Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 12-04-2006, 11:51 PM   #1
2ndGearFling
Member#: 64466
05, STI on green
Default Buy reverse factory wire harness
2ndGearFling is offline   Reply With Quote
Old 12-05-2006, 12:06 AM   #2
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
Originally Posted by 2ndGearFling View Post
wrong.. the SU03R says female... you would need a male.. which is metra 71-8901
but a normal car side harness like the one I think you're saying is metra 70-8901
vipernj is offline   Reply With Quote
Old 12-05-2006, 11:48 AM   #3
lbergstr
Member#: 134047
2006 WRX Sedan
Steel Gray
is there a walkthrough anywhere for connecting the factory sub to an aftermarket HU? i know it's probably stupid easy but i'm not super bright on this stuff...
lbergstr is offline   Reply With Quote
Old 12-05-2006, 01:47 PM   #4
vipernj
Member#: 86854
2004 fx35 02 Z06
then you should super search
Old 12-05-2006, 02:29 PM   #5
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
Is this an advert?!? Shouldn't this be in the classified section, since you aren't asking a question. You just say, "here it is. buy it." I wish a mod would move this thread...
?!?!?What?!?!? Why the heck are you saying he's wrong, then saying he's right?!? Choose one, please.
janikphoto is offline   Reply With Quote
Old 12-05-2006, 03:54 PM   #6
lbergstr
Member#: 134047
2006 WRX Sedan
Steel Gray
I did. offset's manifesto (http://forums.nasioc.com/forums/showthread.php?t=824983) sez I just need a reverse (male?) harness. but the stock HU thread (http://forums.nasioc.com/forums/showthread.php?t=749402) sez that newer subs are connected to the HU via an 8-pin connector in addition to the 14-pin. I've got an 06 WRX so I'm guessing that applies to me. Dunno if there's a reverse harness available for the 8-pin connector.
So I guess what I really want is a walkthrough specific to the 06 WRX. Probably too much to ask.
Old 12-05-2006, 05:59 PM   #7
vipernj
Member#: 86854
2004 fx35 02 Z06
hush.... i just realized i disagreed then agreed... damn 15 hour work days...
Old 12-05-2006, 07:13 PM   #8
janikphoto
Member#: 10471
2000 BMW Z3
that's alright. I've said a lot dumber stuff than that. That post makes you look like stephen hawking compared to some of the blunders I've posted!!!
Old 12-07-2006, 03:18 AM   #9
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
First, in response to the original post: Gee, that's a bit expensive. There are places out there selling this for less. Search and you will find.
The link is indeed for a "reverse" harness. It looks like the original factory radio harness you'll see inside the dash that plugs into the rear of the stock radio. EDIT: The picture on that web page incorrectly shows a forward harness.
Now for the bad news: The SU03R lacks one of the dimmer wires . So Subaru radios won't light up correctly (or at all). The whole reason you'd want to buy one of these is to plug into a factory radio, so you really want all 14 wires.
See this pin-out for details as well as useful links at the bottom.
SVXdc is offline   Reply With Quote
Old 12-07-2006, 03:20 AM   #10
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
is there a walkthrough anywhere for connecting the factory sub to an aftermarket HU? ...
... the stock HU thread sez that newer subs are connected to the HU via an 8-pin connector in addition to the 14-pin. I've got an 06 WRX so I'm guessing that applies to me. Dunno if there's a reverse harness available for the 8-pin connector.
Connecting the factory sub to an aftermarket HU is actually very easy provided that you use a wiring adapter ("forward" harness) to install your HU.
For the "old-style" subwoofer harness, you'll just insert it into the connection like you would with the factory radio...
Before: car harness--> ]forward harness ---- HU harness> ]HU
After: car harness--> ]sub harness> ]forward harness ---- HU harness> ]HU
(the sub harness has both genders and looks like a short extension cord)
For the "new-style" subwoofer harness, you need to splice two of the wires on the 8-pin plug onto the same colored wires running between the 14-pin plugs. See this thread (pictures in post #18, mod in posts 20 & 21):
stock sub w/ aftermarket hu
If you don't want to splice into your factory sub harness, then yes, you would need a mating 8-pin connector (it would be a "forward" in this case, the same gender as what's on the back of the radio). I haven't been able to find these yet. Next best option would be to buy or build an "old-style" sub harness.
Old 12-07-2006, 12:22 PM   #11
lbergstr
Member#: 134047
2006 WRX Sedan
Steel Gray
Thanks SVXdc!
where to get reverse factory harness? Wagon Joe Car Audio, Video & Security 7 07-01-2004 01:16 AM
Where can I buy a WRX wire harness for towing my trailer? STR8OUT Electrical & Lighting 2 05-23-2003 08:36 PM
Using factory wiring harness... edcoak2001 Car Audio, Video & Security 3 11-29-2001 01:17 AM
aftermarket amp/sub with factory wireing harness jasonmolinari Car Audio, Video & Security 4 11-16-2001 11:47 AM
