Welcome to the North American Subaru Impreza Owners Club Saturday January 21, 2017
Old 12-10-2006, 08:10 PM   #1
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Default Accuracy of the oil dipstick
Alrighty, is it just me or is the oil dipstick on our cars just really inaccurate? I changed the oil the other day, filled it up to "F", drove it in a rallycross, and before going home, checked the oil level and it was past the little hole (this is after the car was sitting for a good 30 minutes).
Today I checked the oil level again at the church parking lot and it was right in between "F" and the hole and the engine was slightly warm...wtf
Ok, rant over...
rougeben83 is offline   Reply With Quote
Old 12-10-2006, 08:52 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
It's not accurate. I've had it tell me I was like a quart over at some instances.
Wiscon_Mark is offline   Reply With Quote
Old 12-10-2006, 11:01 PM   #3
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Same here. I've pulled the dipstick out to see it almost completely dry, put a quart of oil in it, check it again later, then it's a quart over
Can't tell you why for sure either. I think it might be something inherent in the boxer design that some oil stays in the heads or something and doesn't come back down to the pan to be measured.
DerFahrer is offline   Reply With Quote
Old 12-11-2006, 10:56 AM   #4
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Yup, quart over was typical in the past three EJ25's I've owned.
MYfirst00 is offline   Reply With Quote
Old 12-11-2006, 10:59 AM   #5
ttatsumi
Member#: 85763
So, what's the best way to measure it. besides draining everying?
ttatsumi is offline   Reply With Quote
Old 12-11-2006, 11:03 AM   #6
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
I think that's the only other way. Drain it hot and fill it with the amount in the manual. But a little over or a little under isn't going to do much harm. As long as I see a mark on the dipstick, I keep driving.
Old 12-11-2006, 09:28 PM   #7
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
Yeah Ive had 3 Ej25s always had issues. Just the way it is. Gotta be careful.
SLegacy99 is offline   Reply With Quote
Old 12-11-2006, 10:53 PM   #8
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
...why is there such confusion here?
i drain it all the way. put in slightly over 4.5qts and it's full. problem solved.
if the engine was just run it will read low, it's not all in the pan yet.
if it IS running, you're retarded, shut it off. it's not like automatic tranny fluid.
you pull the stick, wipe, then dip all the way, check it.
just put the right amount in, note where it is on the stick AFTER you start it and fill the filter, then let it settle for a minute. go by that.
common sense y'all.
it's a wet stick; about as blatant as a weather rock.
ooberdoob is offline   Reply With Quote
Old 12-11-2006, 11:48 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
It'll be a problem when I have the turbo, bigger oil filter, and oil cooler installed...it won't be 4.5 quarts anymore
Old 12-15-2006, 08:15 AM   #10
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I think the dipstick itself is perfectly accurate, although mine is a dark anodized black which is much harder to read then a silver dipstick.
Oil level should be checked on a level surface, after having sat for 3-4 minutes with the engine off.
Jonathan is offline   Reply With Quote
Stupid mechanical question of the day. redapex Off-Topic 26 06-03-2010 05:40 PM
"The penis is the dipstick of the body's health" -=C=- Off-Topic 4 06-12-2008 11:01 PM
Accuracy of the Apexi Auto-Timer? jpmarotta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-25-2002 12:14 PM
Accuracy of the factory boost gauge. Boosted Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-24-2002 06:14 PM
