Welcome to the North American Subaru Impreza Owners Club Sunday September 27, 2020
Old 11-02-2006, 03:26 AM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default Gt52 Turbo - Internal WG vs. EWG - Dyno Flash Case Study
Last week, I was feeling the Element GT52 Turbo big time
However, we ran into some clitches with the 19 psi wastegate actuator as we had boost creeping up to 21 psi up top (too much for 93 octane pump gas)
We ordered a new 9 psi internal gate actuator and SADLY it also had significant boost creep and was shooting up to 21 psi at red line
In order to better control the boost we added a Ultimate Racing upipe with tial 38 mm EGW and dump tube with Forge Unos MBC
Also, while we were at it the Agency Power header was added - very nice unit 4 into 1 (similar to HKS)
Mod list is
2006 STI - (dyno sheet erroneously says 2004)
Agency Power header
Ultimate Racing upipe and 38 mm Tial EWG
Element Gt52 Turbo
Perrin injectors
Buschur fuel pump
Perrin BIG MAF
HKS Exhuast
Custom Ecutek Easy Ecu tune by Dyno Flash
Here is the difference
same 19 psi of boost - same pump gas 93 octane
Huge gains with the header and EWG
My final answer on this turbo - its a very well balanced quick spooling enjoyable street turbo which will get you well into the 11's on pump gas
However, no way its going to work well with an internal gate and by the time you add in the 1800 plus price tag and EWG set up you are nearly in a rotated mount Gt30 price leauge
My sum up - pricey unit which kicks ass on the street
Al
Dyno Flash is offline   Reply With Quote
Old 11-02-2006, 08:08 AM   #2
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Great Info ... Thanks Al
WRX-Blue-Mica is offline   Reply With Quote
Old 11-02-2006, 09:11 AM   #3
Gordata
Member#: 86891
2002 WRX Wagon VF22
Damn Al, You are the man!! I am going to call you this Next week to come up there, Car is almost out the bodyshop. And bigMaf is setting in my closet at home.
Gordata is offline   Reply With Quote
Old 11-02-2006, 09:18 AM   #4
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Am I seeing this right? One graph shows better low-end whilst the other shows better top-end? Which is which in terms of which car has the EWG and has the IWG?
akira02rex is offline   Reply With Quote
Old 11-02-2006, 09:40 AM   #5
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
the loss of low end could be from the header?
Old 11-02-2006, 09:41 AM   #6
InfamousDX
Member#: 25413
EWG is the blue.
IWG is the red.
I would assume that pretty obvious as EWG's always make more power.
from what al said, he only added the EWG and uppipe.
Old 11-02-2006, 10:10 AM   #7
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
I know I sound like a broken record, but for $1800+$600 for EWG, why bother?
EDIT: I suppose I should read what Al says.
Capt Crunch is offline   Reply With Quote
Old 11-02-2006, 10:19 AM   #8
Ultimate Racing
Member#: 101728
2002 Impreza WRX
Nice work, Al! Why didn't you tell me you were tuning all of Jimmy's cars?
Darryl
www.ultimate-racing.com
Ultimate Racing is offline   Reply With Quote
Old 11-02-2006, 10:22 AM   #9
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Keep in mind that the IWG was creaping at high RPMs, the EWG was holding 19psi. At some point (Al, waht RPM did the IWG start creaping?) it would not make sense to compare the two curves.
javid is offline   Reply With Quote
Old 11-02-2006, 01:19 PM   #10
alfriedesq
Member#: 6788
2014 991 Turbo S
2007 997 Turbo
Darryl
We are loving the Ultimate Racing products for sure
I am hoping to get my car back on the Dyno with the EWG with the stock VF39 unit and sdee what gains it makes on that set up
On my car particularly the Ultimate upipe fit like a glove with that Tial 44 EWG - well done
alfriedesq is offline   Reply With Quote
Old 11-02-2006, 01:21 PM   #11
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
you figure if its gonna be named gt52 then it'd be better than a gt42 haha... the title got me excited but then i thought to myself i've never heard of the turbo before so its prob gonna be in the gt30r power range.
Looks like a great power curve, pics of the engine/turbo?
Caplin 2.5 is offline   Reply With Quote
Old 11-02-2006, 01:25 PM   #12
alfriedesq
Member#: 6788
2014 991 Turbo S
2007 997 Turbo
What is going on in that graph is that one car the EWG one hits 19 psi and then tapers down to 18 - (mainatining a totally safe pump gas boost level)
The other with the IWG hits 19 psi but then after 6,000 the IWG and down pipe CAN NOT flow enough exhuast gasses to by pass the turbine wheel and the boost is uncontrolable and creeping up to 21 psi which is why the power band picks up a bit at the top. At the same boost level on the low part the EWG car is making loads more low end power.
