01-28-2007, 01:44 PM | #1 |
Member#: 124053
Vehicle:2002 WRX Back to BONE STOCK |
Important EWG/IWG/WGDC question I NEED answered.
When you deal with WGDC's, do they react the same with an EWG as they do an IWG?
01-28-2007, 02:03 PM | #2 |
Member#: 44762
Vehicle:2013 BRZ WRB |
As in, do changes cause similar effects? Yes. Will your stock WGDC table work with an external gate? No.
01-28-2007, 03:53 PM | #3 |
Member#: 124053
01-28-2007, 06:45 PM | #4 |
Member#: 44762
Wow, thats good news.. What gate are you using?
01-28-2007, 07:59 PM | #5 | |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
01-28-2007, 10:29 PM | #6 |
Member#: 124053
Tial 35mm... I'm wondering if theres some type of pattern EWG vs IWG on the duty cycles.. like to get the same effect out of the EWG maybe decrease the numbers across the table..
What I may end up doing is tuning on my IWG, and then logging a 4th gear pull. Then switch over to EWG and log a 4th gear pull to compare. |
01-28-2007, 10:29 PM | #7 |
Member#: 124053
Thanks for the reply, I'll tell you how it goes
01-29-2007, 01:23 PM | #8 |
Member#: 44762
What turbo are you running? I've been holding on to this externally gated up pipe for quite some time and eventually plan on installing it with my ported and polished td04.
01-29-2007, 06:59 PM | #9 |
Member#: 124053
01-30-2007, 11:05 AM | #10 |
Member#: 44762
Have you done any tuning? I was holding off on the external gate because I was afraid I wouldn't get enough fuel without bigger injectors and a pump.
01-30-2007, 09:02 PM | #11 |
Member#: 124053
No i put it on, i hooked a friends wb02 sensor up for a day a few weeks after i put it on and all my fueling looks normal... i was hitting about 10.5:1 @ wot, 16psi
02-02-2007, 07:20 PM | #12 |
Member#: 88322
Vehicle:2009 BMW 135i |
The first approximation trend is the same. Higher duty, more boost. The overall shape might be very different, but it also has a lot to do with the turbo.
It's likely the WG actuator spring is much stiffer. Going from a 7psi to a 15psi spring means you really don't need much WGDC at all until you are asking for 15+psi. Be careful loading high numbers where you don't need them, as it will end up giving you poor performance. |
will castrol import work in the auto 5eat? NEED ANSWER ASAP please | boostdog | Transmission (AT/MT) & Driveline | 4 | 07-15-2009 04:01 PM |
Questions I need answered for 06STI stock, needing mods | messobren | Newbies & FAQs | 15 | 12-24-2006 03:27 PM |
Just installed my Helix DP, questions that need answers | skiblur | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 11-20-2003 09:58 AM |
questions that need answers | shortfuseWRX | Alaskan Impreza Club Forum -- AKIC | 18 | 07-31-2003 09:38 PM |
questions that need answers.... | chivespa1 | Mid West Subaru Owners Club Forum -- MWSOC | 7 | 11-30-2002 04:38 PM |
