01-26-2007, 01:36 PM | #1 |
Member#: 10108
NWIC
Vehicle:1874 Bicycle |
OSECU 2006-2007 WRX Stage 1 map comparisons
For all you guys bashing the OSECU maps (2006-2007 OSECU stage 1 and OSECU-EF stage 1) and open source tuning, I have datalogs of both stock stage1 free maps. One of them is really near the edge and the tuning strategy is somewhat different (more boost, less advance, VVT stuff). The other takes a different approach.
I see 0 knock (KC and IM pegged at max values all the time during boost) on the "EF" map. On the "OSEC" map, I saw what could have been knock, ECU pulled 1 degree but the KC near that area was not normalized, so you cannot tell if it was ping or the ECU code doing a ramp function. I prefer the "EF" map. It looks to be a very safe tune and pulls nicely. Here's the link with HP/TQ graph comparison based on engine load (you will have to register to see the forum): http://www.plasmatize.com/osecuroms/...t=295&start=30 Seriously, though, if you do not know the basics of how an engine works, then throwing a short ram, TB exhaust, etc on your car without any tune is bad. Plus, a tuner does not drive your car everyday. He is not going to listen to ping because he isn't there! If anyone decides to mod a WRX, they need to know about how an engine works first, whether they are using a tuner or tuning it themselves. At the very least, they need to know what knock and ping sounds like, so they can log it, post it and drive slow till someone helps them fix their map who has more knowledge, then log again. How may tuners have caused customers blown engines? ALOT. If that customer was educated, had a knocklight or logged, then he would not have blown up. Plus if you learn to tune and log yourself, a trip to the dyno is much cheaper than a tune.
Last edited by gabedude; 01-27-2007 at 11:09 AM. Reason: Changed cyliner pressure to engine load |
01-26-2007, 01:39 PM | #2 |
Member#: 99289
We need a login over there, rehost?
01-26-2007, 01:45 PM | #3 |
Member#: 10108
NWIC
01-26-2007, 02:14 PM | #4 |
Member#: 99289
Thanks. That's neat information to have.
01-26-2007, 03:40 PM | #5 |
Member#: 72829
W. Canada
Vehicle:2006 WRX 2015 WRX |
The 'OSEC Stg1' map that you used does not have the same 'timing fix' that is applied to the 'EF' map. That is why the timing takes a dive at ~3800rpm. Some details on this topic can be found here:
http://forums.nasioc.com/forums/show....php?t=1155809 http://www.enginuity.org/viewtopic.php?t=666 |
01-26-2007, 03:59 PM | #6 |
Member#: 10108
NWIC
Thanks, I see the details, but I didn't find where they found the exact reason in the ECU code that causes that drop in KC. I suppose they found the fine correction table eventually.
Anyway, doesn't really matter as this EF map will be my base map and I'll only change it if it starts pinging. |
01-26-2007, 10:07 PM | #7 |
Member#: 16827
SCIC
Vehicle:2003 WRX(Sold), Z4 Aspen White |
damn, those are 'good' numbers for stage 1 now i need more power for my stg 2
01-27-2007, 09:41 AM | #8 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Your HP/TQ numbers are not based on cylinder pressure. They're based strictly on the engine load value logged by the ECU and completely ignore the effects of spart advance, intake valve advance and air fuel ratio on HP/TQ. They're meaningless. |
01-27-2007, 10:17 AM | #9 | |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
01-27-2007, 10:44 AM | #10 | |
Member#: 10108
NWIC
Check this thread out about load and TQ relationships, I am just using it to get an idea of the power curve comparing the two maps. Its far from accurate , but its better than nothing. http://forums.nasioc.com/forums/show...1099390&page=8 The EF map is one ev8siv3 made and he denoted it is a test map. IIRC, it stands for "EconoFormance" and it is very smooth. |
01-27-2007, 10:51 AM | #11 |
Member#: 2992
NESIC
Consider the case where you jack up the boost, severely retard spark advance and drop the AFR down to 9.5:1. You get more engine load without knock but less HP/TQ.
01-27-2007, 11:00 AM | #12 | |
Member#: 10108
NWIC
I have a gtech in the head unit I just installed. I'll get a reading off that thing in a few days. I may dyno it soon just to see what power it really is making. |
01-27-2007, 11:01 AM | #13 |
Member#: 10108
NWIC
01-27-2007, 11:03 AM | #14 |
Member#: 10108
NWIC
I'm no mechanical engineer, so if someone has a better formula I can use for estimating the curve from my logs, go ahead and gimme the link.
01-27-2007, 11:06 AM | #15 |
Member#: 10108
NWIC
Yeah thats what the OSECU map did, and it hit a max load of 2.5 (5.0 for you 16 bit guys) and I can tell you that it felt like more torque, but the power near redline really drops off on the OSECU map, you can feel it but the graph doesn't really show it. The EF map uses a good advance rate and lower boost and it feels much more powerful than the other map in the upper rev ranges.
01-27-2007, 11:47 AM | #16 |
Member#: 88322
Vehicle:2009 BMW 135i |
The best answer would be to use vehicle speed or RPM to estimate acceleration rate. Knowing how much your car weighs together with acceleration rate gives you a more encompassing number. The problem here is the logger doesn't log very fast, giving a very volatile number.
01-27-2007, 12:37 PM | #17 | |
Member#: 16827
SCIC
fwiw, my stg 2 after those 'rough' calculations gets 280tq and 247hp, which is why i said your numbers look nice im still working on my tune slowly |
01-27-2007, 04:59 PM | #18 |
Member#: 10108
NWIC
Cool, it is quite useful it seems for tuning without a dyno. You get close at least.
01-29-2007, 09:41 PM | #19 |
Member#: 115771
NWIC
Vehicle:2006 WRX WAGON OS Stage 1 |
I am glad I read this before I flash my stage 1 map, I think I will try out the EF map first
01-29-2007, 10:39 PM | #20 |
Member#: 10108
NWIC
I'll be doing more logging soon, but so far, the EF map is much better on gas and it is mostly smooth. Better than stock for sure.
03 WRX stage 1 map help | CSwrx22 | Open Source Reflashes | 29 | 08-26-2010 01:53 PM |
AP2 on 04 WRX Stage 1 Maps in California | ayoraider07 | AccessPort | 2 | 02-14-2010 02:31 PM |
FS:NY(BRAND NEW CUSTOM 2006-2007 WRX or Wrx STI BODY KIT), And Lambo Door Kit | bluesti888 | Exterior/Styling | 4 | 11-21-2009 11:22 PM |
FS:NY(BRAND NEW CUSTOM 2006-2007 WRX or Wrx STI BODY KIT), And Lambo Door Kit | bluesti888 | Exterior/Styling | 0 | 08-14-2009 04:37 AM |
WTT: 2006-2007 WRX TR Seats for WRX Seats | chad1043 | MWSOC Private Classifieds | 5 | 01-14-2009 04:11 PM |
