01-25-2007, 01:16 PM | #1 |
Member#: 103320
Vehicle:1998 swapped Forester L |
openECU tools on an EcuTek ECU?
I have an EcuTek flashed ECU. I'd like to be able to scale my injectors and MAF, then make the drive to my tuner, where he could then make my final map with EcuTek. Is there any reason why I can't do this?
01-25-2007, 01:48 PM | #2 |
Member#: 103136
Ecutek started "locking" out the ecu about a year ago. So, you won't be able to read or flash the rom if you have had a tune within this period.
01-25-2007, 02:06 PM | #3 |
Member#: 41049
South East
Vehicle:2010 Impreza WRX KTM 250sx |
You can go to OpenECU.org or activematrix.com and DL'd the ECUunlocker program.
01-25-2007, 02:09 PM | #4 |
Member#: 103136
01-26-2007, 06:36 PM | #5 |
Member#: 103320
This is a very interesting point. I am actually running a ECU which is not my original, so the license could well be one of the older versions which is unlocked.
Pardon my ignorance, but with a tactrix cable, and the OpenECU tools, I could confirm this? |
02-04-2007, 03:48 PM | #6 |
Member#: 87629
SCIC
I would also like to know, as I have an ecutek tune and want to get into open source tuning. I got retuned last month but I'd like to be able to adjust wg duty and other settings for the climate in new orleans. how can I make use of the free software with my setup?
blown95 |
02-04-2007, 05:10 PM | #7 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
as has been stated, if you were reflashed with ECUTEK in the last 12 months approx. then your ECU has been locked out, so the open source tools, as well as the dealer ECU tools (including other flashing tools from people like Cobb), won't be able to read the ECU at all. You can confirm this by trying the ECU read function in the ECUFLASH program with the Tactrix cable, if the check engine light just continues to blink and the fans cycle then most likely your ECU is locked out.
If you got ECUTEK'ed last month, then it's 100***37; definately locked out. If you had your ECUTEK done over a year ago, then it's possible that you *may* be able to read it. The ECUUNLOCK program ONLY works with the Mitsus. |
02-05-2007, 02:17 AM | #8 |
Member#: 87629
SCIC
thanks for the good ingo gethin.
02-06-2007, 07:15 AM | #9 |
Member#: 26714
Vehicle:2002 Spec C LUR LUR |
Read the sticky up top for the full story.
will a version1 utec work on an 03 ecu | Sharky NRK | Engine Management & Tuning | 0 | 10-24-2005 12:15 AM |
Can I use a Cobb AP on an Ecutek ECU?? | mrtrex | Engine Management & Tuning | 3 | 10-02-2005 10:46 PM |
MBC on an ECUTek reflash | wcbjr | Engine Management & Tuning | 11 | 07-27-2005 11:51 PM |
Anyone using AutoEnginuity Scan Tool on an '04 STi? | SaabTuner | Electrical & Lighting | 10 | 01-31-2005 06:13 AM |
Tuning with Delta Dash on an Ecutek Reflash | Tuned | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 10-04-2004 08:43 PM |
