01-29-2007, 02:18 PM | #1 |
Member#: 60972
BAIC
What parameters should I log?
I would like to start logging so I can run a better tune than my current map, my question is what parameters should I log?
01-29-2007, 03:41 PM | #2 | |
Member#: 12263
South East
Vehicle:'02 WRX SRP 4EAT XPT Stg II |
Subaru DBW Paramaters Advance Multiplier Engine Load Engine Speed Ignition Timing Intake Air Temperature F Intake VVT Advance Angle Left Knock Correction Manifold Relative Pressure (corrected) Mass Air Flow Primary Wastegate Duty Cycle Throttle Opening Angle Vehicle Speed MPH Ext LM1_O2 (Any wideband IF available!) Chris |
01-29-2007, 04:04 PM | #3 |
Member#: 60972
BAIC
Thanks for the help.
I'm using the enginuity logger and I don't see the advanced multiplier...should I use a different program or am I missing something? |
01-29-2007, 04:21 PM | #4 |
Member#: 12263
South East
I use ecuexplorer and the advance multiplier is under the user defined data items. You will also find Engine Load, and Manifold relative pressure (corrected) there too
use this page to determine which of each you will need (there are multiples) http://www.scoobypedia.co.uk/index.p...emoryLocations Chris |
01-29-2007, 06:03 PM | #5 |
Member#: 60972
BAIC
I also found this on the enginuity site just in case anyone is interested
Engine Speed (RPM) Throttle Opening Angle (***37;) Intake Air Temp (f) Ignition Timing (btdc) Vehicle Speed (mph) Knock Correction (btdc) Manifold Absolute Pressure (psi) Manifold Relative Pressure (corrected) Atmospheric Pressure (psi) Primary Wastegate Duty Cycle (%) |
01-30-2007, 11:15 AM | #6 |
Member#: 44762
Vehicle:2013 BRZ WRB |
Version 0.4.0 of Enginuity doesn't have IAM defined in the logger xml. It will be autodetected and available in 0.4.1, which should be released within the week.
What parameters can the AccessPort monitor? | blitzmr2 | AccessPort | 0 | 01-02-2009 10:36 AM |
Logging..what parameters? | vision.dynamix | Open Source Reflashes | 7 | 09-23-2008 12:59 AM |
Newbie Question - What Should I Log? | adeliciouspizza | Open Source Reflashes | 4 | 07-13-2008 03:51 PM |
What should I log to compare a power gain between parts? | Rick Schu | Engine Management & Tuning | 9 | 10-09-2007 07:45 PM |
What Parameters to Log to Check Car is Running Properly ? | Murf_68 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-07-2007 07:45 AM |
