Tire & Wheel Forum sponsored by The Tire Rack |
10-24-2006, 09:17 PM | #1 |
Member#: 10188
Vehicle:2007 Forester XT |
Changing offset by milling - safe ?
I've wondered if this would safely work since I went from VW to Subaru. I had a mint set of Kosei wheels on my Jetta. Both the Subie and the Jetta are 5x100 but the offsets are different. Since the VW offset (38) sticks out further than the Subaru what I want to know is Could I have a metal shop mill the wheel to change the offset to a "Subaru-friendly" offset such as 48 ?
It sounds simple enough, remove enough material and you can correct the offset. However, will this work and would it be safe ?
10-25-2006, 12:12 AM | #2 |
Member#: 39086
NWIC
Vehicle:2004 STi White |
Is there 10mm of thickness of extra material in the wheel flange?
How well can the machine shop index off the tyre bead to the hub face to keep things true? The first is an engineering judgment / wheel design issue. The second is just flat dam hard to do. For 4 rims. Better off to sell the VW wheels and buy some that fit your Subaru. |
10-25-2006, 12:17 AM | #3 |
Member#: 60082
Vehicle:2004 Forester STI Silver |
You funny. From an engineering standpoint, the RED FLAGS are waving. I'm curious how many wheel engineers would cringe at your statement. Um...DANGER, DANGER Will Robinson! I'm just saying...10mm is A LOT, getting close to half an inch. |
10-25-2006, 02:05 AM | #4 |
Member#: 39086
NWIC
Doctor Smith:
"Go a head Will. It's cheap and easy..." Given automotive wheel design there might be 10mm in the flange... There is a reason that offset is critical. Both for wheels and hubs. Let alone king pin offset... |
10-25-2006, 09:58 AM | #5 |
Member#: 13856
Vehicle:04/5 STI white/WRB |
NO!!!!
When we machine the wheels, the PCD hole depth is dependent on the offset. When you remachine the mounting face 10mm, you will essentially lose the PCD hole depth and your nuts will nut reach minimum thread engagement. |
10-25-2006, 10:39 AM | #6 | |
Member#: 26638
Unless he is talking about milling away the road side of the wheel, which would not make any sense to do. Either way, it's unsafe to do. |
10-25-2006, 08:18 PM | #7 |
Member#: 10188
Interesting comments guys , so Mr. Rota you're saying you drill the lug holes after the wheel is milled for offset ?
15 mm spacer on 52mm offset wheels ? How safe ? | Serkan | Tire & Wheel | 20 | 09-15-2009 04:42 PM |
is it possible to change offset my milling down the center of the wheel? | azn2nr | Tire & Wheel | 8 | 08-25-2006 12:55 AM |
How can you tell the offset by looking at a rim? | step down | Tire & Wheel | 1 | 07-20-2006 11:47 PM |
change offset by machining rim? | zakats | Tire & Wheel | 7 | 10-07-2003 06:47 PM |
Sparkplug change...all by myself... | Firewire | Vancouver Impreza Club Forum -- VIC | 13 | 06-11-2001 11:15 PM |
