02-11-2007, 04:22 PM | #1 |
Member#: 53665
NESIC
Vehicle:2022 BMW M240i Thundernight |
Tapping the stock knock sensor, will this work?
Hey guys,
I am entertaining the idea of tapping my stock knock sensor based on this write up: http://home.netcom.com/~bsundahl/kno...ten/listen.htm Pretty much, I can tap the sensor wire, put in a capacitor and resistor and run it into some kind of a listening device. This seems straightforward to me except for one part. My stereo has an auxiliary stereo input which I'd love to use for listening to the sensor. Would the whole thing work if I just connected the signal off the sensor to an aux plug which I can than convert to a proper stereo plug and run that into the deck? I am concerned that the signal will not be enough for me to hear through the deck. Do I have to do some kind of an amplification first? I searched around and there's lots of old threads with indirect info. If someone has a similar setup running, please send me some info. Any help is much appreciated.
02-11-2007, 08:04 PM | #2 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
That circuit is an audio amplifier, you need it to be able to hear it.
I have used it and it works well. The signal coming from the knock sensor is too weak for you to plug into your line input, and you need that capacitor anyway to isolate any DC from getting into your ecu. |
02-12-2007, 08:54 AM | #3 | |
Member#: 53665
NESIC
02-12-2007, 09:46 AM | #4 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
Useless. It DOES give you audio but you can't hear the difference between what is knock and what is just a loud as heck engine. I've tried it, it doesn't do anything but make lots of noise since our knock sensor is broad spectrum and the processing is done in the ECU.
02-12-2007, 10:16 AM | #5 | |
Member#: 53665
NESIC
06-12-2007, 03:06 PM | #6 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
I am *still* in the market for a device like the one you mention, Ziggyrama.
I've done the wiring as you pointed at in your first post. With post-analysis using "Gram" or "Cool Edit Pro" it is most definitely better than NOT listening. I have wanted to make something proper for years now but I lack the electronics skills to design the unit. I even offered $50 to a certain forum to help me out. All I frickin want is 4KHz - 8KHz from a knock sensor in realtime with volume control and a headphone jack. Hell, maybe I'll just rip apart a TXS KnockLite and amplify its signal to an audio jack somehow. |
06-12-2007, 05:48 PM | #7 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Here's an interesting post from http://www.enginuity.org/viewtopic.php?p=6921#6921:
06-12-2007, 06:12 PM | #8 |
Member#: 8512
South East
Yes, unfortunately, Link ECU USA is in "la la land" so getting a KnockBlock is almost futile.
http://www.linkecu.com/dealers/dealersusa * http://www.link-electro-usa.com/ : Tried their Contact Us email address. Bounced. * Off Road Buggy Supply (O.R.B.S.) looks super sketchy. Would not order from them. * Vivid Racing ... nuff said. Won't order from them on principle alone, let alone their high prices. * Brain Storm, aka miata.org : Dead link * http://www.finelineimports.net/ : Cannot find KnockBlock anywhere on the site * http://www.flyinmiata.net : Zero search results for KnockLink or KnockBlock * http://www.fairfieldcountymotorsport.com/ : Zero Link products shown |
06-12-2007, 06:16 PM | #9 |
Member#: 8512
South East
Not only that, tried to order from www.linkecu.com directly.
Code:
Site Error An error was encountered while publishing this resource. NotFound Sorry, a site error occurred. Traceback (innermost last): * Module ZPublisher.Publish, line 196, in publish_module_standard * Module Products.PlacelessTranslationService.PatchStringIO, line 34, in new_publish * Module ZPublisher.Publish, line 146, in publish * Module Zope2.App.startup, line 222, in zpublisher_exception_hook * Module ZPublisher.Publish, line 115, in publish * Module ZPublisher.mapply, line 88, in mapply * Module ZPublisher.Publish, line 41, in call_object * Module Products.CMFFormController.FSControllerPageTemplate, line 90, in __call__ * Module Products.CMFFormController.BaseControllerPageTemplate, line 28, in _call * Module Products.CMFFormController.ControllerBase, line 232, in getNext __traceback_info__: ['id = formmailer', 'status = success', 'button=None', 'errors={}', 'context=<PloneFormMailer at order-form>', 'kwargs={}', 'next_action=None', ''] * Module Products.CMFFormController.Actions.TraverseTo, line 38, in __call__ * Module ZPublisher.mapply, line 88, in mapply * Module ZPublisher.Publish, line 41, in call_object * Module Products.CMFFormController.FSControllerPythonScript, line 104, in __call__ * Module Products.CMFFormController.Script, line 145, in __call__ * Module Products.CMFCore.FSPythonScript, line 108, in __call__ * Module Shared.DC.Scripts.Bindings, line 311, in __call__ * Module Shared.DC.Scripts.Bindings, line 348, in _bindAndExec * Module Products.CMFCore.FSPythonScript, line 164, in _exec * Module None, line 19, in formmailer_send <FSControllerPythonScript at /clients/LinkElectroSystemsLtd/formmailer_send used for /clients/LinkElectroSystemsLtd/billing-and-shipping-info/order-form> Line 19 * Module Products.PloneFormMailer.PloneFormMailer, line 401, in send_form * Module Products.PloneWebsiteTemplates.antispam.Spammers, line 33, in logIfSpammer NotFound: (Also, the following error occurred while attempting to render the standard error message, please see the event log for full details: name 'checkPermission' is not defined) Troubleshooting Suggestions * The URL may be incorrect. * The parameters passed to this resource may be incorrect. * A resource that this resource relies on may be encountering an error. |
06-12-2007, 07:02 PM | #10 |
Member#: 2992
NESIC
Maybe you should try their forums to see whether anyone anywhere will sell you a KnockBlock.
http://www.linkecu.com/forum/forums |
$40 knock sensor, Will it work?? | 96GreenLX | Service & Maintenance | 4 | 07-08-2007 10:02 AM |
Reading the Stock Knock Sensor | subachad | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 01-22-2004 02:12 AM |
Essay on the stock knock sensor, DeltaDash, and engine management ... | wayoutwest | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 01-24-2003 12:40 PM |
Anyone try this with the stock knock sensor? | 8Complex | Normally Aspirated Powertrain | 3 | 10-20-2000 05:49 AM |
Has anyone removed the stock Knock sensor?? | TMR Impreza | Technical Forum Archive | 7 | 05-19-2000 06:52 PM |
