Welcome to the North American Subaru Impreza Owners Club Saturday February 25, 2017
Old 01-22-2007, 11:13 AM   #1
06WRXTRacer
Member#: 133147
06 WRX/FOZZ
AW
Default best way to store stock TR enkies w/ RE92s.
Hay guys, got some new rotas and toyos and have kept (and plan to keep my) stock set up. I was wondering what is the best way to store the wheels? As of now i have them flat one on top of the other in two stacks of two, but is it best to have them half full, full, overfull, exc. Should i try and keep the wheels from sitting on the ground and rest them on the rim someone? Anywho any help would be greatly appreciated.
06WRXTRacer is offline   Reply With Quote
Old 01-22-2007, 01:17 PM   #2
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
There have been several threads here disussing wheel and tire storage -- but it's been a while. Here's what I do with my second set: Clean off the wheels. Inflate the tires to normal pressure. Wrap in a large, heavy plastic bag (I use bags for yard waste). You can even use a vacuum cleaner to suck the extra air out of the bag. Store the wheels flat; stacking them four high is not a problem. If you store the wheels in a garage or basement, be sure they are raised a few inches up off the concrete slab using wooden blocks or something similar. This should keep the wheels good shape and prevent the tires from degrading due to cold, dampness, UV, dryness, etc.
thorongil is offline   Reply With Quote
Old 01-23-2007, 12:47 PM   #3
06WRXTRacer
Member#: 133147
06 WRX/FOZZ
AW
That is a good idea. I'll give that a shot!
Thanks bro.
Troy-
Best way to store heads/cams flwrx Built Motor Discussion 6 05-07-2006 02:33 AM
What is the best way to store your wheels/tires for the winter? Bankie Tire & Wheel 3 11-13-2005 11:30 PM
Best way to store an almost new tire? silvercharged Tire & Wheel 7 07-05-2005 07:30 AM
Best way to store tires for winter is. . . skiteton Tire & Wheel 17 11-30-2004 10:48 AM
best way to launch stock wrx? iDRIVElikeAmadman Proven Power Bragging 8 09-23-2003 09:49 PM
