valve, blowoff valve, whatever u call it!! newbie-subie SCIC Private Classifieds 2 02-12-2009 04:35 AM
04 Stock Bypass valve and 04 Full Exhaust!! CHeap! Texas Money Engine/Power/Exhaust 19 07-20-2008 09:25 PM
Stock STI Bypass Valve or a stock WRX Bypass Valve ASAP! Aleksey Private 'Wanted' Classifieds 1 11-04-2005 02:46 PM
Bypass Valve vs. Blowoff Valve kid 13 Normally Aspirated with bolt-on Forced Induction Powertrain 7 04-30-2002 09:53 AM
