Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Old 02-03-2007, 11:13 AM   #1
xblaze1one
Member#: 123395
Midnight Black Pearl
Default egt ?
I have my tactrix cable, stage two map, and wideband o2 sensor. I was wondering if i can just keep the stock egt sensor and use laptop datalogging in real time to watch my egt's.
xblaze1one is offline   Reply With Quote
Old 02-03-2007, 03:54 PM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Not really. The stock EGT sensor is too far away from the cylinder to have any real value. It was put there by Subaru to monitor the health of the sotck uppipe cat.
The value you would read could be 200-300F low.
Your best bet is to watch A/F ratios or install an EGT gauge with the probe directly near the exhaust valve. Plenty of threads on that.
blkscooby is offline   Reply With Quote
Old 02-03-2007, 06:41 PM   #3
xblaze1one
Member#: 123395
will i have to get rid of the stock egt sensor when i put a catless uppipe in? I have read that the probe on the stock sensor is very weak and could burn up and go into my turbine! Also what would you say would be my best bet for keeping everything safe wideband o2, egt, or knock? I can't afford all right now and i am using a premade map, i am not really playing around with tuning myself just yet i want more background before i start that.
Old 02-03-2007, 10:50 PM   #4
blkscooby
Member#: 44422
2009 G8 GT
Its a good idea to get rid of it. I'm not sure how real the danger is but there is some to leaving it in.
Also, if you can only afford one, my recommendation would be to get the WB02 first.
Old 02-26-2007, 01:30 PM   #5
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
Bolt to plug the uppipe egt bung: $2
New turbo: $150
Not having to troubleshoot a blown turbo: Priceless
Do yourself a favor and get rid of the stock EGT sensor as soon as you get a catless uppipe.
brettm is offline   Reply With Quote
autometer egt gauges, what egt probe are you using? Tobey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-09-2004 11:19 PM
Issues with Stock EGT bung location and Omori / other EGT gauge probes? DTECH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-06-2004 08:24 PM
Autometer Ultra lite EGT with oem egt probe? dubRexn Electrical & Lighting 2 09-17-2003 05:43 PM
will a defi egt probe fit into the factory uppipe egt location? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-08-2003 12:32 PM
what to do with uppipe factory egt if using defi egt whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-21-2002 04:57 PM
