02-14-2007, 03:31 PM | #1 |
Member#: 71744
05 wrx block swap
Hey guys,
First of all HELP and thanks for any info. I have a 01 2.5 rs impreza. I was doing a motor swap to a 05 wrx and when the motor was installed i learned that the block was bad. So i have to swap the block out. I was offered a USDM sti block with forged piston. The setup i have thus far is 05 wrx motor VF 39 STi pink injectors STi TMIC gruppe s headers Injen CAI ERZ up pipe ERZ catless downpipe Greddy evo catback Now my question is can i do a block swap with out engine management? Will this block work with the setup i have with any problems? The Mech was going to do a cpu flash for the setup i had with the wrx block. But since that doesnt work he said it will still work fine. What do you guys think? Also he wanted me to do a value job before the motor goes in. The Mech ported the wrx heads. What do you guys think? I am real new to this block swap. I have been having bad luck with this swap and just want it to be done and relaible. I want a fast car and also a daily driver if needed. Any input would be great. IF i have to get a EM system can you guys recommend the best route. Im not really going to play around with it much. i just want to set it and forget it. Also price is a factor. Thanks
02-17-2007, 06:34 PM | #2 |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
What engine management are you using right now? Stock 2001? '05 WRX ecu?
02-17-2007, 08:03 PM | #3 |
Member#: 71744
It has the 05 wrx ecu
PSM 05 STi for 05 WRX trunk swap | psmBoXer | South East Region Private Classifieds | 1 | 01-14-2014 01:09 PM |
05 wrx- block swap | Gemni69 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 02-14-2007 02:22 PM |
wrx - block swap | Gemni69 | Subaru Conversions | 0 | 02-14-2007 05:02 AM |
05 wrx ecu swap to 05 ecutek problem? | nuhga | Engine Management & Tuning | 1 | 11-12-2005 06:27 PM |
EJ20 WRX Block Swap | Soon2BturbodRS | Subaru Conversions | 2 | 06-17-2003 12:45 PM |
