Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 01-26-2007, 04:06 PM   #1
bdon22
Member#: 113940
2006 WRX
Steel Grey Metallic
Default Gauges for Stage 1?
I'm thinking of picking up a Tactrix cable & boost gauge. My car will only have sillicone IC hoses, drop-in panel filter, and silencer delete for 'power' mods, everything else is stock. I'm really not looking to drop a ton of money into gauges (300 for afr, egt, etc...), so would this be enough to safely run a tweaked stage 1 base map?
bdon22 is offline   Reply With Quote
Old 01-26-2007, 04:46 PM   #2
gabedude
Member#: 10108
1874 Bicycle
This should answer your question.
http://forums.nasioc.com/forums/show....php?t=1188171
A wideband is always best to make a good map, otherwise try to find a good stage map to start with and tweak it. Log and understand what the ECU is telling you. But no, you just need a laptop and the cable to start with a base map and adjust it to your mods.
gabedude is offline   Reply With Quote
Old 01-26-2007, 04:50 PM   #3
gabedude
Member#: 10108
1874 Bicycle
BTW, the EF map on 93 should be fine for your mods. If you run 91 and get knock, then scale back the timing some in the trouble areas that don't have a KC of +6 (with the EF stage map, you should see +6 KC in boost all the time or else you are knocking). If you don't understand this, read in this tuning forum as well as the various other open source tuning forums.
Wtt:ACT stage 2 Cluth for stage 1 04-08 STI the real suby dude Tri-State Area Private Classifieds 3 05-31-2008 11:18 AM
Poll: Gauges for Stage 2 STi?? JM530 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 03-24-2005 09:01 AM
WTT: Stage 2 Unichip for Stage 1 Unichip Lachlan Private 'For Sale' Classifieds 21 11-07-2004 09:21 PM
FS Ecutek/ECU for Stage 1 Vishnu WRBLUEWAGON Tri-State Area Forum 5 03-04-2003 04:47 PM
Anyone know what model Magnaflow exhaust TurboXS uses for stage 1? imprezive one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-30-2002 03:34 PM