The main issue is that with the high exhuast manifold back pressure of the IWG car the cylinders can not freely evacuate the spent combusion gasses and this leads to knocking and timing retard - this and the high 21 psi boost level are not good for pump gas
This is why I would recomend this turbo ONLY with a EWG
Old 11-02-2006, 01:26 PM   #13
alfriedesq
Member#: 6788
2014 991 Turbo S
2007 997 Turbo
Yes - I do not like the Gt52 name myself
Its a hybrid Gt30 and mistsubishi combo
I think the Gt52 is a bit misleading - esapecially for guys like me who use a real GT42R
Old 11-02-2006, 01:27 PM   #14
alfriedesq
Member#: 6788
2014 991 Turbo S
2007 997 Turbo
Ok Gordata let me know when you are ready
AL
Old 11-02-2006, 01:47 PM   #15
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
I believe that the Element turbos are named after their lb/min flow. The Element GT52 is 52lb/min turbo and the Element GT65 is a 65lb/min turbo. I have no idea why they stuck the GT on the front of the name though as it does make things confusing.
driggity is offline   Reply With Quote
Old 11-02-2006, 01:57 PM   #16
remowgn
Member#: 41149
09 FXT
SSM
+1... why not ET52 or ET65? sounds like a pretty cool name to me.
remowgn is offline   Reply With Quote
Old 11-02-2006, 02:05 PM   #17
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Agreed
Old 11-02-2006, 04:29 PM   #18
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Very interested, keep everyone posted Lot of folks interested in what this can do since headers + EWG up/DP would be a very cool street/pump alternative to a 20g at a comparable price point for folks w/ stock cars looking for the upgrade.
verc is offline   Reply With Quote
Old 11-02-2006, 05:49 PM   #19
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Franky, I am getting rather board of the stock turbo
It has no balls
Its weak and I really dont know if I have the patience to watse a lot of time trying to squeze the last whp I can out of it and tryu to go 11's
I at least have to get it on the dyno and maybe go to the track one time if I am lucky before I put in the gt35
Old 11-02-2006, 05:53 PM   #20
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
This is definitely the highest reading dyno dynamics I have ever seen
Whats stock on this dyno? 280whp?
SuperSTI is offline   Reply With Quote
Old 11-02-2006, 05:58 PM   #21
tearitdown9
Member#: 46417
2008 evo X
where are you seeing full boost on this setup??
looks like a killer street setup.
any comparison to 20g's or sz 49s
tearitdown9 is offline   Reply With Quote
Old 11-02-2006, 09:49 PM   #22
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
It has no balls
You make me laugh (in a good way). You were soooo excited about the EWG and the VF39 about 10 days ago. Now you say it has no balls and you want a GT35. LOL... That's priceless.
You are too accustomed to the Mitsu's that come outta the factory with a pretty decent OEM turbo. The EJ257 should have been released with at least a TD06H-18G (if not bigger) imho.
SilverSurfer04STi is offline   Reply With Quote
Old 11-02-2006, 11:46 PM   #23
Caplin 2.5
Member#: 71203
2005 2.5rs
*homer simpson druel* gt42r *druel* In my dreams.
Thanks for that useful peice of info, it wouldn't happen to be a garret turbo would it? that could explain the GT maybs I uno, only element can tell us.
Old 11-03-2006, 12:50 AM   #24
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
that is exactly what it stands for GT52 Garrett Turbo 52 lb/min compressor wheel.
stu is offline   Reply With Quote
Old 11-03-2006, 03:38 AM   #25
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I brellay wanted to try and do some work to find that ,last ouunce of power in the stock Vf39
But it seems its just a weak punk turbo - I am loosding interest
FS (NY): PE850cc Injectors, GT52 Turbo, IAG EWG setup and MBC Gabriel~ Engine/Power/Exhaust 8 05-17-2009 12:00 PM
FS (NY): PE850cc Injectors, GT52 Turbo, IAG EWG setup and MBC Gabriel~ Tri-State Area Private Classifieds 7 05-17-2009 11:59 AM
Uppipe w/EWG Vs. internal WG at 20g max smittypac Newbies & FAQs 5 04-04-2008 08:04 PM
AZ: Element GT52 Turbo, TXS FMIC, Tial 38mm WG hulkmanj99 Engine/Power/Exhaust 5 10-24-2006 09:40 PM
425 whp on pump gas STI with Dyno Flashed ecutek - case study Dyno Flash Engine Management & Tuning 7 12-02-2004 02:16 PM
