02-10-2007, 02:54 PM | #1 |
Member#: 118769
Vehicle:2006 WRX Sedan Aspen White, XPT Stage 2 |
ecuFlash help - Unknown Rom Image
First off, is this correct?
Second, I'm at altitude of 4500 and running Stage 1 map from osecuroms.org. Target boost is 14.7 but i'm only reaching 11.5psi. Anybody know what table, if any, i should change to compensate for elevation? Third, after i reflash, am I supposed to reset ECU (unplug battery for hour or whatever) it?
02-10-2007, 07:56 PM | #2 |
Member#: 25433
Vehicle:2003 WRX SW all we'll drive |
After a reflash you do not have to reset the ECU by unplugging the battery. You just have to remember to disconnect the green connectors (after shutting off the car - not sure if that's important, it's what I just do). Your first two questions....don't know....
Ecuflash won't read rom, but will write..help. | scoobystas | Open Source Reflashes | 9 | 07-01-2009 04:31 PM |
Unknown rom file ECUflash error for 06 wrx tr | choiboi | Open Source Reflashes | 7 | 05-22-2009 08:10 PM |
Ecuflash Edit with Rom Raider. ?????? | javastiwagon24 | Open Source Reflashes | 4 | 04-16-2008 02:49 PM |
Laptop can't open ROM image to flash | o2sys | Commercial ECU Reflashes | 10 | 08-16-2007 01:13 PM |
help unknown BOV | slipknot23 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 10-09-2002 08:54 PM |
