03-05-2007, 02:36 PM | #1 |
Member#: 41561
Vehicle:04 GT3076 2.1 Stroker = Broken 3rd |
Enginuity: Is load column based on MAF voltage?
I am just curious, I am trying to get into OPEN ECU tuning but I do not know what load columns are based off of.
Are is the load column based off of MAF voltage?
03-05-2007, 02:57 PM | #2 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
lol, no. It says what it is based off of on the left
2*g/rev is the calculation. It is 2 times the current grams per second devided by the rpms per second. |
03-05-2007, 03:30 PM | #3 |
Member#: 41561
Alright...But that still doesnt help me.
Is there a good read up somewhere. I'm coming from the utec world where Load is based off from how much boost ur running. |
03-05-2007, 03:48 PM | #4 |
Member#: 44762
Vehicle:2013 BRZ WRB |
Load = MAF(g/s) * 60 * 2 / rpm
03-05-2007, 03:49 PM | #5 |
Member#: 115260
Vehicle:04 WRX 205/22E Hybrid w/ VF39 |
What exactly are you looking for?
Load is based on airflow and rpm, as stated. It is an indicator of torque. Higher the load, higher the cylinder pressure. (At least thats what I assume) Log load and RPM to find out where you are on the map. Thats the cell it's using. If it falls between two cells, it interpolates. Sounds like you are looking to relate it to something else you are used to in UTEC. Unfortunately I can't help you there, as I've never used one. I'm sure other's can chime in that have. |
03-05-2007, 04:26 PM | #6 |
Member#: 41561
MAF Voltage when Car in on, but not running | Mechie3 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 11-25-2009 08:43 AM |
0 LOAD column as no effect in changes on idle AFR | NITROS | UTEC | 10 | 08-10-2006 10:45 AM |
why is load column only 80 | baldchicken | UTEC | 11 | 08-08-2006 12:02 PM |
MAF voltage on stock sti turbo? | overdose | Engine Management & Tuning | 8 | 07-06-2006 01:32 PM |
Crackle in speakers based on engine load | wrxsvt | Car Audio, Video & Security | 1 | 12-15-2001 12:40 AM |
